Question about Toshiba e-Studio DP170F Plain Paper Laser Fax
"Broken Registration" I have a toshiba e-studio170F----it's not getting or sending faxes. The screen pops up with "Broken Registration press stop". What does that mean?
  • Toshiba Master
  • 643 Answers
U need to press "STOP" to return to idle state.
If this Error Message is repeatedly displayed, machine programming
has become corrupted.The machine must be re-initialized.
Pressing *13 and ON the machine, it will re-initialized the fax.
Posted on Feb 26, 2009
We have moved office and we now need to programme our new fax nbr on our canon L350 fax machine. can you pls assist and oblige. brgds, hushidar bhathena
Hi!On the right side of the control panel is a flap that u can pick up!(the one with the speed Dial numbers on)Ther is a button that says DATA REGISTRATION,Press it and on the screen it will say DATA REGISTRATION,press set,it will say USER SETTINGS,press set,It will say DATE AND TIME,Use the arrows down to get UNIT TEL NUMBER,press set and type in your new number,press set and stop and there you go!Good Luck!
Nov 10, 2010 | Canon Office Equipment & Supplies
E-Studio170F drum warning changed drum and still get warning
You need to reset the drum count on the machine. To do this press [MENU], [5], [2], [04] then when it says reset drum count use the up or down keys until it says yes then press enter.
Jul 27, 2010 | Toshiba E-Studio 161 Copier
How do i get a fax confirmation to print?
Press function then data registration and set/ok.It will say user settings,press the arrow down to get report settings,press set/ok,it will say tx report press set/ok and use the arrows to get output yes,press set/ok and stop!It will print one after every fax u send!Enjoy!
Apr 29, 2010 | Canon FAXPHONE L80 Laser
Not getting fax report and want to set time and date on l80 faxph
Press functionand then data registration,press set/ok and it will say user settings,press set/ok and it will say date and time,press set/ok and type in the correct date and time press set/ok and stop!To get the report press function and data registration and set/ok,use the arrow down and scroll to report settings,press set/ok and it will say tx report,press set/ok and use the arrowdown untill u get output yes!Press set/ok and stop!Enjoy!
Apr 24, 2010 | Canon FAXPHONE L80 Laser
How do I get a receipt with each fax I send?
Open the One-Touch Speed Dial panel. Press the Data Registration button. Press the Set button. Use the down arrow to select 2.REPORT SETTINGS. Press the Set button, then use the down arrow to select 1.TX REPORT. Use the down arrow to select OUTPUT YES. Press The Set button. Press the Stop button to return to standby mode. Pages 15-5 and 15-6 from the Users Manual.
Mar 09, 2010 | Canon LaserClass 2060P Plain Paper Fax
After sending a fax, the screen keeps popping up with memory tx... what does this mean? Did my fax go thru?
No, it did not go through, it keeps trying to send it until you press STOP while it is redialing.
Oct 01, 2009 | Canon LaserClass 2060P Plain Paper Fax
Dp80f
send 100$ tack solution
Apr 12, 2008 | Toshiba DP80F Printer
Canon LaserCLASS 710 Fax Owner's Manual
Set Speed Dial / One-Touch Feature
  1. Open One-Touch Speed Dialing Panel and press “Data Registration.”
  2. Under “Additional Functions” scroll to find “4. ADD. Registration” and then press “Set.”
  3. Scroll to find “1. 1-One-Touch Speed Dial” and then press “Set.”
  4. Under “Tel # Registration” scroll until the desired “One-Touch” number is displayed. Press “Set.”
  5. Under “Tel # Registration” scroll to find “1. Tel Number Entry” and then press “Set.”
  6. Under “Tel Number Entry” enter fax number (with “9” and the area code – ex. 913104454200) and then press “Set.” Screen will display “Data Entry OK.”
  7. Under “Tel # Registration” scroll to find “2. Name” and then press “Set.”
  8. Under “Name” enter the company name and press “Set.” Screen will display “Data Entry OK.”
  9. Press the red “Stop” key on the main control panel.
  10. The “One-Touch” feature is now set.
Label corresponding “One-Touch” button with company name.
Jan 30, 2008 | Canon LaserCLASS Fax 710 Printer
How to change the sender's info
Lift the panels on the keyboard. press data registration and press set. press set again and use the down key to scroll user name and set and press the clear button and you can enter the new name by using the numericals keys corresponding on the alphabet like your cell phone. when finished press set and press the down arrow to tel number and press set. press clear and enter your fax number. and press set when finished and press stop.
Aug 16, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
Speed dials
I'm not sure if this will help because I haven't seen a 2060 control panel but most Canon fax machines use the same process. Press either "menu" or "data registration" button. (Again -I'm not sure of 2060 control panel.) Display should read "user settings" Press the "down arrow" (looks like an upside down triangle) until the display reads "tel settings" Press "set" Display reads Speed Dials Press "set" Display should give the # of the speed dial (ie. Speed Dial 01) Press "set" Display reads "tel number" Press "set" input # you want to send faxes to Press "set" Display reads "Name" Press "set" use letters on keypad to input receivers name (ie. For letter "C" press #2 three times, you may have to use the arrow keys to move the cursor for names such as BC Corp) Once name is input - you guessed it- Press "set" you will now be presented with various other send options which most people/businesses never use. You can hit stop to return to normal mode. After inputting speed dial #'s & names,you can print a list of what you have input by getting back to the "Tel registration" screen & pressing the report button. I can be reached @ bspier@carlsonsupplies.com if you need more assistance. Good Luck!!
Jun 09, 2007 | Canon LaserClass 2060 Fax
Toshiba e-Studio DP170F Plain Paper Laser Fax Logo
203 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
