Question about Western Digital My Book Essential 500GB USB External Hard Drive
How to remove forgotten password on WD My Book Essential 500MB External
It has no reset pin hole or button. Only a power button, usb, adapter & Kensington slots. I want to preserve the existing data on the drive so a factory restore is not an option
  • Brian Sullivan
    Brian Sullivan Oct 31, 2012
    You can reset the password on My Passport from within the application if need be.Click "Start" and select "Computer." Double-click the CD-ROM drive, then double click the "SmartWare" application; on a PC, the application is listed as "WD SmartWare.exe," and on a Mac it is listed as "WD SmartWare.app."Click the "Settings" tab. Click "Set Up Drive." Select "Install" and accept the "End User License Agreement" when prompted. Click "Continue Setup." Open the "Security" tab. Type your current password into the box labeled "Password." Enter a new password and a new password hint.Confirm by checking the "I Understand" box and clicking "Update Security Settings." and keep the password apart from your computer
  • Western Digital Master
  • 27,725 Answers
Is it your primary drive with an operating system and which operating system ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
hope this helps
Posted on Oct 29, 2012
  • Concept Bahama
    Concept Bahama Oct 31, 2012
    This is an external drive so that solution does not help. It seems that my question was not fully read. I'm not having an error. The password was simply forgotten and I do NOT want to wipe the entire drive only remove the password.
  • Brian Sullivan
    I think i did mention was it your primary drive and have you triedhttp://majorgeeks.com/Dr._Freeware_Syste... its free and has password reset tools
bob_computer
  • 3153 Answers
SOURCE: No power to my WD 1TB
If its under warranty then get it sent back.
If its not then almost any 3.5 " external sata enclosure will do so long as it has its own power supply. and if that supply is a wall-wart then should you pooch that, they are so easy to pick up and replace.
If you need quick access to the files remove the disk and fit it to a suitable computer.
If this information was useful please click
Posted on Aug 14, 2009
  • 108 Answers
SOURCE: how do you back up seagate external hard drive to
Plug both Drives into Computer USB ports. double click on my computer, double click on the drive that has the files, highlite the files you would like to move, right click within the highlited files, then select copy, go back to my computer, double click on the other drive, the one you would like to move the files to, right click and select paste. That`s it. After you verify that your files are on the Seagate drive, then you can delete the files on my book or whatever. Good luck
Posted on Dec 21, 2009
perpetually
  • 360 Answers
SOURCE: Can't turn off Hard Drive
The error means that you are using a file on the external hard drive and that it can not close that file when it is use. You have to close the program that is using the file first.
Example:
Lets go on the assumption that you have your music collection on the external. If you still have your music player running when you try to disconnect, you will be greeting with the same error message.
If the external contains any files that your Operating System uses, you will get this message anytime the computer is on. An example of this can be your "Page File".
Shutting the computer down correctly is your safest bet until you find exactly what file is being used and what program is using it. During shut down, the computer closes any running programs. With no programs running, it will safely disconnect from the external HD because there will be no files in use.
If you manually disconnect it while the file is in use, you could very easily corrupt the file and make it unusable. This is comparable to an Operating System getting corrupted from a computer not being shut down correctly (pulling the power from wall without doing a shut down).
Hope this helps.
Posted on May 02, 2010
  • 177 Answers
SOURCE: forgotten wd my book essential drive unlock
I believe this drive works with the Mionet program? If so, go to the Mionet website, and you should be able to get reminders, and/or reset the password.
Posted on Jul 17, 2010
mariolands
  • 2296 Answers
SOURCE: how to reset password for
Follow this link and download ATAPWD 1.2 to recover your password: http://win7dl.com/download/download+ATAPWD+1.2+Hard+Disk+Password+Utility.html
Posted on Nov 19, 2010
What volt adapter for WD 3200H1U-00?
Most external hard disks use a 12 volt 2 amp power supply. The modern ones are small and cheap. Be aware the power plug should be the same as the power plug on the old power supply. and the polarity also.
Jul 09, 2014 | Western Digital My Book Essential 1TB...
Wd 1600 not working
Western Digital My Book hard drives use USB 3.0 and USB 2.0 speeds to transfer data from the hard drive to the computer and vice versa. When your My Book external hard drive is not performing properly or not turning on, you can troubleshoot the problem before sending the hard drive back to the manufacturer. Correctly powering up and installing the My Book are essential for transferring information and avoiding corruption.
Run your fingers up and down the power cable that connects to the back of the My Book hard drive and the wall outlet in your home. Feel for breaks or tears on the cable and replace the cable if needed. Check the pin on the back of the hard drive where the power cable meets the drive. Make sure the pin is straight and will make contact with the power cable properly. If the pin is bent, send the hard drive to Western Digital for repair. Plug a different device into the power outlet you are using to make sure it works properly. Use a device that you know powers on correctly. b> Slow Transfer Rates b> Open your computer's tower and check over the PCI adapter card that gives you the ability to achieve USB 3.0 speeds. Make sure that the adapter card is installed correctly per your manufacturer's installation manual. If the PCI adapter card is not installed correctly, you will not be able to transfer data in the 3.0 speed. Disconnect any other external hard drives connected to the system. When two hard drives are connected via USB, they share the transfer rate bandwidth and slow your transfer speeds down. Run a Windows Update to change the USB driver on your computer. Click "Start" then "All Programs" and then "Windows Update." Run the update and choose your correct USB 3.0 driver from the list. Click "Install" at the bottom to install the driver. Hope this helps.
Jan 05, 2013 | Western Digital My Book Essential Edition...
I have an external hard drive but forgotten the password
I did a bit of research for you and came across an article which says this:
It's difficult when you forget a password, especially if the data on the password protected hard drive is of value. Unfortunately, I'm not sure there is much you can do. Try some of these steps to see if they can help you unlock your external device.
The only real solution or hope that you have is looking for a reset button on the external device. The reset button is on the back of the device and is most likely located where the power supply or USB connection hooks into.
If you do have one of these buttons, power off the device and unplug the device from all the power cords or connections running into the box and hold the reset button for at least 30 seconds. You may need to use a paper clip or another similar tool to press the button.
If this works, it should reset the device to the default user name and password which is usually blank.
If that doesn't work, the best thing I can suggest is taking it to a service technician.
Jan 02, 2011 | Western Digital My Book Essential 1TB...
Where is the reset button to my Wd my book Ex harddrive,The lights at the front of the harddrive are flashing and when I connect it to the computer or medid player no icons show so I can look into my...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 16, 2010 | Western Digital My Book Essential 1TB...
My Western Digital My Book Essential 1TB External USB suddently won't start,even though i'v plugged in the power cable, theres no lights nor sound coming out from it it just suddently happen out of nowhere
* the USB cable
* the power-adapter
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 10, 2010 | Western Digital My Book Essential 1TB...
Forgotten wd my book essential drive unlock password
Jul 17, 2010 | Western Digital My Book Essential 1TB...
Lost my AC adapter, and dont know what the adapter specs are so as to get a new one
You'll need a 12V, 1.5 Amp power supply. Center pin is positive (+).
Something like this should do.
Nov 17, 2009 | Western Digital My Book Essential 1TB...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
I can't locate my power adapter for my WD storage devivce
they all use 12V , so just get any 12v transformer that fits
the amp is i think 3.1amp or near.
Mar 04, 2009 | Western Digital My Book Essential 500GB...
Western Digital My Book Essential 500GB USB External Hard Drive Logo
169 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
