Question about Xerox WorkCentre PRO 128 Copier
Error occerred coad 041-366
A error occerred coad 041-366 xerox printer model all in 1 5230
2 Suggested Answers
  • 129 Answers
SOURCE: In Xerox work center 7345 error coad 0004361 plz give me clearance of this
That error is a drum motor failure. It can be either a seized drum or a motor. Remove drums and enter diagnostics and test the motor first. If that passes put back in one drum at a time and then run the test after each one to identify bad drum.
Posted on Jan 12, 2016
Jan 12, 2016 | Xerox Office Equipment & Supplies
I have workcenter c450 machine the coad comes in this machine the coad number -04-361
Nvram recovery card to initialize the nic if you don't know how to do this you're better of hiring a tec, it will be cheaper and you won't break the printer. 11_6_2013_4_52_15_am.png
Oct 08, 2013 | Office Equipment & Supplies
Error 004-341
fuji xerox 2240 eror coad 004 -341 solutin plz help me
Aug 01, 2013 | Xerox DocuColor 1632 Laser Printer
Xerox 432 erar coad
printer is not ready to copy
Sep 09, 2010 | Xerox WorkCentre 432 ST Copier
Xerox docucolor 1632 fault code: 004-341 the printer doesn't print at all
Try reseating the waste toner then all 4 drums, see if the chips are mating.
Most likely either the machine software is corrupted and needs to be reloaded, or the MCU board has failed, could also be a bad laser, called the ROS.
Jan 02, 2010 | Xerox DocuColor 1632 Laser Printer
Error 4and 3
epson dfx 8500 error coad 4and 3 the power supply was dead .
Apr 29, 2009 | Epson DFX-8500 Matrix Printer
Change ink cartradge 11ER00670, same error after new cartradge.
SYSTEM NEED TO BE RESET, CARTRIDGE MAYBE DEFECTICE, THE SWITCH MAYBE A PROBLEM, GO ONE LINE AND SEE IF ANYONE ELSE SEEN THESE TYPES OF PROBLEMS, GO ONLINE AND TYPE:
XEROX PHASER 5500N LASER PRINTER CARTRIDGE ERROR 11ER00670
ENTER
IF THAT WAS THE ERROR NUMBER YOU HAD
OR
XEROX PHASER 5500N LAZER PRINTER CARTRIDGE ERRORS
ENTER
OR
XEROX FOREM GROUP
ENTER
OR
MANUFACTURE NAME,MAKE,MODEL, DRIVERS AND SERVICE MANUAL
ENTER
ROD
Feb 09, 2009 | Xerox Phaser 5500N Laser Printer
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
Nov 12, 2007 | Tektronix Phaser 860DP Thermal Printer
Xerox WorkCentre PRO 128 Copier Logo
282 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
