Question about Toshiba Satellite A75-S226 Notebook
Beeping power adapter
I have a Toshiba Satellite A30. It works fine running off a charged battery but when I plug the power adapter in, the pack on the adapter starts beeping and won't charge. If I try to plug it in to the back of the laptop with the power switched on already it starts to spark. Yes, I have a problem!!! I thought it might have been the power jack so I had that replaced and it is doing exactly the same thing. I've been told that I need a new motherboard but I don't want to pay $1200 for a new one. Any suggestions as to what it could be? Thanks
    Scholar:
  • 94 Answers
The problem is most likely (85% sure) with the DC Jack itself, that is one of the rarer issues with it. Since it is a 2-state switch, the likelihood of both circuits closing is my guess. And also the cheapest repair. I have been completely through the A75 without a schematic, and have to remember it's quirks in design.
Posted on May 18, 2007
  • scomtech Mar 16, 2011
    Kegtapper - do you mean the socket on the laptop or the plug on the psu? We have a machine doing the same
Toshiba Satellite m305-s4910
remove the battery pack and power source. make sure nothing is plugged into the laptop. hold down on the power button for 30 seconds. then reinstall battery, plug the the adapter into a known live power source (the real reason for your problem) and power it up!
Jan 16, 2012 | Toshiba Satellite M305-S4826 Laptop
How do I restore my Toshiba Satellite A30 303 back to factory settings.
press power on button and press F2 to enter BIOs
in last select restore to factory setting and save changes by click on link or press F10
Aug 20, 2011 | Toshiba Satellite A30-303...
My toshiba satellite series a135-s4656 laptop stopped charging for over two weeks now. Though the adapter (power pack) is functional. Please what do i do (cos the system has been down since)?
How do you know the ac adapter is working? Just because the light on the ac adapter is on doesn't mean it's working. Does it work with the ac adapter plugged in? Just not charging the battery. If in the first case just buy a new ac adapter and see if it works, most are affordable some not so much. If the battery isn't charging then you will have to shop for a new battery. If both of those are good then you have either a bad ac plug on your laptop, or motherboard issues. Hope this helps, if you have more questions just reply and I will try to help.
Aug 01, 2011 | Toshiba Computers & Internet
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My battery doesnt hold a charge
That means that you will be needing a new battery. I would suggest that when you get a new battery (hopefully from the manufacturer) What you should do it charge it, and don't recharge it untill it has completely dead. That will help to preserve the battery longer.
All The Best,
Ryan Frame
Creative Energy Associates Technical Center
Jul 09, 2009 | Toshiba Satellite L45-S7423 Notebook
My Toshiba Satellite A30 laptop keeps switching off when charging. It works fine when on the battery but seems to overheat when I use it whilst charging the battery. Can you help ?
I would suggest that you try it with another AC adapter first, because it seems the adapter is faulty and therefore supplying more current into the laptop than necessary.
If it works perfectly with another AC Adapter, then you might just have to change your AC Adapter.
Hope it helps.
Jul 05, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Toshiba laptop wont turn on
Hi, you must remove the battery pack and connect with just the power adapter, and tries to turn on the computer if it operates properly and the battery problem solved
May 05, 2009 | Toshiba Satellite P105-S6104 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Toshiba Satellite A75-S226 Notebook Logo
1,002 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
