Question about Canon i860 InkJet Photo Printer
My printer just feeds paper, sometimes it prints
When I pay bills online, I can print a summary perfectly. When I try to print from e-mail or word document, it doesn't engage the printer - it just feeds paper through.
  • sheltojo Jan 14, 2009
    my printer prints some Word documents clearly and other Word documents it prints very faintly (you can almost can't read it)
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
Paper is jamming as soon as the paper gets in halfway through tray 1. its a pamphlet sized paper and i have changed the seeting on the printer. tray 2 works perfectly but since the paper i need to print on...
Sarinana
Hi
The problem is with the size you are about to print. Try to use the paper in landscape then Portrait as this may solve the problem. As the paper sensor in the printer is in the middle of the feed assy. and sometimes it may not detect the paper correctly. And also try to use the size as A4 but make the changes in your software you are printing from.
Hope this will solve the problem.
DO RATE MY SOLUTION
Regards
Jun 29, 2011 | HP LaserJet 2420 Printer
I try to print and the printer just prints the first of several pages and the online/error red led comes on.
Try to pull the paper tray out and clean the feed roller inside with alcohol or water.Usually,paper dust on the feed roller causing it to slip during paper feed and printer jams.
Oct 08, 2009 | Samsung ML1740 Laser Printer
I get a series of blinking orange lights and a green pause.
Hi Mike, the paper feed switch doesn't feed paper... it switches the paper source from the top feeder to the bottom tray. Do you have paper in both? How many times does the orange light flash in between the greens? That tells the error.
Jul 14, 2009 | Canon i850 InkJet Photo Printer
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Paper feed grabs more than one sheet
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Apr 21, 2009 | HP Hewlett Packard Officejet Pro L7680...
Tally 2280+. While printing, goes offline and displays paperjam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Dec 29, 2008 | TallyGenicom 2280 Matrix Printer
Can't print labels
I found out that each time you print from the manual load tray, i.e. letters and labels, once you have the paper in the manual load tray press print and then press the demo button to start the manual feed. I hope this helps.
Aug 28, 2008 | Samsung ML 1430 Laser Printer
Print from MS Word 03 & e-mail to P2015dn trouble
This could be due to incorrect paper size. We have letter as default paper size in the driver, however, A4 paper size into the application.
Please try the latest drivers (Universal Printing Driver) from www.hp.com/support/ljp2015
- Nikhil
Apr 14, 2008 | HP LaserJet P2015dn Printer
Printer Feed Problems
paper too thin 80gsm is too thin..try100. hope it solves your problem...did mine cheers derek
Mar 27, 2007 | Epson Stylus Color 1160 InkJet Printer
Canon i860 InkJet Photo Printer Logo
49 people viewed this question
old marine
old marine
