Question about Casio GzOne Commando C771 Verizon Cdma
Im trying to figure out what all of the symbols on the home screen mean, on a cassio Commando
Is there a key of the different symbols? Thanks.
  • 7,482 Answers
Hi Las
Go to the following webpage and download the FREE user manual for your Casio it will explain all there is to know about your Casio.
Please take time to rate me
Bud
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and cranking the engine or by pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Bud
http://nec-casio-mobile.com/support/download/GzOne_COMMANDO_Eng.pdf
Posted on Oct 29, 2012
How do i make the green keys n the acre aspire 4530 work
hold down the fn key and press the key you want!!!!
Jan 12, 2014 | Computers & Internet
3414 gateway laptop backlight goes out
First look at the buttons on your keyboard. Look for keys that have a sun or light figure on them. It will not be the traditional white color, probably blue, or red, some off color. A particular laptop is a Dell Inspiron, and it has the symbols on the Up and Down arrows. It looks like a sun symbol. The symbols are blue in color, which means there has to be another key on the laptop that is also blue, that you will have to press in conjunction with these keys to perform the function. This is similar to a function key on a calculator. The default setting on your laptop is going to be power conserving. Meaning that when you unplug your laptop, the screen will dim to save power. You can change this by increasing the brightness. So in conclusion, in order to keep your laptop screen bright, you need to turn up the brightness when the laptop is unplugged. Make note that when you do this, the power consumption will increase.
Feb 08, 2013 | Gateway MX3414 Notebook
Sony vaio tr3a screen is black, but safemode lettering shows when I reboot with f 8 held down so I know the monitor is working but when I choose safemode and the computer tries to get into windows...
Hi ponotoc2,
On my acer I have some F buttons with little symbols on, I know that if I press FN + F6 it will switch my laptop screen on and off, I also can use FN + F5 to swap between monitors.
These could be different on a sony though and I can't remember what F numbers you need to press, I've seen some people say FN + F4 but im not 100% sure on this..
The symbol you should be looking for could look like 2 boxes one dark one and one coloured to simulate brightness.
I hope this helps
Myke
Feb 23, 2011 | Sony VAIO TR3A Notebook
Im having problems getting the @ sign up on my laptop.It is located with the letter q and i dont no what to press to get it up.Can you help me?
Hi, is it on the 2 key instead 'SHIFT & 2' if so let me know so I can tell you how to switch it back.
Thanks
Mark ;-)
May 03, 2010 | Compaq Armada 7400 Series Replacement...
How to get stock report from cassio TK-6500
For PLU stock balance report
1. Key turn to "X1"
2. Press [6][4] [CA/Amt Tend]
For PLU sold report
1. Key turn to "X1"
2. Press [1][4] [CA/Amt Tend]
Jul 24, 2009 | Casio Parts Cash Register PC Desktop
Instructions what key pad buttons symbols mean, im a first time user dont know what key pad symbols stand for
the sysmols has there usual meanings for which they stands for.
also if u are trying to type them and not able to type them then u have to press the "shift" key on the keyboard before pressing the button which you wants to type.
Apr 24, 2009 | Acer Aspire 5735 Notebook
I lost my manual and I'm just trying to find out what the symbols on the front panel mean. I'm particularly interested in knowing what is the difference between the sun and half-sun
The full sun symbol means full heat drying,, and the half sun symbol means half heat drying.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Dryers
Keyboard
You don't say what make and model so generally there is either a key with a degree symbol or it is on a keytop in a different color this means tou must use the code or alt. key with it.
DickyO
Dec 20, 2007 | Office Equipment & Supplies
Screen cracked and cannot taggle to seperate screen
Carefully examine the keyboard. These do vary from model to model but one key will have a screen symbol in another colour[blue perhaps] this will mean pressing another key to get the blue function The key to press may also have a blue element. Also get onto the Sony Technical Support team
Jun 06, 2007 | Sony VAIO TR3A Notebook
Casio GzOne Commando C771 Verizon Cdma Logo
79 people viewed this question
Top Casio Audio Players & Recorders Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Casio Audio Player and Recorder Expert? Answer questions, earn points and help others
