Question about Car Audio & Video
I have a Rockford fosgate P4004 with two 12'
    Top Expert:
  • Car Audio & ... Master
  • 34,814 Answers
I think you are right about the "fried" part. It would have to be opened up and repaired to be able to use it again
Posted on Nov 13, 2012
  • Daniel Wright Nov 15, 2012
    I found out that 4 of the transistors blew out. I would repair it myself but its a pain in the *** trying to get them off board (I've tried plenty). I may just sell it dirt cheap and probably let someone else fix it and enjoy it
  • Tom Chichester Nov 16, 2012
    Ah, but it was fun while it lasted...
  • 637 Answers
What is your question?
A thumbs up would be greatly appreciated if this answer is helpful to you. I have a Rockford fosgate P4004 with two 12' - rockford-fosgate-p4004-two-12-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Posted on Dec 19, 2014
2 Suggested Answers
SOURCE: Rockford P550.2 going into protect mode
Have you tried using bigger gauged wires? If the amp can not pull enough power through the wire it can cause it to run into protected. This solved my problem running a 2000W amp on 12 gauge wire, went to 8 and it worked great.
Posted on Nov 14, 2008
I have 2 15"L3 kickers and I'm running them with a Rockford Fosgate T1500-1bdCP what should how do I tune my amp and speakers
turn down the gain until you can go full volume without distortion.
crossover frequency is always up to the user.
Feb 07, 2015 | Rockford Fosgate Car Audio & Video
How to wire kicker 07cvr124 4ohm duel voicecoil 12in sub to my rockford fosgate 4channel punch 600r amplifyer
run the positive from one voice coil the the negative on th other than take th left over positive from one voice coil and the negative from the other and bridge it to the amp use the blue sub wire but u will have to buy a 1 unto to splitter to hook up ur rcas from amp
Mar 28, 2012 | Rockford Fosgate Car Audio & Video
I had Rockford Fosgate P300-1 Amplifier installed professionally with a Kicker CVR10 10 in Subwoofer in 2010 Comaro. My problem is that it causes an odor in my car. I took it back to Mothers window tint...
your kicker cvr subwoofer should have a max power of 1600 watts therefore your amp is not too much for the sub because the p300-1 amplifier has a max output of 900 watts. if anything your amp would not be enough to produce max power out of your subwoofer. your sub should not produce an odor unless you have your amplifier bridged which doubles the watts pushed to your subwoofer and if that is the case your amp is pushing 1800 watts to a 1600 watt sub which could be causing it to fry or possibly blow soon. other than that if thats not the case there shouldnt be a problem.
Dec 31, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
What number of cable should use on rockford fosgate 1 farad capacitor thanks
If good brand name wire, jl rockford monster kicker, the 8 gauge wire will be fine. if buying it at walmart or somewhere, then use 4 gauage wire
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
Is a kicker zx 2500.1 better than a rockford t2500-1bd?
no way. fosgate is on top of there game right now and is a great amp once again. it will out preform and out last the kicker and i love kicker also but fosgate has this one.
Jan 31, 2010 | Car Audio & Video
Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Help with CVR 12 (kickers) and a Power 1050 s amp (Rockford Fosgate)
Send me your email account and i will draw you a diagram and send it to you there. I will need to know if the ohms of each sub as well as the amp. I'll also need to know if the subs come with one or two voice coils.
Ciza
Nov 04, 2008 | Rockford Fosgate Power 1050S Car Audio...
Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Rockford Fosgate 501bd question
that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
Car Audio & Video Logo
182 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
