Question about Linksys WRT300N Wireless Router
Linksys wrt300n won't reset - Linksys WRT300N Wireless Router
5 Suggested Answers
33mlake33
  • 142 Answers
SOURCE: Linksys Wireless WRT300N
Try going to the configuration page and check if it is sending a wireless signal.
Posted on Dec 30, 2008
  • 177 Answers
SOURCE: my wrt300n power led is blinking and the rest of
Hi Friend
Please follow the steps to reset the router in a different way
1) Press the reset button for 10 secs and after that unplug the power cable from the router and wait for 10 secs
2) Plug the power cable back and press the reset button again for 10 secs and after that unplug the power cable from the router and wait for 10 secs
3) Plug the power cable back and press the power button for 10 secs again and unplug the power cable from the router for 10 secs
After trying these steps if you see the power light still blinking then you need to replace the router. Please call the customer care of linksys 1800 546 5797,they will let you know how to replace the router
warm regards
Chiranjeet Mitra
Posted on Oct 09, 2009
sweetlady105
  • 36 Answers
SOURCE: My linksys WRT300N router is Not working. The
Hi, we can hard reset the router for about a minute, powerlight should be blinking the moment we reset the router, if case still all lights are lit but powerlight is solid. We can do these steps:
> Connect computer to router
> Open control panel - network connections - right click local are connection
> Click status and go to support
> Check for IP address, if we have IP: 192.168.1.x IP address on the computer
> Please open command prompt
- (for WinXP) go to start and click run, type cmd
- (for win7 and winVISTA) click start and type on start search cmd
> On the black screen, there is a blinking cursor type ping(space)192.168.1.1
> If we are getting Request timed out - that means router is defective
- if we are getting Reply from responses... then there is a need to upgrade the router...
Let me know if you still need help...
Posted on Dec 22, 2010
  • 3 Answers
SOURCE: My Linksys WRT300N Router is
Have you run the Setup CD that came with it?
If so, then I suggest resetting the router by pushing the reset button. Download the latest firmware from Cisco and then connect to it by opening your browser on a hardwired (direct connected) computer and typing 192.168.1.1 in the command line. From there you will enter the usual USER name of "admin" without the quotations. Upgrade the firmware and you should be set. You may need to teak the settings a bit to get what you prefer from your router, but that is personal preference.
Linksys WRT300N router flashing all lights
On the back of the router you will see what looks like a pin hole, turn the router on and use a paperclip to push into the hole(it's a reset button) and keep it pushed in till the router cycles off then on again, it resets the router to default. Hope this helps.
Jul 01, 2017 | Linksys WRT Computers & Internet
Am using Linksys WRT300N v1.1 wireless router but all LEd are glowing except power led. and i am unable to connect through wired ethernet ports and also wireless is not working.
Try to reset the configuration of your router from the reset button and try that you getting the console with its default username and password.
Jun 18, 2011 | Linksys WRT300N Wireless Router
WRT300N: does not boot, all leds are lit
Solution 1.
How can I reset the Linksys WRT300N to factory defaults?
Hold the Reset button on the Linksys WRT300N for about 30 seconds.
What is the IP Address, Username and Password to log in to the WRT300N?
IP Address: 192.168.1.1
Username: none
Password: admin
You should also know the configuration of your ISP provider after reset. You'll need to re configure your connection from modem to router.
Solution 2
How do I upgrade the Firmware on the Linksys WRT300N?
# 192.168.1.1 -> Administration tab -> Firmware Upgrade sub-tab. Click "Browse" and browse to the firmware upgrade file on your computer. Click "Start to Upgrade". Do not reset or power cycle unit while it is upgrading.
Username: none
Password: admin
Apr 10, 2011 | Linksys WRT300N Wireless Router
My WRT300N Linksys router shows all lights, I've hit the reset button onece, but I can not get online without plugging the cable directly into my computer.
Since you hit the reset button on the router, it will go back to default settings.
By default, the SSID is linksys and the wireless security is disabled.
So on the wireless network connections on your computer, you should see linksys and then just connect to it.
However, it is advisable to change the default SSID and to enable the wireless security.
Follow this link to change the SSID.
Follow this link to enable wireless security.
Dec 30, 2009 | Linksys WRT300N Wireless Router
I just rewired all my network connections, my wrt300n wireless indicator is not lit. The network is set up on a linksys broadband router on a cable modem and wrt300n was functioning properly when it was...
Try first resetting the router by pressing the reset button of the router fro 10 seconds while power is ON and then after that reconfigure the router.....
Dec 07, 2009 | Linksys WRT300N Wireless Router
Hi there, my router has all its lights on with only the power cable connectedmodel is linksys wrt300n
switch off the rotuer and plug out the cables and reconnect them again and turn on the router and then check. OR reset the router and reconfigure it again.
Nov 19, 2009 | Linksys WRT300N Wireless Router
My wrt300n power led is blinking and the rest of
Hi Friend
warm regards
Chiranjeet Mitra
Oct 06, 2009 | Linksys WRT300N Wireless Router
Dec 24, 2008 | Linksys WRT300N Wireless Router
What happens when i reset?
yes it will reset the network name and ssid ... as well as the configuration of your router ...
Nov 16, 2008 | Linksys WRT300N Wireless Router
Wrt300n password
Try using "admin" as username & password.
-mrsolution
Jun 11, 2008 | Linksys WRT300N Wireless Router
Linksys WRT300N Wireless Router Logo
19 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
