Question about RCA Televison & Video
All channels have an overall green hue across the picture tube.
  • 10,594 Answers
I assume it is rear projection TV so want to know how old is this? If it is rear projection Tv then either green gun drive over gain or red and blue are less drive gain. Problem can be set by adjusting Screen Volts of all 3 guns in TV to produce correct white balance for fine colors. If you have no experience of TV repair then ask help by qualified TV tech.
Posted on Jan 03, 2009
    President:
  • 2,110 Answers
U have to contact service center...
http://tv.rca.com/en-us/servicelocator.html
    Master:
  • 505 Answers
Ok turn off tv for 30 minute pull the plug from power point make sure all speakers if any near tv are removed at lease 1 meter away then switch back on after 30 minutes let me know asap how that geo's
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls postback the exact model number.
Offhand, this could indicate that the green is overdriven and drowning the other colors, red and blue.
Good luck and Thank you for using FixYa.
    Genius:
  • 1,199 Answers
It sounds like the red lens in your tv is going out and needs replaced...This is whats causing more green to show up!
What are signs of picture tube going?
Signs of a CRT going old, are bad focussing, unnatural colours and hues of a certain colour (red, green, or blue) if you watch black/white pictures. In colour pictures, black sequences also show hue.
Jun 13, 2014 | Panasonic CT-32SL14 32" TV
Is it dead?
Check its video output card for any loose solder terminals. This card can be located at the base of the picture tube, directly plugged on to it. Check all solder terminals here. It is a best practice to resolder all the suspected solder terminals, by applying a little more fresh solder. resolder all the CRT base socket solder terminals too. If the solder terminals that connect the filament of the picture tube got loose soldered, this kind of fault can occur intermittently.
Jun 22, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
How do I replace the blue tube and is it worth the cost?
Hello, It has been my experience that once you replace any one tube of a CRT projection tube TV, the CRT that has been replaced will have more emission and it will reflect in the picture quality, I mean that there will be more definition, brightness, contrast in the blue images in the overall picture than the red and green, it will also show up as excessive in the overall gray scale adjust.
Oct 21, 2010 | Sony KP-65WV700 65" Rear Projection HDTV
Looks like 3D tv
Try doing a calibration. Projection TVs work with 3 picture tubes (Red, Green, Blue). The Red may be off to one side causing the hues.
The manual is available here for instructions on how to perform calibration:
http://www.retrevo.com/samples/Hitachi-manuals.html#Projection%20TV
Apr 06, 2009 | Hitachi Televison & Video
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Blurred TV - double vision with red hue
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
Sep 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Hitachi 61SDX01B
The problem is called green geometry.There is nothing wrong w/the green pix tube.It is critical to get the green geometry
accurate because the red and blue convergence overlays on
the green.If you have more than an alignment issue,that will need
repair before adjustments are attempted.
Oct 15, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Green, Green
Have tried to see if you can hold of a colour profile from epson for the machine? This could make a difference.
Oct 12, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
