Question about Dishwashers
Error 002 on my beaumark portable dishwasher and does not drain properly
3 Suggested Answers
  • 48 Answers
SOURCE: beaumark dishwasher 400411
Assuming that it has gotten progressively slower over time, suggests a blockage of food, labels, etc.
-the sometimes it will drain...sometimes will not results each time you run it...the food becomes dislodged...then catches within the drain...note...this is a good thing...it just has to be cleaned out everynow and again...which most of us do not do enough:(
This is not a difficult fix...but can be really gross to do.
The first time doing this is sorta-hard...but once you do it once, see how simple it really is....you will only not wish to do it because you know the goop you will find :)
  1. open dishwasher door
  2. lift out bottom rack....sorta put your head right inside....try not to put too much weight on the door as you do it...yes this is awkward :)
  3. look at the bottom of the DW and there will be a circular hard plastic mesh/drain (lots of little holes, and perhaps even a larger catching reservoir)
  4. these holes and the reservoir have likely become clogged with food residue/labels, etc
  5. here is the gross part....scoop this out...BE CAREFUL.....especially if you have EVER broken a glass in the dishwasher....as the glass is mixed in with this goop!
  6. If you are feeling really adventurous...you can actually remove the circular basket to more thoroughly clean it..ie. wash it in hot water..scrub...etc...this is the best..
  7. to do this...the lower arm must be removed
  8. generally they are held in place by the 'cap'...turn counter-clockwise...spins off
  9. lift off arm....observe how it came off...set it down exactly the same way on the floor
  10. now the circular mesh is accessable...held down with clips (often the mesh is more flexible than the clips...proceed carefully..as it is plastic
  11. list it out
  12. clean thoroughly
  13. replace
  14. REPEAT PROCESS every so often.....if you do it enough you can stop at #5
hope this helps
Posted on Oct 08, 2008
SOURCE: What is error 002 on Beaumark Dishwasher BM-DW 9702-SS
Error 2 = Longer Draining Time. The installation of the Drain Pipe is too high.
Posted on Jan 11, 2011
Water not drains,Danby Portable Dishwasher
I had the same problem and found the drain blocked at the outlet as it goes into the sink.
Dec 27, 2013 | Danby DDW1899WP Portable Dishwasher
Where can I get the owners manual for a Beaumark 18
try to go www .fitness.manualsonline.com or www. retrevo.com
or wwwmanualsfactory.com or www. pdfservicemanual.com
God bless you
Jul 11, 2012 | Dishwashers
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
Beaumark Dishwasher 40210 won't turn on. I
check the troubleshooting section in your manual. If you don´t have it anymore, you could find one asking here
May 13, 2010 | Dishwashers
Beaumark portable air conditioner operation
Beaumark air conditioners are made by GE…head over to their site and download a manual for their air conditioners - they are very similar.
http://products.geappliances.com/ApplProducts/html/GEAResults.htm#Category=Window_Room_Air_Conditioners
Mar 07, 2010 | Heating & Cooling
Apr 21, 2009 | Dishwashers
Beaumark Whisperwash portable dishwasher has pile of macerated food scraps behind screen at bottom rear of machine. Dishes have "grit" stuck to them after cycle complete. Think the built-in...
That screen is held in place by two screws. Remove the screws, pull out the screen, clean it and put it back. You should perform this cleaning periodically to keep your dishwasher running perfectly.
Gina
Jul 11, 2008 | Dishwashers
Danby error code 002
I spoke with Danby, and this error indicates the fact that the dishwasher is unable to fully drain. Likely causes are a kink in the hose, hose is too high on the drain pipe to drain, or, the pump motor is dying.
Seeing as mine's been mounted without fault in the same place for 2 years, I think I can tell you which one I have.
Dec 22, 2007 | Danby DDW2406 Stainless Steel Built-in...
Dishwasher
pump not working.
check wiring
Nov 28, 2007 | Heating & Cooling
Dishwashers Logo
386 people viewed this question
Top Dishwashers Experts
