Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
Screen flickering My Sony has recently began to flicker. Not a constant flicker does it at random times. only noticeable with a bright picture/video. Bulb was replaced about 6 months ago and minus the flicker its still as bright as it was when I bought it, so I don't think its my lamp.
    Top Expert:
  • Sony Master
  • 14,553 Answers
A number of possible reasons--from brightness/contrast set too high to a issue with the power supply of the set--a expert would have to examine the set--you might want to call Sony to see if known issue with this model.
Posted on Oct 30, 2012
  • umbrewolven
    umbrewolven Oct 30, 2012
    I did have my contrast set pretty high but it still flickers even at a lower setting.
  • umbrewolven
    Power supply was replaced not even a month ago, referb from ebay. Optic engine was replaced from a different set out of the same model, no issues with that. I'm thinking it may be with the control board or the one that controls the LCD's, The lamp itself is not flickering, I confirmed that today.
3 Suggested Answers
  • 336 Answers
SOURCE: Sony KDS-50A2000 - bulb replaced but picture still yellow
Hi,It sounds like a light engine problem Sony is having.Basically the light of the lamp goes through tunnels that have mirrors that direct the lamp to 3 main LCD chips,These 3 LCD chips are blue,green, and red they blend to create the image and colors.When they start to fail you'll get color discoloration like what you are getting.You will need to replace the optical block because unfortunately they don't sell the LCD chips by themselves.GOD BLESS YOU!
Posted on Oct 06, 2009
  • 126 Answers
SOURCE: blue haze and dull yellow patches on screen
The light engine in your set has gone belly up. It is a very expensive repair. Good news is that on a whole bunch of models like yours Sony has extended the waranty on the light engine. Check with a local authorized Sony service center and give them the model & serial number and you might get a free ride. If I were a betting man I'd take odds on 'you're in luck'. LOL
Posted on May 28, 2009
Why my light status indicator next to the battery About the hard disk is not blinking anymore?
the indicator shows the activity of the hard drive - heavy constant use is a solid bright indication down to none when idle with various level of illumination and flickering at all times.
Aug 30, 2014 | ASUS K50IJD2 Notebook
Kdf e50a12u powers off
It might be the ballast or the heat sensor in the light chamber.
Jan 05, 2014 | Sony KDF-E50A12U 50" LCD HDTV
I have a 52 in. Sony HD ready rear projection tv and recently sometimes and I say sometimes because this happens randomly but the screen begins to flicker a green tint and then it shuts itself off and the...
Some of the early sets had this issue--they had bad picture tubes and set will turn rather bright red, green or blue and shut off.
The tubes for those sets (what model do you have?) are no longer available.
There may be a simple way to resolve this at least for some time depending on the model number--it will require no parts replaced and only a screw driver to adjust something in the set.
Jun 13, 2012 | Televison & Video
Picture getting dimmer (?)
Hi, yes it`s time to replace the lamp, and remember to turn maxxed out brightness to normal once you replace the lamp :) good luck, video-tek
Jun 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
TV turns off after a few seconds
it could be the bulb on the way out, they don't like to turn on if the inverter does not get a voltage use from the bulb, while trying to turn on the tv look at the vents for the bulb if you see it flicker on and of while trying to turn on the tv when it would be the bulb. when the tv is on and work hold a peace of paper over the vent not to cover it but to look at the bulb light if you see a flicker or bright and dim and repeats doing this then the bulb is warn out. if you hear clicking or scratching sounds this could be the inverter board on it way out.
Jul 03, 2017 | Samsung TX-R3080WH 30" TV
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Do I need a lamp/bulb?
Hi, Yes this is what you call a burn in , sence the part of the screen was blank out for so long the rest of the screen used slowly burt in, depending how bright your setting was place at, this is also the same affect when people keep there tv on the same chanel were there is only wrigting and no movement or video game or famous for that. It wouldn't be the bulb , they only project light,
Regards
What About Bob
Feb 25, 2008 | Sony KP-51WS510 51" Rear Projection...
Flickering and freezing of picture for a split second
The most likely problem for image problems and flickering is the lamp (23311083A). I found it at PartStore.com for about $180. Hope this helps.
Nov 11, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
148 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
