Can't see my screen unless I shine a flashlight on it, why is that and how do I fix it?
    Scholar:
  • 106 Answers
Well, there can be two main reasons for it:
1) Either the brightness of your screen is lessened to a greater extent. If that is the case than you can increase the brightness by pressing FN (Function) key and a key from F1 to F12 based on your laptop setting to increase the brightness. Generally it is F7 to decrease the Brightness & F8 to increase the brightness.
2) If your brightness is alright then there is a problem with your LCD Panel. Take it to nearest Compaq Authorized Vendor for a check up. There may be a lose connection or a fault with your LCD Panel.
Posted on Oct 29, 2012
    Genius:
  • 2,432 Answers
Screen back light need replacement.
3 Suggested Answers
piyushclal
  • 148 Answers
SOURCE: L35-S2171, Monitor screen will not
might be ur LED 's r fused up..
try to increase the brightness from ur keyboard.. might be ur screen light is turned off..
try to increase the brightness via ur function key & additional key on keyboard...
hope dat works out
Posted on Nov 29, 2009
KingDWS
  • 1606 Answers
SOURCE: I Have a Sony laptop VGN-NR160e. When I turn it
Your back light or the back light power board is the problem. The way you checked with the flash light is exactly how to find out if it is a back light issue. The ghost desktop is the indication as the image is there but just not illuminated. The back light is like the bulb on a film projector. If it goes out the images are still there you just can't see them.
This is covered by warranty if you have any. So if you think you do you should contact the store you bought it from or contact Sony. If you think you have extended warranty that is usually through the purchase store. If you don't have warranty you have to be a bit more careful. The repair cost will be about $100-$150 with most of that being labour as well as any shipping on top of it. So you want to make sure it isn't excessive. On some low end laptops the repair is as much as a new one. Your other alternative is a bit of DIY.
I don't know where you are located so no idea if any of the places that supply parts are close to you etc. If you do a search for "Sony laptop VGN-NR160e backlight" or "laptop repair parts" you will find literally hundreds of sources. This is a job you can do yourself. This link shows you how how to do it on your model. http://www.fonerbooks.com/laptop_8.htm That will give an idea of what you would have to do. This next link is a place that sells the bulb as well as the inverter board. I'd replace both while you have it apart. The bulb is $10 and the board is $19. If you have the tools which is basically a small Phillips screw driver and something to use as a case splitter like a credit card and a drop of glue to put the little rubber screw covers back in place. This next link is for the inverter board and just click along the left side to get to the back light bulb (or search by model).
Those are your options for a bad back light.If you are considering doing it yourself there are videos and other pages you can look at. Instead of junking it or using a external monitor all the time the parts are cheap enough to make it worthwhile looking at doing it yourself.
Posted on Sep 25, 2011
Sony KDL-46BX420 TV has a black screen with sound.
Inverter board powers the back light leds.
Aug 27, 2017 | Sony Televison & Video
I have sound but no picture on my Sharp Aquos tv.
Do a flashlight test on the screen. With the TV on shine a flashlight on it and look for a dim picture. If you see it, the ballast board for the backlights is bad. If you don't see any movement, the T-Con board is bad. You can get parts from here and fix it yourself. TV Parts Universal TV Stands DLP Chips ShopJimmy
Oct 25, 2016 | Sharp Televison & Video
Why won't it turn on?
While it is on, shine a bright flashlight on an angle across the surface away from you. Can you see any faint images on the screen. If yes, then possibly the back lit lamp / board needs to be replaced.
LCD LED TV Repair No Image Blank Black Screen Flashlight Test How to Fix...
Nov 25, 2015 | Televison & Video
No picture
If you look very close at your screen (might need flashlight here), do you see the picture as a black screen? If so, your backlight may have died on the panel. Replacing the inverter board will fix that right up unless the tube (lightbulb) has burnt out instead of the board. Both are replaceable.. Check it out.
Aug 17, 2014 | Dell 221-9495 W5001C 50 INCH PLASMA TV...
The monitor Westinghouse model LCM-19w4 when I turn on the computer the screen remains black even with a green light on and I can use a flashlight to see the screen. When I turn it on and off the scre
It's mostly likely a bad capacitor in the main power supply of your monitor. If you're brave enough to dismantle it, look for capacitors that're "crowned", and sometimes even rupture from overheating in such circumstances. You can order replacements from Digi-Key if you can figure out which might be your problem, but I'm not sure I recommend you try this unless you have at least SOME soldering/desoldering skills or a friend who does. You COULD wind up worse off. It's up to you, only YOU know your personal skill level for such tasks. And do I need to say, UNPLUG it before dismantiling? :)
Mar 16, 2014 | Westinghouse 22" Widescreen LCD Flat Panel...
Black screen
Here is a fast test for the inverter in the display. Take a small flashlight and shine it in to the bottom right corner where the windows start button should be. While shining the light in try looking at the screen. If you can see the Start icon then the inverter PS or the FL tube in the display is bad. The least expensive fix is to replace the Inverter. There exist detailed instructions for the disassembly of the display panel as well as sources for the part itself. If there is further problems contact back later.
Nov 26, 2013 | IBM ThinkPad T43 Notebook
Black screen that can be seen with a flashlight
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Aug 26, 2012 | Acer Aspire Computers & Internet
How do I replace the bulb? or is this something that I have to send in for repair? Pioneer wants a flat rate of $200.00 The buld went out on my screen (AVIC-N1) Everything works, I just can't see the...
I had a problem like that with mine, it was not a bulb it was something called the flex cable, it powers the screen. you can send the radio out and they will fix it.
Mar 08, 2010 | Pioneer AVIC-N1 Car DVD Player
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
