Question about Trendware TEW-452BRP Wireless Router (TEW452BRP)
Several Router problems
Hi to all.... I have the following problems with my Trendnet 452BRP router. 1. WHen setting up a connection using the PPTP protocol (PPTP modem), the router keeps on rebooting every 3 seconds 2. When set to use a PPPoE connection, the router will work normally. But when under heavy traffic, it will intermitently reboot, work for another maybe 3 mins and reboot again. This can go on for anything between 10 times and infinetaly. Rebooting manually does not solve the problem. 3. The wireless feature works OK only when the IP on the wifi card is set manually. If left as "Obtain IP Automatically" the network is found, the laptop displays "connected to Network" but I cannot browse the internet. When IP is set manually, all works fine. DHCP on the router is enabled. I have updated the router's firmware with the latest available on Trendware's site but no progress. I have the Alcatel SPeedtouch Home modem. Can anyone help please? Thanks
  • 21 Answers
It sounds like an ADSL signal strength issue. Test that it is not a problem with the ADSL phone cable setup, using the shortest ADSL/Phone cable you can find (under 1Meter is best)unplug all other phone line using devices and filters from the wall jack points and test the routers connection again as the only device plugged in(this is Isolation testing) If the issue replicates itself under isolation testing conditions then ring your ISP providor and request that the "ADSL signal voltage" needs to be increased slightly as your router is not hearing the ADSL signal properly. If the issue doesn't replicate itself under isolation test conditions, you are either using an old or bad ADSL/Phone cable or your cable is too long (should not be longer than 5meters)or if you are using a wall socket/splitter for direct adsl access (without filters)then test the socket with a filter to verify the socket/splitter is not the cause of the problem, if you do use phone filters, during isolation testing, test each of the filters individualy with the router and see if the disconnection issue is replicated if so replace the bad filter the disconnection issue was being caused by phone signal interferance. Your third request requires you to setup the LAN info on the windows side of your connection not the wireless card, this can be verified by searching for websites via thier IP address which will work, when searching via their website name wont, DNS resolution issue, it is probably best practice to use MAC Addressing for your wireless setup though.
Posted on May 17, 2007
SOURCE:
Set password
Download the user guide from here
TRENDnet Support TEW 452BRP 108Mbps Wireless Super Broadband Router
1. Go to Wireless on the management menu.
2. Got to Security on the next menu and change the wireless security from disabled to your choice of security setting and then follow the prompts. Page 31
Apr 19, 2014 | Trendnet 108Mbps Wireless Super G...
How do I set up a secure password?
For trendnet
Your Trendnet wireless router lets you broadcast your home network across your entire house, so you can access the Internet in any room. This signal may be powerful enough to extend into neighbors' houses, where they could easily jump on the network if it is unsecured. To protect your network, set up Wireless Encryption Protocol, or WEP, to encrypt data and prevent access unless the user enters the correct password.
Type "http://192.168.0.1" in your Internet browser's address bar and press "Enter." Enter "admin" for the username and leave the password field blank. Click "Log In" to log into your Trendnet wireless router's administrative program. Click "Wireless" from the left pane of the "Basic" tab. Click "WEP" under the "Wireless Security Mode" section at the bottom of the screen. Enter your preferred password for the network. A strong password is made up of a random selection of numbers and letters. Click "Save Settings" at the top of the screen to save your WEP settings.
trendnet wireless router users guide
http://downloads.trendnet.com/tew-611brp/manual/ug_tew-611brp.pdf
Mar 26, 2013 | Trendware TEW-452BRP Wireless Router...
Wireless netoworking (router)
Go to start-> run-> devmgmt.msc
In the device management right click the cdrom and click scan for hardware changes
Apr 29, 2010 | Trendware TRENDnet TEW-452BRP 108Mbps...
Wan and All LAN led bulbs are continuously on- Router not working
Straighten a Norwegian paper-clip, and insert one end into the small hole in the back of the router, to "reset" the router to its "factory" settings.
Or, spend $50, and replace the router.
Mar 26, 2010 | Trendware TEW-452BRP Wireless Router...
I am unable to connect to internet with laptop
you did not tell us how you connected to the internet by wireless or ethernet cables. but any way first check the setup of your modem router otherwise your network provider.
Oct 05, 2009 | Trendware TRENDnet TEW-452BRP 108Mbps...
Slow internet connection
Sometimes ISPs (Internet Service Providers) upgrade information on their end to improve or alter something about their network. When this happens, routers have outdated information from the modem. You might want to try power cycling the modem and router. To do this, unplug the power from both the router and modem. After about 15-30 seconds, plug the modem back in. Wait for all of the lights to come on excluding the "PC Activity" light if it exists. Once the modem is registered with your ISP, plug your router back in and test your net speed using a site such as:
http://www.speedtest.net
If your service is back to normal, then you're all set. If it isn't, you may want to contact your ISP as there could be something wrong with the route traffic is taking from the node to your residence.
Mar 05, 2009 | Trendware TRENDnet TEW-452BRP 108Mbps...
Low outgoing internet
If you are experiencing slow speed while connected to a router, there are a number of things that can cause that problem.
If its the router causing the problem it could be a bad router, or a setting on the router.
1.) first thing i would do is a traceroute to google.com so from a command prompt type tracert google.com and see if your few hops are high. if they are when the router is connected but not high when the router is disconnected, then we know its something with the router.
log into the router's configuration.
2.) on some models you can change the MTU size.
3.) make sure your not filtering any ports that you need such as 110, 25
start with those 3 steps and let me know how that goes.
Feb 20, 2008 | Trendware TEW-452BRP Wireless Router...
Linksys Routers and Microsoft PPTP
Microsoft uses IP Protocol 47 [GRE] for this secure tunnel. Provided that the PPTP Pass Through is set to Enable on the Router's Filters page and port 1723 is forwarded to the VPN Server, the Router will allow authentication and remote access into your network. The router will also allow you access remote PPtP networks from behind the router providing the PPtP Passthrough is enabled on the router.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Trendware TEW-452BRP Wireless Router (TEW452BRP) Logo
426 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
alex metro
alex metro
 Mike M
Mike M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
