Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
The glow rod will lite then go dim a number of times then the burners try to ignite but wont stay burning its also clicking when its trying to ignite
    Genius:
  • 1,033 Answers
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Posted on Oct 30, 2012
  • 189 Answers
SOURCE: I have a goodman gmpn 100-4 REVB furnace that will not stay lit
If the igniter lights the burners the ignitor..... is not bad. Its like a light bulb.... it works or ot doesn't.
You are describing a dirty flame sensor. Dishonest contractors will sell you a new ignitor but clean the flame sensor when the are installing the ignitor. It is located at the opposite end of the burners than the ignitor. It has one wire going to it. Remove it and clean the rod with a piece of fine grit sandpaper. this should be done every year before heating season.
Good luck
Posted on Mar 29, 2009
WebTeligent
  • 42 Answers
SOURCE: No heat, trouble shooting light has continious flash.
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Posted on Nov 10, 2007
Accurate Joe
  • 61 Answers
SOURCE: Goodman GMP075-3 ignition problem
Test while the unit is firing with a meter. you should have 24 volts going to gas valve. If you do and no gas is coming out, you have a bad gas valve. You will need a gas pressure test kit to install a new one correctly.
Posted on Dec 01, 2008
  • 288 Answers
SOURCE: Goodman furnace burner ignites then shuts off in about 10 seconds
if you have replaced the flame sensor and it will not stay lit, the draft safety switch may be opening. It works on positive and negative pressure created by the inducer fan motor.You may have a restriction in your heat exchanger or if is a high efficiency furnace, it may not have the drain tube installed properly with a trap. The trap works just like the trap under your sink and if water isnt in the trap, the pressures can be effected enough to open the draft switch(some call it an air pressure switch)
Posted on Jan 07, 2010
atocrxr
  • 135 Answers
SOURCE: My goodman furnace will start to ignite, then it
Another part that you might want to check is the flame sensor. It is a very good chance that this is the problem, the stat calls for heat, the induced draft motor (little motor on from of furnace), ignitor comes on, the main burner fires, just for a second or two, the burner shuts down, the main blower motor defaults to blower on!
If this is the issue;
Then this is what you do to fix it, kill power to the furnace, look where the burners are, to the left side there is a little wire, usually yellow or orange running to what kinda looks like a spark plug, one screw should be holding it to the burner bracket. take it out, at the end of the white porcelain is a small metal rod sticking out, it probably has a slight bend in it.
take some steel wool, or sand paper and clean the rod till is is nice and shiny, NOTE: when you take it out, it won't look really dirty, maybe just like a pencil lead,,,,it is dirty!
Just use the sandpaper and clean the rod till it looks like metal, "do not sand the white porcilen". Put the part back in and turn the power back on and run the furnace as usual.
90 % chance that this will fix your problem.
The rod get a build-up on it from the sulfur that is added to the gas, and has a hard time passing the milli-volt signal back to the furnace computer, which is passed from the ignitor, through the flame, to the sensor! This way the computer knows that all of the burners are firing and it is safe to run!
Please take time to come back and rate me, or contact me with any further questions!
Have a warm day :)
Sincerely,
Paul Gibson
NOTE!!
Do not touch the ignitor! The part that gets bright and hot! Even when it is cold, the oil on your fingers will cause it to burn out.
Posted on May 03, 2010
Arcoliner furnace, model wo451. Where is pilot light located and how do I shut it off?
It may not have one or it may have one thats intermittent, or more likly it has a hot surface ignightor. To see, set stat up with power off and go down by furnace and turn it on. a inducerfan should start, then after a 3-8 seconds, youll here a click. if its a single click you have an hsi and you will see it glow ornge, as it dims, the main burners will light. The hsi looks like 1.5-2 long u shape pieces made from black silicone with a whit porcelen base, Unplug it and set your meter 120 volts and if you have power but the ignighter wont glow, change it. Kill power and remove with one screw. Take to a heating shop and get a peplcement, but DO NOT touch new one with fingers. If it goes click click click multiple times, then watch if it lights a pilot near burner. IF it does and goes out after a few seconds, then clean the other small rod that the pilot hits, and whose functine is to tell the main vavle that, indeed, the pilot is lite, but the sensor isdirty and the iny voltage it produces is not enought to teel the valve,ok. If these fail, and you DO have a standing pilot, one that never shuts off, follow the tiny copper tube from the gasvale to its end at the beginning of the burners. This is a thermocouple and needs to be replaced. Any hardware store has them. Thermocoule, NOT, thermopile. Any other info you beleive to be important to me, teex benthums@yahoo.com Good luck
Sep 14, 2015 | Heating & Cooling
Goodman furnace Model GDS80703AXBB -fan comes on then igniter light comes on, then burners turn on but shut off right away and wont stay lit. Now igniter light wont come on so burners not coming on at...
Sounds like either the flame sensor is not working.
The sequence for starting the furnace is:
1. extraction fan on
2. pressure sensor (for fan)
3. ignitor (spark or glow plug) comes on
4. gas valve opens up
5. ignition of flame
6. flame sensor (or temperature sensor)
7. plenum temp. sensor
8. main fan starts
It is most likely that the flame sensor is dirty or gone,
or (and I hope not), the module is gone and needs to
be replaced.
Sep 10, 2017 | Heating & Cooling
Goodman GMP100-3 home furnace status lite is constant red
check continuity of hot surface igniter....open loop means replace igniter
Nov 04, 2012 | Goodman Heating & Cooling
Goodman heater not igniting, coil does not glow. Do I replace the coil and would that not allow the gas to open if there is no glowing coil?
your correct the gas valve will not open ifnthe glow coil does not ignite the flame which then hits a flame sensor (looks like bent piece of wire usally on the opposite side of burners from glow coil) you can with a long lighter thats is used for lighting a gas grill light the furnace manually that will allow it to run through one cycle only. you must first have the door off to the burner area, have someone else turn the furnace up to when it turns the exhaust blower on. when that blower starts running you have to listen for a click , that click is when you will hold the lit lighter right where the glow coil is, the pilot will light and your furnace will run, providing its only the glow coil that is bad. you may show your ex how to do this and leave her do it for the rest of the winter that would help keep her off your back and you could kill two birds with one stone so they say. if you do get a new glow coil i recommend getting the new style they cost a little more but they are not as fragile, you cant touch with hands or bump the old ones but the new ones take a lot to break and seem to last longer. Good Luck
Dec 29, 2011 | Goodman Heating & Cooling
Gmp075-3 furnace wont stay lit
Sounds like an airflow issue. Is the return air clean? System is not tripping the limit switch with the door off because it's getting all the air it can handle, with door on its not getting enough air???
Aug 15, 2017 | Goodman Heating & Cooling
I have a Goodman Manufacture furnace, model #GMPN120-5. The furnace keep clicking on /off while asking for heat. I even turned the fan to the on position (instead of auto) and the problem continues. ...
Can you tell me if the burners are lighting at all? I need a little more information about the cycle. If the burners are lighting and then going off immediately you need to clean the flame sensor. A small rod on the opposite end of the burners from the glow bar. Let me know if this is the situation, or describe the cycle completely and I will try to help.
Mar 19, 2011 | Goodman Heating & Cooling
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
Goodman furnace seems to be cycling too often. Burner not staying on long enough to put warm air into system. Burner quits after a few seconds then repeats.
dIf the burners are only staying on for about 5 seconds, you proably hav e a dirty flame sensor. Watch the burners light, the glow plug will light one end of the burners, in front of the last burner to light the will be a small thin rod, this rod must sense the flame or the gas will be shut down. Take a piece of steel wool and gently cleqan the rod.
Oct 11, 2009 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
264 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
