Question about Vizio Televison & Video
Vizio sound bar not sync with tv sound
Sound bar and tv speakers are not muting together
SOURCE: Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Posted on Feb 21, 2009
  • 4 Answers
SOURCE: dell 32' lcd
I have the exact TV with the same concern. I disassembled my set and removed the sound module to verify part numbers. The cheapest one I could find was on eBoob for over $100.00. My solution was to buy an inexpensive sound bar at Radio Shack and install it. Very simple to connect and it sounds fine. I wouldn't suggest putting money into a low quality TV like the Dell, another board may blow out at any time per several techs I talked to.
Posted on May 07, 2009
budmrtn
  • 11361 Answers
SOURCE: loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 22, 2009
  • 8457 Answers
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Posted on Apr 07, 2010
SOURCE: No sound on my Sanyo LCD 32" flat screen tv
I had this same problem this morning. Luckily, when I reset the whole thing and did the channel search again the sound returned. I have no idea why it fixed it but it did. Hope this helps you.
Posted on Oct 11, 2010
The vizio amp speaker plugged into my tv and bluray player stopped outputting sound when watching a dvd and now only blinks in a set of light at the bottom. What does this mean and how can I fix it?
TV sound bar problem - Audio - Audio - Tom's Guide
www.tomsguide.com/answers/id-1991267/sound-bar-problem.html
Jan 23, 2014 - I recently purchased a Vizio E Series Razor LED 60" tv for my home, and ... The TV plays sound with built in speakers fine, ... on the source playingthrough the tv, if via hdmi, the soundbar would ... Alright I plugged it in but still nosound. ... the tv hooked up yet but my bluray player runs off HDMI and my xbox ...
No Sound Thru Speakers (only sound thru TV) - VUDU Forums
https://forum.vudu.com/showthread.php?...No-Sound...Speakers...sound...
Jun 18, 2011 - 10 posts - ‎8 authors
Just purchased and connected an LG wireless internet-ready TV to a receiver, a DirectTV HD DVR satellite box, and surround sound speakers. ... Cable, Blueray player, and others internet services, like Cinemanow provide ... because i have a Vizio Soundbar 210WS model, and i have to go into the TV ...
Jan 01, 2016 | Vizio VSB210WS Soundbar
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
New vizio tv and vizio sound bar,I have sound from tv but no sound bar sound.
get to your menu on the tv and click your audio, go down to speakers and turn it to the off position.
Jul 09, 2011 | Vizio VSB210WS Soundbar
Tthe sound wont play on my new vizio 3d tv
  1. Check your connection from the TV Audio output to the Bose Input, and make sure the TV is not muted.
  2. In the TV's Sound/Audio menu, configure the TV to output the sound to External Speakers, not the internal speakers.
  3. Make sure the Bose system is powered on, and not muted.
Mar 12, 2011 | Bose Lifestyle 48 System
I have picture but no sound. Checked for mute button, increased/decreased volume, unplugged tv and still nothing.
some sets will have an option to turn off the speakers (different from mute); this is used when you want your tv to output to a sound system with external speakers. check your menu settings for something which disables tv speakers--that is probably your issue.
Mar 06, 2011 | Vizio VO320E LCD TV
Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Aug 20, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
368 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
