Question about Invicta Watches
How to set the second hand on invicta 0654 - Invicta Watches
2 Suggested Answers
SOURCE: invicta 6280 , how to
Pull crown to position 1 and change date to yesterdays date , then pull crown to position 2, wind clock untill correct time appears (observe when date switches to observe the clocks am/pm cycle, this is useful to ensure the alarm goes off at the right time of day when set)
Posted on Jan 30, 2011
My invicta reserve second hand does not move
Very often not the second hand, but the seconds hand for the stopwatch. If you are sure it is, then try pulling the crown out, moving the minutes hand and then resetting the crown.
Dec 27, 2015 | Invicta Watches
The second hand won't tick
On many Invicta watches, the large hand which points towards 12 o'clock is not a second hand. It is the hand used with the stopwatch function. If yours is a chronograph, the second hand, if there is one, may be one of the three small dials on the watch face. There are a number of movements used in Invicta watches and the operating instructions can differ from movement to movement. The battery also will be different depending on the movement.
Dec 01, 2015 | Invicta Subaqua Watches
The seconds hand on my invicta subaqua reserve does not move. It only moves when I start the chronograph. I've read the instructions time after time and can not get it to work.
The hand that moves when the chronograph is working is not a second hand. It will rest at the 12 o'clock position unless you are using the stopwatch. If your Invicta has a second hand, it is one of those small dials on the watch face.
May 03, 2015 | Invicta Watches
Invicta 6280 , how to set time and does the large second hand move ?
Dec 02, 2010 | Invicta Watches
The 24hr hand is meant to keep time in another
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
Dec 30, 2009 | Invicta Watches
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
Have an Invicta Lefty Quartz Chronograph. The subdial that marks the minutes fails to reset to 60, though the large second-hand resets perfectly. Recently I bought another Lefty and had the same problem. I...
Actually the sweep arm can be set to 0 and will probably have to be every time you have the battery replaced. To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it. Make sure to set the right time and replace the crown in the time position.
Great watch!!
May 09, 2009 | Invicta Lefty Chronograph Watch with Band...
I have an Invicta 5103 mechanical wind chrono and the large second hand will not zero out on the 12
Dec 02, 2008 | Invicta Dive/Sport - SPEEDWAY CHRONOGRAPH...
Invicta Gran Speedway CG second Hand reset
good after noon ! the hand of your watch is need to aline , so you need to go to the watc repairman,thank you! god bless !
Sep 03, 2008 | Invicta Speedway Collection Grand...
Watches Logo
26 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
