Question about Garden
What size belt for victa 4012 tx cutter deck
V belt size
  • 148 Answers
SOURCE: need deck belt size yardman model numbera42707
I would suggest downloading the owners manual from www.managemyhome.com and it will tell you what size belt you need.
Posted on May 19, 2009
  • 133 Answers
SOURCE: belt size
Go to www.sears.com and click on partsdirect. Enter your model number of your tractor (found on a data plate usually under seat). It will take you to the page with your parts diagram. Look for the belt in diagram and scroll down to the appropriate number and it will give you the part number for the belt. You can order it from sears and pay shipping or go to local small engine parts department and give them the part number or you can just give them the model number of your tractor and they can get you the belt.
roundo4
Posted on Aug 13, 2009
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
  • 16 Answers
SOURCE: I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Posted on Jan 29, 2011
  • 130 Answers
SOURCE: i need a diagram on
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Posted on Feb 12, 2011
Who sells replacement drive belts for my ac/dc ge cassette recorder model 3-5025a
Belts for any deck can be obtained from Marrs Communications in TX but if you now the size and width they can also be had cheaper from Consolidated Electronics in OH.
Feb 15, 2015 | Audio Players & Recorders
Replace cutter belt for a Victa Pro 12 ride on
Contact dealership/service center or buy a service manual online
Jan 25, 2014 | Garden
My TX-400 stops working after 7 seconds
Lube the deck belt, this product shut down by enough friction between deck vs deck belt.
2) Lube the roller bearings
3) Adjust the deck belt see the diagram
4) TEST the input voltage motor, if there are the motor need repair.
5) Test the output voltage board, for input in the voltage motor, if there are NOT, the board is faulty.
6) Run the software calibration, for diagnose, troubleshooting.
See my personal TIPS for help too.
sincerely. God bless you.
May 06, 2012 | Exercise & Fitness
I have a problem with my ride on mower. we need to replace the belt that drives a twin cutting disks on a Victa 4013TX but cannot find any diagrams to help.
4013 HT is a Victa with a 13hp briggs and stratton engine normally with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Jan 08, 2011 | Garden
I need a diagram of how the drive belt is put on
4015 HTX is a Victa with a 15hp briggs and stratton engine normallu with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Dec 13, 2010 | Garden
Craftsman 42 inch deck mower. Model 917.277611 (2007). LT1000. 16.5hp Briggs & Stratton. Springs on cutter deck assembly broke. Had to re-assemble cutter deck. Re-attached springs and tension arms....
Aug 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Nov 18, 2009 | Garden
Cutting deck on greenfield evolution mower will not disengage
Usually this is caused by badly worn belt or incorrect type of belt fitted, check allignment, tension, belt size should be marked as A... not 13A..... if marked as the latter it is an "automotive" type belt not suited to "slipping" when belt loosened to disengage cutter. Check also for the belt has not rolled over in the groove.
Oct 31, 2009 | Greenfield Industries Disston #752980 Mm...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
