Question about Asrock 845GV (P4I45GV) Motherboard
PC Getting restart after installing RAM of different speed
MyPC is getting restart everytime I put on, few after installing 512MB RAM with 400 MHz Speed. As per installation guide my motherboard (Asrock 845GV) supports RAM with speed 333MHz. My delear said that it will support. Please help me what should I do, what could be the problem ? Is my RAM faulty ? or my motherboard doesnot support high speed RAM ? My dealer says to change Jumper setting. Please help.
    Problem Solver:
  • 5 Answers
1. Make sure the memory is seated firmly in the motherboard and the clips are fastened. 2. When it boots up try to hit the key to get you into the CMOS setup screen. If you make it in the CMOS setup save and exit. 3. Follow the motherboard instructions to clear the CMOS. Involves jumper or removing battery etc.. the process varies with manufacture and model. If it starts working check the capacitors on the motherboard to see if they are blown on the bottom, leaking brownish gunk or bloated. 4. Put the old memory back in and see if it works normally. May not be compatable or backwards compatible.
Posted on May 15, 2007
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
I have 2 pcs of RAM, 512MB and 1GB. then my pc has 4 slot. Can I install both 1GB and 512MB?
yes you can install it but issue is that . Is your computer supports the both bus peed first check the bus speed for checking bus speed you can see a steker on ram on that print will start form like
512. 400. its it speed is 512mb and buss speed is 400
if your 1gb ram is also 400 bus speed its mean it will run your computer smoothly.
if buss speed is change so you will face trouble. so please confirm the bus speed first thanks
Jul 16, 2011 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Memory is not compatible to motherboard
You might want to go into the motherboard BIOS and change all of the memory timing settings to AUTOMATIC. The settings that are currently configured may be set too high/fast for the new chips.
There are many different specifications/speed settings that can differ from memory chip to memory chip, even within the same general MHZ category (Like your DDR 400)
Jan 04, 2010 | ASUS P5PE-VM Motherboard
Restart computer even when bios is open
Check your Processor cooling system.If the cooling is not proper or if the processor is not working properly then the system will restart on its own with in few minutes of boot up process.Also check if there is any infection.
Jul 10, 2009 | Intel Computers & Internet
I have a GA8ST800 board and I have have been running 256MB ram at 266MHz. I fitted a 512MB ram at 400 MHz. The two together would work fine, even though they were running at 266MHz. I bought two 512MB...
The RAM speed of the new chips is too fast. You need the slower either 266mhz or 333mhz RAM speed to make your system stable again. Hope this helps.
Dec 27, 2008 | Gigabyte GA-8ST800 Motherboard
OptiPlex GX270 mini tower
Remove the 256mb memory and insert the 512mb memory in slot1 and see whether it works. Please note that the memory needs to be in pairs.
I think the GX260 is mini tower has two different moles
1) PC3200 compatible with memory - 184 Pin DDR3200 400MHz
2) PC2700 compatible with memory -184 Pin DDR2700 333MHz
Please enter the service tag on dell.com and find the manual and the right memory for your PC
All the best!
Dec 17, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Ram problem
1)not all rams are dual compatible 2)did u try both sticks separately? (1 may be damaged) 3)are they exactly the same? CAS, voltage, etc..? Sometimes different CHIPS cause trouble 4)try changing to 333 mhz if it works, go back to 400 and try either CAS 3.0 (assuming auto is 2.5 or lover) if not working yet, try the "T" seeting to "1". If your BIOS doenst show this setting and is AWARD, after getting into it with DEL, press CTRL+F1 and then look which setting came from the dark... (hidden settings) on Gigabyte boards for ex. it has to be done.
Jan 23, 2007 | Asrock 775i65GV Motherboard
Asrock 845GV (P4I45GV) Motherboard Logo
263 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
pankaj rautela
pankaj rautela
Alun Cox
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
