Question about Intel inside Pentium 4 P4 System Case Sticker (718256397194)
My pc automaticaly shutdown ? - Intel inside Pentium 4 P4 System Case Sticker (718256397194)
  • Intel Master
  • 27,725 Answers
If the PSU power supply units fan is not working the PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Posted on Oct 29, 2012
Hp com ergo
If you remove the battery driver from the device manager, it will reinstall a non corrupt driver when you re-boot.
May 10, 2013 | HP Pavilion G4 G6 G4-1000 Series...
Dell optiplex 780 shutdown automaticaly
The desktop could be overheating and shutting down.
To fix this problem, please click on this link :-
Apr 14, 2011 | Dell OptiPlex 780 MT Desktop Computer...
My hp compaq nx9010 sometimes shutdown on windows logon. moreover, automaticaly shutdown during xp installation. please help me.
could be overhating problem but more likely power supply not putting out enouph watts to carry the load it takes more cpu usage and power tho run windows and apps then it does to run cmos/bios
Sep 02, 2010 | HP Computers & Internet
When i shutdown my notebook it'll automaticaly turned on. why should i do?
Your motherboard's BIOS may need updating.
1. Plug in AC power adaptor
2. Log in as the Administrator.
3. Download the latest XP BIOS update here.
4. Run the 14cn67ww.exe program
5. Run the flashxp.bat program and wait for the computer to restart automatically.
NOTE: Do not remove the AC adaptor or turn of the computer.
May 30, 2010 | Lenovo IdeaPad S10e Netbook
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
I cannot connect to my wireless. The communication problem says Cannot communicate with www.microsoft.com(207.46.19.190)
hi u do not tell about ur os ok,
reset ur ip address as automatic,
step- my network places _view network connection_right click on wlan _properties_select internet protocol_properties_obtain ip.....Automaticaly
obtain dns Automaticaly.
ok
thanks
Jan 27, 2010 | Acer Aspire 4530-5889 Notebook PC
Emachine wont start
remove all external and internal peripherls.
example for external: mouse, monitor, keyboard, printer.
Internal: hard drive, memory modules, video cards, modem (if there's any), optical drive or dvd drives.
just leave the motherboard, power supply and processor intact, try turning on the computer with out those components mentioned. see if you get a beep sound before it turns off, but if not the most logical part that needs to be replaced on this type of problem is the power supply if that doesn't work the next thing to do is replace the motherboard. hope that helps
hit me back on the results. thanks!
May 25, 2009 | eMachines T6211 PC Desktop
AcerPower 1000 keeps shutting down
you mean the computer power off automaticaly.
check the all cable of mother board.
Jan 21, 2009 | AcerPower Sn PC Desktop
SHUTDOWN RATHER THAN RESTARTING AND STOPED AUTOMATICALY
need to replace the coaxial cable or Update this handset recommended to go service center of i-mate for fixing because is hardware issue or check the site www.clubimate.com
Feb 11, 2008 | i-mate JASJAR Smartphone
Fujitsu siemens notebook automaticaly shutdown
hi, do you mean that the notebook does not power on at all? in that case, first check the BIOS lethium battery, it must be dead, replace and let me know..
Jan 06, 2008 | Computers & Internet
Computers & Internet Logo
69 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
