Question about MSI K8MM3-V Motherboard
I want to speed up the processing of my computer. for that what i can do?
  • 42 Answers
You can add ram, thats the quickest easiest and most bang for your buck and time. You need to make sure you get the appropriate type of ram and that you run your ram in what is called parallel. The best bet is pull the ram you've got off of the board. Take it to your local computer shop and get a couple of new sticks of ram. Nothing smaller than 512mb/each but some systems won't let you do more than 2GB total. Which may mean (2) 1Gig sticks of ram.
If you want to try the free route, dump all the old files you don't need/use. Uninstall old programs you don't use and run your disk defragmentation software.
Posted on Jan 04, 2009
Tip
How can you make your computer faster
<p><span>Lot</span><span>'s of people work on their computers nonstop, so computer is one of the most important electronic devices in our life. So must want to keep your computer faster and reliable.</span><br /> <p><span>These are some important tips which can make your computer faster.</span> <br /> <p><span><br /></span><br /> <p><span>1. </span><span>At the time you should check viruses, viruses can play different types of havoc with your computer. Make sure that you scan your <span>computer</span> for viruses at least once in a week for security. If there is no virus in your computer, check with a malware or spyware program to be sure that none of these nasty programs are hiding on your <span>computer</span> as well. When you removed these viruses your computer speed will automatically increased.</span><span><br /></span><br /> <p><span><br /></span><br /> <p><span>2. </span><span>After checking for viruses, you now need to look at what is installed in your <span>computer</span>. If some programs are running with computer that you never use. These programs may be taking valuable disk space. The program which running on startup will slow down the boot process. You should try to uninstall these programs by using add/remove programs. Now you will see a dramatic increase in speed.</span><span><br /></span><br /> <p><span><br /></span><br /> <p><span>3. </span><span>Now you have to check out some administrative functions. For getting your computer faster it is requires that you have to disable all the unnecessary processes. There are various sites are available for complete guides on which processes and tools to disable in order to increase the speed of your computer.</span><span><br /></span><br /> <p><span><br /></span><br /> <p><span>4. </span><span>Defragmentation is also one of the power tools that make your computer faster. This option available in system tools in the accessories. You should do this process every in a week. Defragmenter may reduce the amount of disk space you are using as well as increase speed of your computers.</span><span><br /></span><br /> <p><span><br /></span><br /> <p><span>5. </span><span>Another error that makes your computer slow is registry errors and other files. For making faster computers you must have to reduce registry errors. For removing these errors, you have to use a registry tools. Registry tool will fix your computer problems, as many corrupt fake registry tools will actually install spyware and cause further problems with your <span>computer</span>.</span><span><br /></span><br /> <p><span><br /></span><br /> <p> <span>By using of these useful <span>tips</span>, you will make your computer definitely faster in speed.</span><br /><span><br /></span>
on Dec 24, 2010 | Computers & Internet
My desktop has an orange light no beep sounds when starting it won't boot up the back where ethernet plug goes is orange too the fan makes a burning smell also
Orange light usually means the harddrive or computer is processing and loading, But it can also mean that there is a problem with the hard drive. Start your computer and wait. If you see orange light it means its working to boot up, it might take a while, you might see your screen black for a while but eventually will work.
To fix this problem you need to upgrade more hard drive space, RAM memory and processor speed
Nowadays a computer should have a minimum of 2GB of RAM memory, at least 120GB of Space, and about 2.0Ghz of processing speed.
You can also buy great refurbished computers which are cheaper. Most of them come with 4GB of RAM memory, 250GB HD Space and 2.5Ghz processing speed.
May 24, 2011 | Dell Computers & Internet
THE TASKMANAGER'S PERFORMANCE SHOWS 100% USAGE EVEN WHEN THE COMPUTER IS NOT PERFORMING ANY TASK.SPEED OF THE COMPUTER HAS BECOME VERY SLOW.
Start by identifying the processes which are using the cpu and stop them or disable the processes which are causing the usage.
Mar 07, 2011 | Computers & Internet
Blurred or snowy video what will I do? Please help, thanks!
This could have many causes. One easy solution would be to free up your computer processor:
  1. Hit "ctrl+alt+del" to open the task manager.
  2. Click on the "Processes" Tab
  3. Now, select any processes that you are not using and click on "End Process"
This will speed up your computer tremendously if you had a lot of unneeded processes running. Another reason may be that you're using too much bandwidth. To solve that, you need to stop any downloads, or videos on the internet to speed it up.
Feb 25, 2011 | Logitech Webcam
My printer is printing slowly
Print speed can be affected by three important factors:
Available computer RAM
Available computer hard drive space
The HP All-in-One product paper sensor
Follow the steps below the ensure the computer is operating properly.
Step one: Verifying the amount of RAM
Verify the amount of RAM installed in the computer.
Determine the amount of memory currently in use by background programs or processes.
Programs/processes will run in the background even when no applications are running. Most of these programs/processes will be indicated by an icon in the lower right corner next to the time.
Less memory available for applications will result is slower processing time and consequently, printing speed.
To determine processes running in Windows 2000/XP , do the following:
Press Ctrl , Alt , and Delete simultaneously and then release.
From the Windows Security box, select Task Manager.
Click the Processes tab to view all running processes.
Click the Performance tab to view the total and available amount of memory.
To determine processes running in Windows 98 , do the following:
Open the Device Manager .
Click the Performance tab.
The available system resources will display as a percentage.
Turn off unnecessary background processes.
This will free up system resources and increase printing speed.
To turn off processes in Windows 98/ME/XP , do the following:
Click Start , Run , and type msconfig.
From the System Configuration Utility, click the Startup tab.
Determine what processes are unnecessary and remove the checkmark those items.
Step two: Verifying the amount of hard drive space
Follow the steps below to determine the amount of hard drive space on the main drive.
Open My Computer , right-click the C drive, and then click Properties .
This will display a chart along with the total hard drive space, used space, and available space.
Verify that there is at least 2-3 GB of hard drive space available.
The computer will require at least this amount to process printing data for simple text files, more for image files. The lower the amount of available hard drive space, will greater the time to process print data.
Step three: Ensuring the paper sensor is clean and not damaged
The all-in-one product paper sensor plays an important role in determining the print speed.
Printing a self-test or demo page will ensure that the paper sensor is in proper working condition. If the page completes in less than 40 seconds, the sensor is working correctly.
Even if the sensor is working correctly, the printer driver might need to have the paper sensor turned off. To turn off the sensor, follow the steps below:
Open the Printer folder, right-click the printer and click Printing Preferences or Properties.
From the Properties box, click thePaper/Quality or Features tab.
Under the Paper Type section, open the menu and select Plain Paper instead of Automatic.
This will disable the paper sensor and increase the print speed
Nov 10, 2009 | HP DeskJet F4280 All In One Printer InkJet
How do i increase the speed for pentium(R)4cpu 3.00ghz
you can increase your speed of your processor installed in your computer by adding more memory that your computer or motherboard and processor can support. Sometimes even you have a high speed processor but it needs to have a high speed size of memory also in order cater more processing transactions in your computer. The memory function as the temporary storage of your current program or application you load in your syustem or you run in your computer. So the more memory size you have the more program or application you can load and the more program can be loaded in your memory it can help your computer fast or process more processing transactions in the computer system. So if you want to make your computer fast you have to install a high speed processor at the same time a large and fast memory.
Hope this will help you answer your problem. Thanks
Jun 25, 2009 | Computers & Internet
My processor's clock speed is 2.53ghz, when i boot up my computer's processor actually runs at a 2ghz clock speed intel ID utility detected it but after 10mins or so my processor's clock speed drops down...
The reason for this is because you CPU needs to run only at 1Ghz at that particular moment. see the more programs you run, the more processing is needed. No if your computer is on Idle then the or have programs like word or excel running the processing is less. so the CPU automatically reduces the processing speed. this way the CPU is energy efficient. you have nothing to worry. this is a feature that Intel has added to the newer generation of CPU's
May 13, 2009 | Computers & Internet
Processing speed and memory installed
This happens usually when you use a old computer , try to increase the primary memory space of the computer you be able to install it or your computer may not be compact able with the printer or please check on the box the system requirement.
May 20, 2008 | Lexmark X2350 All-In-One InkJet Printer
Siemens computer
hi dear
i think it's processing stop causing by internal failure, it's about your speed of dvd recording ...try to used a slower speed
and try to refresh your burning softwre
ok
Mar 26, 2008 | Computers & Internet
MSI K8MM3-V Motherboard Logo
142 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
