Question about HP LaserJet 4200 Printer
13.02.00 jam inside top cover - HP LaserJet 4200 Printer
4 Suggested Answers
SOURCE: paper jammed problem 13.05.00 JAM INSIDE TOP COVER
It happens form both: manual feed and tray... sensors don't look misplaced.
Posted on Jan 17, 2008
  • 398 Answers
SOURCE: 13.20.00 Jam in top cover area, no jam
pull your fuser out and you will find the jam and reason for the noise. it is pulled from the rear 2 covers and 2 screws
Posted on Jun 23, 2009
pineworks
  • 4041 Answers
SOURCE: 13/20.00 jam inside top cover message and have
Hello there
Ok try this may cleaer it.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 09, 2010
How do I get jammed paper out of the back of it?
This is from the user guide available on the HP.com website:
This section contains the following topics:
• Clear paper jams
• Avoid paper jams
Clear paper jams
Paper jams can occur either inside the printer or in the automatic document feeder.
CAUTION: To prevent possible damage to the printhead, clear paper jams as
soon as possible.
TIP: If you notice poor print quality, clean the printhead. For more information, see
Clean the printhead.
Use these steps to clear a paper jam.
To clear a jam inside the printer
1. Remove all media from the output tray.
CAUTION: Trying to clear a paper jam from the front of the printer can
damage the print mechanism. Always access and clear paper jams through
the automatic two-sided printing accessory (duplexer).
2. Check the duplexer.
a. Push the button on either side of the duplexer, and then remove the unit.
b. Locate any jammed media inside the printer, grasp it with both hands and
then pull it towards you.
c. If the jam is not there, push the latch on top of the duplexer and lower the
cover. If media is jammed inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the printer.
3. Open the top cover and remove any debris.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and
remove the jammed media, if possible. If not, do the following:
a. Ensure the printer is turned off and disconnect the power cord.
b. Lift the printer off Tray 2.
c. Remove the jammed media from the bottom of the printer or from Tray 2.
d. Reposition the printer on top of Tray 2.
5. Open the ink cartridge access door. If there is paper remaining inside the printer,
ensure the carriage has moved to the right of the printer, free any paper scraps or
wrinkled media, and pull the media towards you through the top of the printer.
WARNING! Do not reach into the printer when it is on and the carriage is
stuck. When you open the ink cartridge access door, the carriage should
return to its position on the right side of the printer. If it does not move to the
right, turn off the printer before you remove any jam.
6. After clearing the jam, close all covers, turn on the printer (if you turned it off) and
resend the print job.
That's about as much as I can find for you. If you look in you user guide which is on a CD that came with the unit, you can go to page 152 through 154 to see diagrams that go with these instructions. Good luck!
Nov 13, 2014 | HP CM749A - Officejet Pro 8600...
I have 5200 hp laserjet printer is a problem 13.05.00 jam inside top cover tell me this problem
A jam has occurred in the registration
assembly area.
1. Press the 'down arrow' to see step-by-step
information.
2. Open the top cover and remove the print
cartridge.
3. Remove all media inside.
4. Lift the metal flap and remove any
remaining media.
5. Verify that the media size matches the
tray settings and the dial on the tray.
6. Reinstall the print cartridge and close
the top cover.
7. To exit, press ? .
Oct 27, 2011 | HP LaserJet 5200 Printer
My HP 8500 a909a states there is a carriage jam. However there is not paper jam. I've tried resetting it and turning off, pluging into wall outlet, removing and replacing the printheads. I think...
Hi, please try this:
a. Push the button on either side of the duplexer, and then remove the panel or unit.
b. Locate any jammed media inside the device, grasp it with both hands and then pull it towards you.
c. If the jam is not there, push the latch on the top of the duplexer and lower its cover. If the jam is inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the device.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and remove the jammed media, if possible. If not, do the following:
a. Ensure the device is turned off and disconnect the power cord.
b. Lift the device off Tray 2.
c. Remove the jammed media from the bottom of the device or from Tray 2.
d. Reposition the device on top of Tray 2.
5. Open the print carriage access door. If there is paper remaining inside the device, ensure the carriage has moved to the right of the device, free any paper scraps or wrinkled media, and pull the media towards you through the top of the device.
6. After clearing the jam, close all covers, turn on the device (if you turned it off) and resend the print job.
Aug 23, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My hp 8500 is saying paper jam but there never was one
This is based on the HP 8500 manual. I hope this helps.
Aug 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
13.20.00 JAM INSIDE TOP COVER
Without seeing the printer or knowing what you have already done....a "13.20 Jam inside top cover" error means that a jam occurred in the registration assembly area.
Remove the toner cartridge.
Remove all paper from inside printer.
You should see a metal flap. That's part of the "registration assembly".
Lift it up and make sure that all paper pieces are removed. Use a flashlight if you can.
Make sure that the media size that you are using matches the tray settings and the dial on the tray.
Reinstall the cartridge and try again.
May 18, 2011 | HP LaserJet 5200 Printer
Paper jam on top cover but ther is no paper on top
check for stuck up key sensor, hook type that detect paper passing, some time that key dislocate.
Apr 15, 2010 | Office Equipment & Supplies
How do I fix a paper jam? I've got paper jam around the exit roller and I can't get it out?
There should be a way to unlock one of the sides. Try taking out the toner cartridge and going in that way. If you can see the paper, get a pair of needle nose pliers and SLOWLY see if you can pull the paper out.
Sep 21, 2009 | Samsung CLP-510 Laser Printer
Jun 23, 2009 | HP LaserJet 4200 Printer
PAPER JAMMED
If you are unable to remove the jammed paper from inside the Automatic Sheet Feeder (ASF) then it is necessary to remove the printer top cover. The ASF is then easily removed by removing three screws, and any jammed paper removed from it.
If you require assistance in how to remove the top cover, please post a new comment to this effect.
Aug 02, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jammed problem 13.05.00 JAM INSIDE TOP COVER
Nov 19, 2007 | HP LaserJet 2420 Printer
HP LaserJet 4200 Printer Logo
202 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
