Question about Philips Magnavox DVD/VCR Dual Player
ZV420MW8/DVD/VCR WONT WORK..
I HAD TWO FRIENDS HOOK UP MY DVD/VCR AND I BELIEVE THEY HOOKED IT UP RIGHT...WHEN I TURN THE DVD/VCR BUTTON ON THE REMOTE, ON THE DISPLAY SCREEN ON THE DVD/VCR THE CODE
"E1 APPEARS...COULD YOU OFFER ME ANY ADVICE...
STAN ROUSE
  • 1 more comment
  • ephesians3 Jan 03, 2009
    I HAD MY DVD/VCR HOOKED UP...WHEN I TRY TO CUT IT ON THE DISPLAY SCREEN ON THE DVD/VCR SHOWS "E1"....
    I HAD SOME FRIENDS CONNECT UP MY ZV420MW8 DVD/VCR AND WHEN I TRY TO CUT IT ON WITH THE REMOTE, THE DISPLAY WINDOW ON THE UNIT READS
    "E1" DO YOU HAVE ANY SUGGESTIONS?
    stan rouse
    I HAD MY ZV420MV8 DVD/VCR CONNECTED UP AND WHEN YOU CUT ON THE DVD/VCR WITH THE REMOTE, THE CODE
    "E1" APPEARS ON THE UNITS DISPLAY SCREEN...ANY SUGGESTIONS?
    STAN ROUSE
    Sergeant:
  • 233 Answers
Well, Bad news, but E1 is an error code that means something is internally wrong inside the unit. It may be cheaper in this case to just replace the player..
Posted on Jan 03, 2009
    President:
  • 2,110 Answers
At first, I thought you might be using S-Video cable to connect, and hadn't changed the default "Video Input" to "S-Video In" but that's for E1.
E2 only takes the Yellow "Video In" so you must be using it for your Video connection?
I'm was wondering if your Video > Video Input menu is set for "S-Video In" and it's affecting both E1 and E2, but a test disproved that possibility?
    Genius:
  • 1,199 Answers
Hit the select button on the remote to change to another connection so the unit has a open signal to the TV
  • 3,037 Answers
Hi ephesians3_2
E1 is the rear composite/S-Video+L&R audio input and E2 in the front input. To change the source, top left side button on the remote.
so something is wrong with the rear part of the player, either the player itself has a problem or something that is hooked into it is causing this error to show up.
bestdarngood
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, the error code "E1" could refer to a stuck disc or tape inside. Try unplugging for a few minutes. Press and hold the POWER button while plugging in. Alternately, normally power it up and press & hold the eject button.
Good luck and Thank you for using FixYa.
  • 470 Answers
It looks like a standard DVD but is written in a different data format. They aren't using ISO or UDF from what you're showing me, since windows can only read ISO or UDF you need to just get an app that doesn't care what the format is - that may work.
There are 2 options, one is to use the GC as the reader and dump the files to your PC (not sure how you would do that) the other *may* work using a DVD reader app that will read either the GC format.
The big problem I see is the encryption and it may just be that's the reason why you can't read it, thus you have to crack that then ZV420MW8/DVD/VCR WONT WORK.. - frown.gif No way to do this unless you can program, assume you can? Then you need some hardware info for the GC.
There should be a way to copy them...playing them may require a modchip.
The unrecoverable errors are do to encryption, like a CSS disc no you can't recover those for sure it isn't reading the sectors
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 18, 2009
    E! appears a detection of harmful error, you need to replace your unit because it cannot cure anything because the E1 error is changing and deleting all the program on your unit
  • Philips Master
  • 13,433 Answers
E1 would indicate the External 1 connection if you browse channels up or down you might get E2 which would be the external connection 2.
Recorded pictures onto a DVD on my computer, they won't play on the ZV420mw8
I looked up your DVD player's model number online. It is not equiped to read picture files (.jpg, .bmp, etc.) You have to be carefull when you transfer pictures to a DVD on your computer. If you just burn them to the disc, most DVD players wont be able to read the information. Frequently you have to use a program like Microsoft Movie Maker to get them in the right format.
You may have to start over and use a DVD making program to make them a video and not just picture files.
Hope this helps! Don't forget to rate!
Jun 26, 2012 | Magnavox ZV420MW8 DVD/VCR
How do I change VCR recording speed on the Magnavox ZV420MW8
If you have the manual it is on page 79 (Press Rec Mode There are two speeds SP SLP it will toggle between the two.)
You can download the manual at http://www.funai-corp.com/6pdf/om/ZV420MW8.pdf
Jul 04, 2011 | Magnavox ZV420MW8 DVD/VCR
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
How do i connect my magnavox zv420mw8 to my cable boxconverterand modulator
the cable from the wall is to the cable box in....(do have monitor) cable box out to tv coax in...dvd / vcr & audio outs to tv ins....and tv outs back to dvd vcr audio in....tv is on ch 3 for cable...look for your dvd /vcr or aux ch when want to look a dvd or vcr...now set the dvd to ch 3 settings and cable broadcast...your cable box will determine what you record....note HBO may not record on DVD, but will on VCR tape
May 15, 2010 | Philips Magnavox DVD/VCR Dual Player
My non-tech friend hooked up a new DVD player, but can't get it off Spanish...
You didn't explain why you can't. No manual? You follow the instructions but they don't work?
I'll assume the basic, no manual.
If it's the VCR then do the following...
Turn it on and press the VCR button at the top of the remote.
Then press the SETUP MENU button.
Then highlight SETUP on the screen and select it.
Hightlight LANGUAGE SELECT and follow the instructions in the yellow box to change.
If it is the DVD then do the following...
Turn it on and press DVD at the top of the remote.
The big 'A' should be highlighted at the top left of the screen.
Move the highlight to the right to MENU LANGUAGE.
Then move it again to the right to ENGLISH at the top of the list.
SELECT English and press SELECT MENU again.
That should do it.
Jan 19, 2010 | Sanyo DVW-6100 DVD Player/VCR
Can't get hooked up so it ALL works vcr, converter box, dvd...
If the DVD works through this "box". Things are looking alright. There must be a number of inpus or hookups to connect VCRs or DVDs or what ever to this "box" that then allow you to hook tp the TV.
If this is the case there has to be a way to swithc the box to the different things hooked to this box so that you can see& hear them.
I do not know what this box is, but can only guess you need to get the manual or more info on how it works.
If you can try to hook each one of your pieces seperately to the box.
First unhook the DVD that works, and hook the VCR. If works, unhook the VCR and hook up the the enxt piece. That way you'll know if each of them is working.
Dec 30, 2009 | Philips Magnavox DVD/VCR Dual Player
No color and sporatic play on VCR mode, with zv420mw8
If this problem happened within a few seconds, you probably have dirty heads. If It happened slowly you could have an alignment problem. Both of these problems should be repair professionally.
Fuji
Jan 29, 2009 | Philips Magnavox DVD/VCR Dual Player
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
At the end of my wires
If you use scart cables you almost cannot go wrong. You can either hook one scart from your DVD/VCR to the TV and one from the cable box to the TV, and switch using the A/V button on your TV.
Alternatively, you can hook one from your cable box to the "in-port" on your DVD/VCR, and one from the DVD/VCR to the TV. In this case you should be able to record programs from your tuner.
Dec 11, 2007 | Toshiba 27A44 27" TV
Philips Magnavox DVD/VCR Dual Player Logo
91 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
