When cutting or ripping, the blade wabbles and I have tightened it but nothing changes?
Dont wast any more time, blade has been damaged by a hard knock or heat! buy a new blade and check shaft allighnment! (some blades need a spacer if not genuine or will wobble and some blades are **** for no reason- even pricey ones) good luck
This could be caused by several problems. First unplug the saw. Put a known straight edge against the blade (making sure not to contact the teeth) turn the blade slowly and watch for runout. Second make sure the spacers and blade flanges are on correctly. I would just about think it would be the blade. If you provide the model and brand I can do some more research. Good Luck
