Question about Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch
Tag heuer carrera - does not work timely !!!
I have just purchased a TH Car and winded it for the first time 45 times. However, after 2 weeks the watch still run slow meaning that it is off 5 to 20 minutes a day. How can this occur ? Is there a fix or do I use the TH wrongly.
Many thanks in advance for your responses.
Best wishes,
  • filip_vanbra Jan 04, 2009
    Many thanks for your effective reply. What does overhaul mean ? Thanks again. Cheers, Filip
  • jer5 Mar 12, 2009
    i have the same problem as filip but mine is worst it will slow down a few hours a day and some time it even stops. Is it caused by the weather cause the place i live in is pretty cold like 9degreesC
  • 2,334 Answers
There is no reason to panic. Your watch needs overhaul. Find your nearest watch repairer and ask to do the job. He will be able to tell you if there are any mechanical faults.
I do not think there are any and your watch will tick as brand new after overhauling it.
Mechanical watches needs overhaul every 5-7 years.
Posted on Jan 03, 2009
  • Arturs Kalnins
    Arturs Kalnins Jan 04, 2009
    It's the same as you would be servicing your car (changing oil, filters, cleaning bits, etc).
    The only difference is that the watch movement is thousands of times smaller and much trickier to do, requires great skill and patience and protective (completely clean and dustless) environment.
How do Iset time tag watch carrera calibre S
Very good video of this on youtube.
Good luck, as the guy on the video says it is complicated!
Oct 18, 2014 | Tag Heuer Carrera Watches
How do I wind up my tag carrera automatic using the crown??
Wow, how wrong yall are.
There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
Feb 24, 2011 | Tag Heuer Automatic Chronograph Series...
Hi, My TAG has been in and out of service three times, the hands came off, the winding mechanism stopped working and the tertiary timing hand has come away this week. I wear it for work [in an office]...
I have this same exact watch with the same problem. In November of this year, my watch just stopped with an inability to autowind itself. I'm a little mad because I have babied this watch, while only wearing it on special occasions (10x). What's the problem?
Nov 21, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Looking for an owners manual for my Tag Heuer
Go to the TAG web site ( insert "" into your search engine).
Select "Carrera"
Select "men" or "women" as appropriate.
Select the model of the Carrera you have.
On the right of the screen you will see a list of options, select "user manual"
Adjust the magnification to make the text readable.
Jan 11, 2010 | Tag Heuer Carrera Twin Time WV2116.FC6181...
Tag heuer automatic series, how do you start the watch after purchasing?
push the crown in if it is in the adjust position .then shake the watch around the auto mechanism sould start the watch
Aug 23, 2009 | Tag Heuer Automatic Chronograph Series...
TAG Heuer Carrera Calibre 16
This is a warranty issue, the watch should not lose time like this. Take it back to the supplier ASAP
Jun 21, 2009 | Tag Heuer Link Automatic Chronometer...
Tag heuer carrera automatic wv211a
Your watch is a automatic. All automatics need to wind-up before being worn at first , or if not worn all the time. Automatics will work with-out being wound ,but will not keep time. Wind your watch at least 50 turns (using the crown) or shake about 150 times , and then try it . Automatics need that back-up power to insure it's accuracy.
Jun 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Open Questions:
See all Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch Questions
Tag Heuer Carrera Auto CV2113.FC6180 Wrist Watch Logo
824 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
