Question about Cycling
Need the illustration for gooseneck assembly for FreeAgent freestyle box
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
Is it standard or is it the one with the 2 cables a few round bits that allows you to turn the handle bars 360 without traping cables ?
Posted on Oct 30, 2012
Raising handlebars
There is a single central connection to the handlebars This is called the "gooseneck". (Ther handlebars slide through the goosenect and then the gooseneck is tightened to hold the handlebars. The connector to tighten is in the front (so you do not get "injured" if you have a collison). Loosten the connector (it may be allen, or perhaps hex nut.). Raise or adjust the handlebars, then tighten. Make sure it is really tight (do not strip the threads). The handlebar has serrations to lock on to the gooseneck so the handlebar - gooseneck bolt will have to be loosened quite a bit to allow the serrations to "jump" to the next serration.
Sep 20, 2014 | Trek 7100
Remove gear shift assembly
There will be 4 bolts on top of the gear box that fix the gear selector turret in place . Remove any trim and rubber boots to get to these bolts . undo them and lift the gear lever ass. out of the box.
Mar 23, 2014 | 2007 Ford Freestyle Limited
Brake rotor removal
you shouldn't need any special tool all you have to do is remove the caliper assembly of the rotor and the rotor should come right off. If not then the rotor should come off if a there is a nut holding it on there
May 10, 2013 | 2005 Ford Freestyle
How to replace front wheel bearings on 2005 ford freestyle
The front wheel bearings are replaced with the entire hub assembly, we don't have the exact model info but we do have access tot he Ford Explorer instructions, which are pretty much exactly the same procedure with minor differences. Bolt torque on the new hub nut is 285 Foot pounds, you do need heavy duty tools as you will see.
Oct 15, 2012 | 2005 Ford Freestyle
Ford freestyle sel 2005 brake lights not working, the turn signals go faster then normal inside the vehicle, as far as i know the blinkers in back don't work either. looked at the fuse box and seems...
Generally when the turn indicators blinks really fast it means that the bulb has burnt out and needs replacing. I believe that they are dual filament bulbs in the back meaning that the stop/turn/park light are all in one bulb. In order to gain access to the bulbs you'll need to remove the tail light assembly. You will have to open the rear hatch and on the bottom by the taillight you should see two screws. Remove these screws and pull the taillight out and disconnect the electrical connectors. Next you will have to remove the socket. To do this just turn it,counter-clockwise I believe, slightly and it should pop right out. Replace the bulb and reinstall and you should be all set. I hope this helps you out.
Mar 09, 2011 | 2005 Ford Freestyle
Cannot set the time on a freestyle 40403 Cortez women's watch.
go to the website "www.freestyleusa.com/support/"
You will see a box labelled "Freestyle Owners" and this contains "get instructions"
Select your watch and download instructions.
Jan 05, 2010 | Freestyle Cortez Mid Watch Purple 40403
'05 Freestyle Heater/AC blower only works on high(4). How do I get at the switch or blower motor. Everything is plastic! Does anyone have a solution? Thanks, Bob.
here is what my book says:
Blower Motor Speed Control To Remove:
  1. Remove the right lower instrument panel insulator.
  2. Disconnect the electrical connector from the blower motor speed control.
  3. Remove the blower motor speed control mounting screws.
  4. Remove the blower motor speed control.
Jul 06, 2009 | 2005 Ford Freestyle
Front fork too narrow to fit tire
sounds like the box may have been squashed. send it back to where you got it from or its not that hard to spread the forks apart by pulling them. used to do this all the time when servicing mountain style bikes that have been thrashed by customers :)
Jul 06, 2009 | Razor Fz 2000 20-Inch Freestyle Bike
Need to replace tailite on a 2006 ford freestyle
open up the hatch just inside remove the panel there should be 3 or 4 10mm bolts you take off and the assembly should be free
Jan 22, 2009 | 2006 Ford Freestyle
Cycling Logo
273 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
