Question about Kyocera Zio M6000 Cricket
How to unlock the lock pass code on a sanyo cricket zio M6000 touch screen cell phone
How to unlock the pass lock code on a sanyo cricket zio M6000 FCC ID: V65M6000 touch screen cell phone
  • 60 Answers
SOURCE: I powered on my sanyo
Take your memory card out of phone. You will need to do a hard reset. This will wipe anything you have downloaded to the phone itself so keep this in mind. With phone off hold your green and red buttons down along with the volume down "at same time" until the phone powers on. This will reset your pbone back to when you first got it.
Posted on Aug 25, 2011
  • 20 Answers
SOURCE: unlock
sometimes the code can be the last four #'s of the cell number
Posted on Jan 29, 2010
ginko
  • 19396 Answers
SOURCE: my kyocera zio m6000
Try the following.
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If no luck, try doing the following:
  1. Remove battery and put it back after two minutes
  2. Press and hold down the home button key while turning on the phone.
  3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
  4. Call Kyocera directlyand report the problem.
Posted on Sep 03, 2010
  • 60 Answers
SOURCE: I have a Sanyo Zio
You need to reset phone. Hold green,red and volume down at same time with phone off. Make sure that if you have a memory card that you take it out first. This will clear the lock code and reset your phone to factory settings.
Testimonial: "Thank you for the help. Awesome"
  • 11 Answers
SOURCE: my kyocera sanyo cricket phone
Hard Reset.
1. Turn off the phone
Phone is completely reset as if it came out of the box. You'll need to *228 and reload ALL of your data.
or WARNING: This process will clear all user settings and downloaded apps. Data on the SD Memory Card and My Backup will be retained. Prior to following the steps below, ensure the phone is powered off.
a)
b)
Procedure,
8. Allow the phone to completely reboot. This may take a few moments.
9. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
NOTE: If you receive a self-test screen or blue screen, the hard reset was done incorrectly. Please try again, from step 1.
Posted on Sep 12, 2011
What is the code to unlock sanyo zoi m6000
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Oct 18, 2012 | Sanyo Zio M6000
How do i reset a kyocera zio m6000 phone?
Hard Reset --> Dial ##4357* nd then type code 000000
Or Else
Menu-->Settings-->Factory data reset-->Reset Phone
Sep 04, 2012 | Kyocera Zio M6000 Cricket
HOW DO I UNLOCK MY SANYO ZIO?
You have to do a factory reset (This will erase all your data from the device)please refer device manual for factory reset method.
Jan 31, 2012 | Sanyo SCP-8600 (Zio M6000) Silicone Skin...
How do i unlock my phone
Try code from Online site and unlock it from Network lock.
Jan 24, 2012 | Kyocera Zio M6000 Cricket
Phone is locked
u cAN PAY TO GET AN UNLOCK CODE OR GET A FREE ONE OF THE NET
Dec 16, 2011 | Kyocera Zio M6000 Cricket
I powered on my sanyo zio kyocera phone and almost all of my apps were missing including settings, dialer, and more, I turned my phone off and then back on and it goes to the screen that says cricket and...
Aug 25, 2011 | Kyocera Zio M6000 Cricket
How to unlock a sanyo zio Phone from cricket
Sorry It's CDMA Network So you cannot..............
Jul 19, 2011 | Sanyo Cell Phones
I am locked out my phone and i want to know how to unlock it
you can get the unlock solution from the service provider......
Jul 11, 2011 | Kyocera Zio M6000 Cricket
I have a sanyo kyocera m6000 when i turnon the phone it only goes to kyocera it dont go farther then that
sounds like a software problem try hardreseting
Feb 28, 2011 | Kyocera Zio M6000 Cricket
I have the sanyo kyocera zio and it won't turn on at all. It just shut down by itself.
Hi Penn,
My name is Ryan and I work on behalf of Cricket. Does this happen while charging the phone via power outlet? Be sure that the battery is fully charged and please try removing battery and with a clean smooth cloth, wipe the battery connection points on the battery and back of cell phone device. Replace and turn back on. If you continue to experience issues, please visit a full service corp. Cricket store location for hands and assistance.
Best,
Ryan on behalf of Cricket
Feb 22, 2011 | Kyocera Zio M6000 Cricket
Kyocera Zio M6000 Cricket Logo
21 people viewed this question
Top Kyocera Cell Phones Experts
Sue Hale
Level 1 Expert
Shane Martin
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
