Question about Cannondale F6 C02
Handlebar adjustment cannondale - Cannondale F6 C02
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: i'd like to raise my
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
Posted on May 28, 2011
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
Handlebars allen
If you are asking what size Allen wrench you need to loosen/tighten the handlebars, you are most likely looking at a 5mm. In rare instances, it could be a 6mm or 4mm. As a cyclist, those three sizes are good to have as they correspond to 90% of the bolts on your bicycle.
Nov 10, 2013 | Cannondale F7 CO2 Feminine
Move saddle forward
Undo the fixing bolts and the saddle will slide forward
Make sure to tighten it up
Mar 04, 2013 | Cannondale Cycling
I'd like to raise my handlebars a little on my cannondale f400.
May 27, 2011 | Cannondale Cycling
How to change head set also replace front fork?
Loosen clamp at top of bike frame where seat slides in ...twist seat back and forth while lifting upward.......To remove ft. fork ..At handlebar assy.remove allen bolt..(some are hidden by rubber plug)..remove handlebar assy/remove large nut at top of frame where handlebar slides down in..
...twist and pull to remove front fork....some have upper and lower nut depending which bike.
Feb 27, 2011 | Cannondale Jekyll 600
Will the cannondale xc3 mtb stem fit on my lefty headshock? And how do I do it?
the XC3 stem comes in a 1.5 in clamp designed to fit on cannondale headshox systems. The lefty fork you have may or may not be compatible, you would have to check your fork to see if it is the right size.
There is an XC3 SL conversion kit for lefty forks that are not the same size and includes the stem and steerer replacement.
Swapping stems is quite easy on the cannondale. Loosen the two bolts holding the stem to the steerer and undo the bolts holding the handlebars, remove stem and replace.
If none of this makes sense then I would strongly urge you too take the bike into your local bike shop, preferrably a cannondale dealer, and have them show you. It will take only a couple minutes and they can confirm compatibility.
Jan 06, 2011 | Cycling
Adjust the handlebars
Loosen the handle bar clamp using a 5mm allen wrench.
Aug 16, 2010 | Cannondale Cycling
Mountain bike advise
sounds like a pretty good bike for what you will be using it for
Oct 22, 2009 | Cycling
Clutch cable adjusters
Bowden cables like your clutch cable work on the law of the lever. Think of lifting up a heavy weight hanging on a rope using a lever balanced on a fulcrum. The rope is in tension and the fulcrum is in compression. To adjust the point of lift you could either vary the length of the rope or adjust the height of the fulcrum. The outer sleeve of your clutch cable is made out of plastic-coated steel, square-section wire and is resistant to compression forces along its length. This outer sleeve works as your fulcrum and, because it is flexible, lets you put it where it is needed - at the end of your handlebar. The cable inner is like the rope in the lever example and resists only stretching forces. It is threaded down through that snaking fulcrum back to where control movement is needed. The cable adjusters let you fine tune the length of the fulcrum, and therefore the lift range of the inner cable.,,,
Nov 10, 2008 | 2002 Cannondale C 440
Cannondale F6 C02 Logo
44 people viewed this question
Top Cannondale Cycling Experts
Charles T Nevin
Charles T Nevin
John Egan
John Egan
Are you a Cannondale Cycling Expert? Answer questions, earn points and help others
