Question about Gateway MX7118 Notebook
Fix the on button on a Gateway laptop (MX7118)
The button that turns the laptop on does not push down. I am trying to get the laptop open to find out what I need to do to fix this but I can't get the case open. Thanks for any help you can give me.
  • gmartinhere Jan 26, 2009
    My power button on my MX7118 does not turn on the computer. I have to use a writing pen to run along the side of it to turn it on. I do not know if this is a specific hazard as the computer won't turn on unless it is plugged in (battery only holds charge for 1-2 minutes. Yeah, its old, but I have a new computer I am using now). I just saw the post and wanted to se if this was a common problem. First it was the hinges kept breakinig, now the power button.
    Gordon
    gordonmisc@yahgoo.com
  • Anonymous Feb 07, 2009
    Wow, I guess it's a Gateway consistent problem, because both of my hinges are cracked as well, and now the power key will not push down. Apparently the hard drive is fine, because I took it to Circuit City and they copied files off my hard drive for me, but they won't open the thing to fix the power key, so I'm doing it myself.
    I wish someone had a guide on how to fix it. I've looked and so far can't find one specific to the MX7118.
  • 201 Answers
Lay down the screen flat
then get the two screws under the power bar
lift up power button bar carfully,you will see ribbon cable connected to the mother board with little brown clips, one on the power button also, this ribbon cable is very thin, and you probably will see the cracks with maginfy, order ribbon cable on ebay
Posted on Jul 20, 2009
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Gateway mx7118 wont start wirt added ram. I want to add a 1gb stick od ddr2700 ram but it wont start with the mamory installed, just sits there with a blinking cursor
If you are using 2 different types of ram (from different mfg.,same brand may not work if made to diff specs) it will not work.
Mar 02, 2010 | Gateway MX7118 Notebook
Laptop will not turn on, either on battery or using AC adapter. Any help would be appreciated. Dobby
A little more info may be needed to narrow the reason down. What was it doing before this occured...was it witnessed, was it upgrading, was it turned off for the night and then the next day...this, was it running all night in hibernation...etc. Have you tried getting a universal charger and trying that. Do you get power indicator lights when it is plugged in?
Aug 27, 2009 | Gateway MX7118 Notebook
SOUND PROBLEM
Here is the Gateway site>
You will find all the drivers on this page..
http://support.gateway.com/support/drivers/search.asp?param=mx7118&st=kw
Jun 24, 2009 | Gateway MX7118 Notebook
SC1485ITC 0534 ZA5150690 WHAT IS THIS ? I NEED THIS PART FOR MY LAPTOP BUT NOT ABLE TO FIND IT .
Get on a friend's computer and go to http://support.gateway.com/support and enter your information on the website, and it should be able to give you specific information about your laptop. If nothing else, try calling Gateway and ask a representative to help you.
Apr 17, 2009 | Gateway MX7118 Notebook
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 13, 2009 | Gateway MX7118 Notebook
Start button on Gateway MX7118 is broken
No there is no other option wherin u can start the machine................u need to use the start button..................Sameeraryan
Jan 17, 2009 | Gateway MX7118 Notebook
Hard disk upgrade for Gateway mx7118
check Gateway's support for possible help here. Most laptops can be upgraded substantially, RAM or Hard drive.
Gateway's site- I didn't see any BIOS upgrades. http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=10651&os=&type=
Perhaps someone on this site has made such an upgrade and can give you a definitive answer.
Jun 18, 2008 | Computers & Internet
Open Questions:
Gateway MX7118 Notebook Logo
782 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
