Question about Roper RAS6233KQ Top Load Washer
Washing Machine won't drain.
Washing machine works fine till time to drain. Won't work if drain hose is in up position, put if I put it down to floor, it will drain fine. I'm currently running the drain out the back door. Please help!
  • sandylee127 Jan 07, 2009
    Need more help Please! First solution did nothing!
  • Roper Master
  • 19,396 Answers
That means that the drain pump is not generating enough pressure, this usually happens when the drain pump hose is clogged.
The drain pump must be accessed, then you take off the hoses, and check and clean pump and lines.
Also check the drain filter attached to the pump.
If you find no obstruction , then the pump must be replaced.
Here parts and diagrams for your appliance.
Posted on Jan 07, 2009
  • 4,806 Answers
Hi there
It sounds like the drain pump is faulty or not working at all, the reason the water drains when the pipe is in the down position is to do with gravity.
Have a listen to the pump itself, if you can hear it humming its working and there is probably a blockage in it, if you cant hear it humming its broken and needs replacing
Good luck
  • Roper Master
  • 8,220 Answers
Most likely a bad lid switch.
  • 916 Answers
1) Be sure the drain hose isn’t kinked.
2) Check the tab on the lid that strikes the lid switch; if it is broken, the washer may stop during the drain cycle. Press and release the lid switch. If it doesn’t click each time you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repairperson.
3) The water pump may be broken or clogged with a small article of clothing, or the controls may be broken
  • Roper Master
  • 3,463 Answers
The reason it works o/k when the hose is laid down , is because the water is syphoning out due to gravitation, so obviously the problem is that the pump is not working. This can be for one of several reasons, first and foremost, the pump is blocked, even if it is partially blocked the water will still syphon out.
Next is that the outlet is blocked be it to an outside sink or drain.
To elminate this. put the drain hose into a sink or other recepacle ,try washer on spin program and if it pumps out o/k, then the outlet pipe to the main drain is blocked or partially obstructed .Make sure that you have the hose at least 80cmm above ground level
If it still does not pump out, then the problem is the pump itself,
or if it is belt driven then could be worn or broken belt
plz rate my solution.
Thanks.
Posted on Jan 03, 2009
    Sergeant:
    Champion:
  • 201 Answers
Hi LAdy
95% of the times there is dirt money or object blocking the pump, I even pulled a bra once out of a pump. Ok here's what you do.. Let somebody tilt the masjien for you or take the back plate of follow the drain pipe into the masjien look for the pump here's a picture of a sample one Washing Machine won't drain. - 8beae6a.jpg
Disconnect the pipe where water comes in push your finger inside the pipe and feel for objects and in the hale @ the pump this will work inspect it properly make sure you put some sealant in the pipe to prevent leaks
    Novelist:
  • 148 Answers
It sounds like your pump is not working and the reason it drains by puttig the hose on the floor it is letting the water out via gravity
when the washer goe into the drain cycle you can usually hear a pump engage if you do not hear that then the pump is not working
you will have to call for service unless you want to replace the pump yourself
good luck
  • Steve Archer Jan 03, 2009
    another thought is that the drain hose could be crimped in the up position
    FIX
    when the washer goes into pump cycle leift the hose and see if it crimps at the base of the washer
    if it does you can either get a new hose ooro cut the hose at the crimp and reclamp( remove the crimp
    when you put the washer back in positon be sure you do not crimp the drain hose
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, it would appear that the drain motor/pump (and/or impeller) is the issue. It would drain normally by gravity (down to floor) but not "up position" which would require a pumping action from the drain pump.
Couold you pls confirm that the washing machine is a Roper RAS6233KQ?
Good luck and Thank you for using FixYa.
  • 470 Answers
If your washing machine has no problem filling and agitating, but neglects to drain your problem is probably the hose or the pump. If it has no problem completing the other cycles, but will not drain your motor and belt are working fine.
First off make sure that the drain hose does not have a kink in it. Secondly, lift the lid and check to see if the tab on the lid that hits the lid switch is in tact. Press and release the tab and if it does not click then it is probably broken and that could be the problem. Next, check to see if the water pump is broken or clogged, if you are not familiar with washers call a repairman.
Most likely it is a pump or hoses that needs fixed or replaced. This is a pretty easy fix, but if you are worried be sure to call a repairman. One more thing, before you attempt any troubleshooting or fixing turn off the machine and unplug it completely from the wall to avoid injury or shock. All you will need is a screwdriver that matches the screws and a bucket for the water.
1. Remove the drain hose from the drain and try to drain the water from the washer. To do this plug the washer back in and attempt another drain cycle. If water does not come out of the drain hose then you now know that the plumbing is in good working order.
2. Place the drain hose back into the drain and remove the washers cabinet.
3. You will now be able to see the pump and it should have two hoses attached to it.
4. Disconnect the hose coming from the basket. If water comes out you will know that nothing is clogging the basket.
5. If both of these tests come out good you now know that the problem is the pump.
6. Make sure you write down all relevant information such as the washing machine model and serial number.
7. Head to your local hardware store and buy a pump (they typically run about $15.00).
8. Remove the old pump and install the new one (make sure the washing machine is turned off and unplugged).
9. Test it. Let it run through a cycle to make sure everything is installed and working properly.
10. If it is still broken call a repairman or ask a handy friend to check it out for you.
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 07, 2009
    The drain line is probably clogged. Maybe that a sock or other piece of
    clothing get between the clothes tub and the outer tub that holds the
    water. In this case it may then get into the drain hose that's attached
    to the pump.Remove the hoses from the pump and pull the item out. In
    case it clean there, check the outer tub port- open the washer's main
    access panel and remove the large-diameter rubber hose that connects
    the pump to the bottom of the outer tub. Then,try to remove the
    clothing through the port.
    Good luck !
    Antonio Buenafe Jr. Jan 18, 2009
    1. Make sure both hot and cold taps are turned on
    2. Put the washing machine onto the whites program, which should take
      only hot water in. Pull the soap dispenser drawer out a little to check
      that hot water is coming in and at a decent flow rate
    3. When you are satisfied that the hot water comes in OK, either turn
      the program to the last rinse, or if you can't alter the program because
      it's electronic, cancel it and then put the washing machine onto the
      last rinse and restart. Open the soap dispenser drawer to check that
      cold water is coming in at a decent rate.
    If the washing machine wont take in any water at all and the drum doesn't
    start turning - plus you can hear a humming noise, check that both your
    taps are turned on or that the water supply hasn't been cut off in someway.
    The gentle humming from the back of the washing machine could be the water
    valves being energised and trying to take water in, but there's no water
    coming through the hoses.
    If no water enters the washing machine, but the drum starts turning (as
    though washing normally) then you should stop the washing machine as there
    may be a fault in the pressure system that controls the levels of water.
    This fault can cause the timer to receive a false signal that water is
    already in the washing machine and the heater may be energized. This can
    damage the heater or burn the clothes inside. A blocked pressure chamber
    can trap air in the pressure tubing and leave the pressure switch on.
    If this happens, when you put the washing machine onto a wash program
    it doesn't take any water in and starts washing because it thinks there
    is water inside. This fault should also prevent the washing machine going
    into spin though too.
    If the washing machine is not taking in water from one side only, (i.e.just
    the hot or just the cold) then the obvious thing is to check that water
    is actually available through the plumbing from the offending pipe. Turn
    off the tap on the affected supply and unscrew the hose from the valve
    at the back of the washing machine machine. Then simply hold the fill
    hose into the sink or into a bucket and turn the tap back on. If water
    comes through at a decent flow rate then check the filter in the water
    valve on the washing machine. You can pull it out with a pair of pliers
    and clean it. However, this will only explain your fault if it is severely
    blocked up, which is rare.
    If no water comes through the hose, or the flow is very slow, then the
    fault is in the plumbing. This is actually also quite rare, but if your
    machine was plumbed in using those self plumbing taps that clamp on to
    the copper water pipes then they do sometimes get clogged up and need
    the hole clearing. If this happens to the cold supply it can be achieved
    by turning the stop tap off first, but if the hot supply is blocked -
    which is the most likely of the two - then you have to turn off the cold
    supply and then drain the hot water tank by turning on the hot tap until
    the water is drained out (unless you know where the valve is to turn the
    hot water off in your water cylinder).
    President:
  • 2,110 Answers
Your Washing machine will automatically stops while put the drain hose in up psition..u have to put it down...
  • 679 Answers
When you say "up position", there is not a pump to pump water out, only a drain, so if the hose goes above the drain it won't drain. it is just like a sink, it only uses gravity,, the small pump is just to empty the bottom, not to pump above the machines drain
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Kitchenaid KAWS700G will fill and wash but won't drain and spin
My washer also did not drain. I disconnected the power supply and water hoses and the drain hose and lay the machine on its side.. The motor is at the bottom. Once I disconnected the hose and put my finger to look inside. There is a rubber stopper and once I moved that aside and looked inside I found my baby sock stuck in the the pump. Once I gently pulled the sock out It came out easily. Lucky me the motor is in working condition.
My washing machine was manufactured I believe in 1997.
This is the first time ever took look under any washing machine.
Best of luck!
Apr 15, 2013 | KitchenAid Washing Machines
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Jan 05, 2012 | Hoover Washing Machines
Won't spin out water but pump works
1.A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
2.If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.3.Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4.Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5.If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thank you for using FixYa and please don't forget to rate me.
thanks,
Reymond
Oct 18, 2011 | Maytag Washing Machines
My washer w6221 won't drain
Check this following things then your washer will be fine.
* Has the drain hose been put flat on the floor?
* Is the drain hose clogged with lint?
* Is the drain hose kinked?
* Is any part of the drain hose higher than 20 cms from the floor level?
* Is the extension drain hose longer than 3 m?
* Is a narrow drain hose being used?
Thanks for your question.
Jun 26, 2011 | Asko W6221 Front Load Washer
A used washer I am trying to hook up . . I have the drain hose going into the floor drain. The washer fills while at the same time draining. So it never really fills enough.
Washing machines need to be drained into a standpipe. This is a drain that is about 36" off the floor. The drain line on your washer will work fine if you have it installed in a standpipe.
by putting it down into a floor drain, you're not going to allow the machine to fill. The stand pipe will allow your machine to fill and still pump the water out during spin cycle.
Make sure there's a drain hose with a hook on the top.
k
Jul 06, 2009 | Washing Machines
Washing machine won''t drain
HI thanks for your questionOn your washer theres a electric pump sometimes foreign objects get caught in pump remove front panel . Using a blade screwdriver insert between top & front panel about 2 inches from corner .The front should now come off .The pump is on the left side . Disconnect pomer If your washer is full of water now put drain hose on floor or in bucket to drain water . Now remove hoses from pump & clean reinstal . Thanks for your question The appliance doc
Sep 06, 2008 | GE WHRE5260E Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
183 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
