LG42 LD520screen doesn't show nothing only blue color. help please.
LG42LD520 SGREEN SHOWS ONLU BLUE AND NOTHING ELSE, AND CAN'T TERNING ANY CHANELS ANY BOTOMS.WHAT IS IT? PLEASE HELP. THANKS.
Posted on Oct 30, 2012
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: I have 42HDX82 Projection TV.
Do you mean like ghosting/ shadowing image where in you see rainbow colors behind the image? If yes then this is a convergence amp problem and is usually an expensive fix. Not 400 though but usually costs about 250$. I can get you a list of techs in your area so that you can call them and see if anyone can quote a reasonable charge for the fix. If you can just get me your zipcode, I can do that for you. If you are good at working on electronic circuits and have some soldering skills, I can help you do this yourself?
Posted on Jul 29, 2011
Nokia 5130 switch on problem
remove switch.
and short switch point to ( - - ) & ( + + )
u can on your cell without switch
Jun 23, 2013 | Nokia 5130 Cellular Phone
I have colour problems with my webcam! it doesn't show the colours properly, for instance, my blue shirt appears purple.
you might try to adjust your color profile through windows control panel,display. or when you open the control panel search for color profile
Dec 01, 2012 | A4tech A4-PK333MB WEBCAM 1.3M
Does anyone know why my mic doesn't work and my desktop background doesn't show?
If you have Windows 7 Starter then you are limited on changing the background.
Jun 09, 2012 | Computers & Internet
Please help me,, the inks in my printer are finished & i replace the black color only,, after that i tried to print a text with a black color & it dosen't print,,it show a message...
Color laser printer require that all four cartridges have toner even if you are just printing black. You will need to replace all of the cartridges that are empty before you can print anything.
I hope this helps, if so please rate my solution.
BuddyMc
Sep 20, 2011 | HP Color LaserJet 2600n Printer
My Break, ABS and Trac warning lights all come on at the same time. I can shut the engine down and restart the issue goes away. I t seems to be happening more frequently. My mechanic found nothing wrong...
Nothing wrong. Doesn't that seem strange to you
The ABS & Trac came on because that system has issues
There may be stored data, if not a code present
The mechanic has to component test to find the problem
These guys spend too much time with a scan tool & I
think some of them are waiting for it to tell them something
Doesn't work that way. If everything goes as it should, the
scanner shows what the computer sees,that's all,& that can
be a lot,but you have to move on & use different skills that
not everyone has learned yet apparently
Try another shop
That really isn't a diagnostic test etc,just looking at data
stream,if they see nothing out of range they quit
That doesn't help you any,the problem is still there,intermitent
maybe, but there.
Jun 26, 2011 | 2001 Ford Windstar
Console says replace belt unit even though I have minimal copies on the printer. Dell 3115 color laser
Hi
Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. Y?? ??n reset ???r Dell printer by using 'Reset Dell Printer' icon. Y?? ??n g?t t? th?? icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer. Hope this helps... Please post back if you need more information.
Daniel
May 28, 2011 | Office Equipment & Supplies
It not bringing out color.it showing black and white
HI,
I will need some clarification as to the model number of your projector to best help you but in general if you have a DLP type projector & suddenly lose all color to your image then the color wheel has failed by burning out or breaking. The color wheel sits directly in front of the projection lamp & if you take your lamp out you can use a flashlight & point it in towards the spot where the light comes out of the lamp & look at the color wheel. The color wheel has 4 to 6 different color pieces called segments like yellow, red, blue & a clear segment. You will be able to see if the color wheel is broken.
If it is you need to have the unit serviced. If you're handy you may be able to order a new color wheel. They are usually around $100. There can be other causes as well but the wheel is the first place to investigate. Please let me know if this was helpful.
Thanks & good luck,
Jim
Apr 14, 2011 | Acer Office Equipment & Supplies
The dark color of my tv was change unspected the dark color now are blue, violet,and other exept black, the dark scense can't see. please help me.
I believe you either have a bad LCD Controller Board or a bad Main Board. The only way to know is to replace one. If it doesn't fix it , replace the other. Or replace both and it should be fixed.
I hope this helps,
Skyassoc
Nov 03, 2009 | Sharp LC-42D43U 42 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
