Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with EZ-Change Ice and Water Filter
Whirlpool refrigerator model EDsPHEXNQ00 22SSa
How to remove bottom front grille
jyackle5
  • 8197 Answers
SOURCE: Trying to remove the water filter and front grill
To change the filter rotate counter clockwise. To remove the grill at bottom grab bottom lift up and out. also here is the manual.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=ET1FHTXMQ04&siteCd=WHRCOM
Good Luck and please rate FixYa!
Posted on Apr 11, 2009
Maytag317
  • 1136 Answers
SOURCE: location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
Posted on May 17, 2009
  • 396 Answers
SOURCE: Whirlpool refrigerator model#WRT-75680. Have
Assuming the freezer is adequately cool, it sounds like the freezer fan is not running. This fan transfers chilled air to the refrigerator section. The fan should be located behind an access plate in the freezer. If it's running, you should be able to hear it. If you can't hear it, remove the access plate and look at it. If it's not turning, you will need to replace the fan motor.
Posted on Oct 16, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool side by side refrigerator laeking form
It sounds as though your filter which screws into the front at the bottom kick plate is bad . The rubber seals on them tend to go bad causing them to leak into the drip pan and causing it to overflow . This will appear to be a leak when in actuality , all you need to do is replace the filter .
Posted on May 29, 2010
heatman101
  • 43501 Answers
SOURCE: How do you remove the
Grab it firmly on both ends a pull hard towards you...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 05, 2010
How can I lock the wheels?
Hello Anthony;
My name is Peter. I am a retired field service refrigeration technician.
Whom ever installed your refrigerator did not do a good job.
You did not provide a model number which is located on a label in the liner inside your fresh food section.
1.) You have a bottom grill or toe plate in the bottom front of your refrigerator. Remove this. It is held in place by either a fastener screw one on each side or clips about 2" in form each side. Either remove the screws if you have them or just pull on the bottom grill straight out to remove it.
2.) Generally you have two leveling screws one on each side of your refrigerator. Turn them clock wise to raise the front end of your refrigerator. You want to raise them to the point where you hold the doors open half way and the backward tilt will close the door without you shutting it.
Get back to me with the model number. There are several other locking and adjustment mechanisms, if I have guessed wrong.
Mar 06, 2016 | Whirlpool Refrigerators
I need to clean the grill in hotpoint refrigerator. When I hope the door to the freezer there two screws hold down grill.The refrigerater is model No. HTS16HBMBRCC HOTPOINT
General Electric (GE) Profile refrigerators have a grille on the bottom of the front of the refrigerator. The grille allows air to be pulled from the kitchen into the lower compartment of the appliance by the condenser fan, which cools the refrigerator's compressor. At times this grille must be removed, such as when you are cleaning the compressor, emptying and cleaning the drain pan or adjusting the refrigerator's leveling legs to level the appliance. The grille is designed for easy removal: It is secured in place using only two screws
  • 1 Open the refrigerator doors to at least 90 degrees.
  • 2 Remove the two Phillips screws securing the grille to the cabinet. They are at the top portion of the front of the grille.
  • 3 Pull the grille away from the front of the cabinet to remove it.
  • Phillips screwdriver
    will be needed
    Dec 21, 2014 | Hotpoint Refrigerators
    How do you clean the refrigerator coil on a whirlpool side by side model #ed5kvexvb00.
    condenser coil ? remove bottom grille use long condenser cleaning brush available at most hardware or bldg. supply.
    Dec 10, 2010 | Whirlpool ED2GHEXN Side by Side...
    Whirlpool ref model #ED5PVEXVS00, need filter for this model. We don't know the part number needed or where on the refrigerator that the filter is located. Please help with both
    The original part number is 4396841; cartridge T2RFWG2. The filter fits into the grill at the bottom of the refrigerator (nearly centered on the left hand side of the grill). There is a cap covering the filter.
    The fridge can be used without a filter if the cap is taken off the old filter and put back into place. For a diagram that includes the filter and grill location see: http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0812046-00001.png . The filter is part 30 in the diagram. The entire set of parts diagrams, leading to parts list and prices are available here: http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-ED5PVEXVS00/1198/0165000 .
    Another on-line source for the filter is: http://www.partstore.com/Part/Whirlpool/Whirlpool/ED5PVEXVS00/Whirlpool/Whirlpool/4396841/New.aspx .
    I hope this helps.
    Nov 20, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
    Water filter won't come out when I push the button
    Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
    Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
    How do i remove the drip pan from under my whirlpool side-by-side
    they are permanently afixed on the newer models. older ones remove the front grill(pull straight out) it is on the left side
    Jun 11, 2009 | Whirlpool GD2SHGX Refrigerator
    Apr 11, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
    Whirlpool Gold. Front grill won't come off.
    when you remove this grill it feels as if it will break before coming off. the trick for removing it is to grab in the center near the bottom and then pull up and out. it will flex alot and feel as if it might break put it will pull loose from the clips on either end. open the doors when removing it to give you plenty of room.
    to reinstall line the 2 "c" clips on eihter end with the with the reciever clips on the unit then push into the clips.
    the grill will not break if done this way. message me back if you have nay further questions thanks Peyton
    Feb 23, 2009 | Whirlpool GS6NBEXR Side by Side...
    Bottom grill
    All of the bottom grills are removable. They snap in very tight and I always worry that Ill break it. They push into a clip on each end. On the Amana they instruct to pull out from the bottom on each side. Suggest looking for user manuel on web for your simular model for specific instructions!
    Jan 09, 2009 | Whirlpool GS6NBEXR Side by Side...
    Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with EZ-Change Ice and Water Filter Logo
    313 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
