Question about Dacor DMT2420SS Microwave Oven
M/w only working when slight pressure applied to door button
This morning, our Dacor m/w oven stopped working - panel was still on and counting down seconds as normal, but no m/w sound or platform turning. After tinkering with it, I realized that the m/w sound and platform returned to normal when I apply a slight amount of pressure to the dooor opening button (not enough to open the door). Seems like there is a contact behind that button that is a bit off.
How can I fix this myself? I removed the door button, cleaned and inspect it but I cannot seem to see anything I can do barring taking the whole thing apart. Any help is much appreciated
Thanks
---Greg
  • erikaandgreg Jan 04, 2009
    Thanks so much for the helpful answer. I will try to open the microwave tomorrow to see if any screws are loose around the mounts or switch. How would I know if that's indeed the switch that needs to be replaced?
    Also, as further development, as of tonight the trick of applying some pressure to the door button does not work anymore - the oven does not cook now and just counts down the seconds as if nothing was wrong. Does it change your opinion on the problem?
    Thanks again
    ---Greg
  • Dacor Master
  • 9,098 Answers
M/w only working when slight pressure applied to d - a1fe1bb.jpg
That would be a defective secondary interlock (lower door switch) or its mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 03, 2009
  • William Miller
    William Miller Jan 04, 2009
    The switch may click and still be bad. You would really need to do a continuity check to see if it's making contact. If the mount is solid and is aligned, then it's probably the switch.
    Since pushing the door used to work but does not, it may be that the looseness or misalignment has increased, or the switch has gotten worse.
    The best best is to unplug it, take the cover off, then observe how the door latch heads go into the chassis and if they snap the switches down all the way.
Latch on Dacor micro (DMT2420S) not engaging sensors.
The latch interlock may be defective or in need of adjustment.
Dec 14, 2017 | Dacor Microwave Ovens
Some sensor/switch is out?
There are two switches there do you know how to get into the control panel?? If not let me know I will walk you thru it
Jan 24, 2008 | Frigidaire PLMB209DC Microwave Oven
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
The Dacor DMT2420S microwave has power. Instrument dial is lite and the timer works. I can program the keypad however the turntable will not turn and the microwave will not work. The timer will count down...
There's no reset button, and if the fuse were blown, the oven would be totally dead.
Your problem is almost certainly a failed secondary interlock (bottom door switch) or its mount.
You can see our help file on door switches here and the service manual here.
Jun 20, 2011 | Dacor Microwave Ovens
Timer counts down but nothing happens
one of three of your micro switches that monitor your door is bad. easy to fix. remove control panel and u will see the switches that the roll cam for your door hits.
Apr 20, 2009 | Dacor DMT2420SS Microwave Oven
Sharp R530EK
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You will need the
Otherwise, the best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Jan 02, 2009 | Dacor PCOR30 Convection/Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
Dacor DMD2420S
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 06, 2008 | Dacor DMT2420SS Microwave Oven
Dacor DMT2420SS Microwave Oven Logo
179 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
