Question about Gateway LT2021u Netbook
The.spacebar.stopped..working. The.spacebar.no.longer.works...How.can.I.fix.it?
  • Gateway Master
  • 27,725 Answers
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Posted on Oct 29, 2012
My spacebar is not working how can i fix this
If on a Desktop, it's best to buy a new keyboard. On a laptop, where the kb is fastened to the case, try blowing out from under the spacebar with compressed air. That kb can be replaced too, but it's a hassle.
Mar 18, 2014 | Computers & Internet
Spacebar somewhat jammed
There may be something stuck under the bar like a crumb of biscuit or a bit of grit that stops the bar from free movement.
Feb 07, 2014 | ASUS Computers & Internet
My..spacebar.not.works
in think that you must change keyboard
Oct 28, 2012 | HP Computers & Internet
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
MY-Toshiba-laptop-spacebar-is-not-working.Please-help-me.Thanks
my spacebar on my keyboard is not working on my toshiba satellite...How do i fix it? I dust it and i took the plate cover off
Dec 21, 2010 | Computers & Internet
Keyboard Spacebar does not work
you will change the space bar button
Jan 10, 2010 | Dell F3534 Touchpad
Dell inspiron 6400 faulty spacebar?
You need to have the keyboard replaced. If you can't get it fixed locally, contact me for shipping information, I fix these kinds of problems a lot.
Jan 05, 2010 | Dell Inspiron 6400 Notebook
Keyboard Failure
Buy a new one.not worth fixing.RICHARDM69
Aug 31, 2009 | E-Machines AAFQ50400000K0 Keyboard
Slide out keyboard not working on HTC Touch Pro
Take the battery out of the TP and then press down very hard on the spacebar. This will reconnect the flex cable and will fix it for the time being. But in the end a replacement will be needed.
Jul 27, 2009 | HTC Touch Pro Smartphone
The spacebar doesn't work consistantly unless ''pounded''
The spacebar is the most often used switch on your keyboard, so, yes, it's from overuse, but also from
the fact that it is the longest key on your keyboard and the closest to the edge, all of this combining to
make it the dirtiest key on the board.
So, get a keyboard cleaning kit, either professional or DIY which would consist of the following, cotton
swabs, compressed air, and maybe a toothbrush and realize that all the stuff that accumulates under
your keyboard's space key makes it harder to depress to the point where contact is made.
Apr 11, 2009 | Computers & Internet
Gateway LT2021u Netbook Logo
401 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
