Question about Canon ImageRUNNER 3570 Copier/Printer
Canon ir 3570 machine shows finisher can not be used
Finisher does not work properly
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
SOURCE: Canon ir 3570
Can anyone pls let me know the procedure to scan a document using Canon IR3570?
Posted on Aug 01, 2008
  • 117 Answers
SOURCE: Error code E602-0001 on Canon IR 3570
your canon image runner Imagedrum problem
Posted on Oct 08, 2009
canontech
  • 1219 Answers
SOURCE: canon ir 3530
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Posted on May 04, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
C3852 error code
Fusing code I. the fusing unit is not warming up to the proper temp. Open the front to the right below where the cleaning clothes are kept there is a cover at about 45 degrees have to get on the ground and look at it there is hole small screwdriver to push the small switch to reset the machine for tha code it will not reset by powering off than on or closing the door.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 10, 2014 | Konica Minolta bizhub C450P Laser Printer
Canon ir 7105 displaying finisher cannot be used
finisher cannot be used this message is show
Jun 09, 2013 | Office Equipment & Supplies
CANON ir 3530 finisher error
canon ir 3530 shows finisher error (displays spanner)
Nov 10, 2012 | Canon gpr-16 ir 3530 blk...
Sir I have Canon IR 2870 a few weeks later machine shown Error 000007-000. I changed the fixing film but machine showing error again why
Sir I have canon 2870 machine. The machine giving the finisher problems, when starting the finisher going down. The machine showing the problem E540. Please kindly solve
Feb 22, 2011 | Canon ImageRunner 2020i Copier
What it a finisher for canon ir 2520
it is the "device" which is mounted on ir 2520 or any other copier, with purpose to stack, collate or staple the copies. :-)
Hope that helps!
Jan 10, 2011 | Office Equipment & Supplies
Ir4570 message: finisher cannot be used help me pls.
Dear colleagues,
I have Canon IR 3045, is giving the following message "finisher cannot be used" is there any solution to reset the message.
Many thanks for any assistance.
Boualem
uae
Sep 16, 2010 | Canon ImageRUNNER 3570 Copier/Printer
I have this machine Canon IR 7105 B&W
Odds are is that the finishers exit bins got stuck while looking for it's HP. Most of the time it is a garbage can.... Move the object blocking the path of the exit trays first. Then turn the power switch for the finisher off first then turn the main power switch on the right side of the copier. Once it is all off > turn the finisher back ON first then the copier and then remove the paper jams.... Good Luck
Apr 24, 2010 | Office Equipment & Supplies
Canon IR 7095
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Jul 28, 2009 | Canon imageRUNNER 3570 Copier
I have a canon machine ir 3035,when ever you switch the machine on it says set the finisher as far as it can go which i did but its still persisting could you plz tell me what to do thank you
the problem cause could be the machine detects that the finisher is not positioned properly if you can detached the finisher from the machine check a hole in the finisher that match a protrusion from the machine , it pushes an interrupter to tell the machine that a finisher was in the correct position. to check fold a small piece of paper and push in to the hole( while the finisher is detached) check the display panel, hope this will help
Jun 22, 2009 | Canon Office Equipment & Supplies
Inserting staples
If the machine has an in-built finisher, the stapler is located in the rear of device. Pull the finisher release handle and pull the finisher towards you. Extract the staple cartridge by pulling up in the green tab at the rear right of the finisher. The staple cartridge can be opened by squeezing the sides together to allow the spring to act. (Sometimes it can be helped with a screwdriver popping the clear tabs located on the underside). Insert the replacement staple pack and pull the orange tab before closing the cartridge shut. Reinsert into the finisher and push down to locate it. Should work ok after all that.
Nov 26, 2007 | Canon imageRUNNER 3570 Copier
54 people viewed this question
old marine
old marine
