Question about Maytag MER5870 Electric Kitchen Range
Maytag MER5870 F9 code and door locked
Performed a self clean which stopped after 2 hours and error F1 appeared and door is locked. After leaving unplugged overnight it now has F9 error code and door is still locked. Opened back panel to unplug touch pad ribbon connector but can not remove without force. Do not want to damage. Does anyone have any advice or pictorial of panel?
3 Suggested Answers
catriver
  • 878 Answers
SOURCE: F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Posted on Jun 05, 2007
SOURCE: Maytag Oven MER5770AAA gives F9 code and won't
F9 is a door latch problem.Check the door latch components.It actually means that the machine is not detecting the door closing.There might be some purchase of parts to rectify this problem.
Posted on Apr 10, 2009
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F9 error code appears within two hours of self clean cycle
F9 error code on GE ovens is usually caused by a problem in the door lock/latch system for the self clean. You state it happens about 2 hrs into the clean cycle. My guess is the the control is not sensing that the door is actually locked. Could be several reasons. Bad door lock motor, Bad switch that senses the door is latched, or is some cases the main control board could have a problem and is just not reading the door is locked. You need someone with the right knowledge to trouble shoot which part is actually bad since it could several different problems.
Mar 10, 2015 | GE JTP75 Electric Double Oven
Maytag range model mer6750 - I tried to open the oven door too soon after a self cleaning cycle Now door won't open and fault code F9-2 appeared. What to do? THANK YOU
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
F9 Door Lock Warning Check door lock circuit or Replace Clock
F-2 Oven temperature sensed by electronic control Replace the clock/relay board.
Here is the part you need to order.
May 18, 2013 | Kitchen Ranges
While self cleaning, we experienced a power surge. now the doors will not open and we can not get it to reset. F9-2 is the error message.
Hi happytrailri,
The F9-2 error code is a Latch, Unlock Upper. Check for obstruction in door lock mechanism.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Jul 10, 2011 | Maytag MER6772 Gemini Electric Kitchen...
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
Kenmore Electric Range model 790 has F9 & F1 code error
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 20, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F9-4 when cleaning upper oven
its related to the self clean ltach motr, if you pull hte unit out and drop teh rear panel, approx halh way down on theright side( when behind unit) thers asmall lock mechinisn mavbe 1.5 round, with a connecting rod 2 wires and a witch, well that motor sometimes as it heats looses connection with the switch. the switch is monitoring door positoin so if it loses contact it thinks the door is open and will trigger a code. the entire latch is replacabel (FRont to back comesa sone assy latch motor swittch and rod. 2 wires connect it and 2 screws(by front latch secure it. if youtry to replaceit your self i giveyou the heads up to lie a yard stick on top of latch before removing old latch (thos will keep the insulation in place) andthen when installe ing new latch also use hte ayrd stick ontop to keep insulation inplace!!!!!
Feb 24, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER5870 Electric Kitchen Range Logo
74 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
