Question about Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E
I have a DL7000 Dewalt generator, my son while helping put diesel fuel in the tank. I have drained the tank, changed the oil, cleaned out the carb. and re assembled all parts. I even changed the spark plug, the unit will not fire. What am I missing?
2 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: My DeWalt dg7000 generator shuts down after
Try clean a clogged carburetor / gas filter!
Posted on Oct 25, 2010
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow...
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Jul 20, 2011 | Pramac 5000 Watt Generator
I accidently put diesel in my John Deere riding lawn mower. How do I safely drain the tank. Or do I need to take the tank completely off? If so I need directions.
If you did not try to start it, you will need to siphon, pump or **** out the fuel tank. The last J.D. that I emptied the tank in I used a turkey baster to draw out the bad fuel. I guess you use what you got. Hopefully your fuel is pumped to the engine and the fuel line goes into the tank from the top. If so all you have to do is empty and replace with gas. If the fuel line drains the tank from the bottom and/or you tried to start it with diesel in it you will need to (after emptying the tank) remove the fuel line from the carb. and direct it to a container, remove the bowl nut of the carb. to drain carb. be ready to clean up a little spilt fuel catch if you can or have rags under and ready. Turn the ignition key for engine to turn over to operate the fuel pump and clear the line. Put a little gas in tank and flush fuel line by using fuel pump to clear. Change fuel filter and put everything back together. Remove and clean/replace spark plug. Test it. Inspect spark plug again if necessary.
Jul 07, 2011 | Garden
What servicing can I do for my generator which has not been used for 2 years now YAMAHA GENERATOR EC5000DVE
change the spark plug clean the fuel tank replace filters and oil change fuel line if cracking or stiff.
remove carb bowl clean out with carb clean remove any sch-lack from old gas run and test power.
hope this helps
Aug 28, 2010 | Yamaha 4500 Watt Electric Start Generator...
I have a craftsman DLS 3500 and my son put 2 part mixed gasoline in it and now it will not start. What should I do?
disconnect the fuel line at the carb and let it drain into something, then remove the screw(bolt) in the center of the fuel bowl and let the gas drain out...once it all removed, put the screw back in and hook the line back up..then remove the spark plug and use carb cleaner or something similar to clean the plug ...before you stick the plug back in after you have clean it, turn the engine over a few times to expel the gas oil mixture....refill the tank and try and start as normal...its probably going to some for a little while till all the oil is burned off
good luck
bill
Aug 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Generac home generator does not start. It starts alittle bit but then dies. Maybe runs for 4-6 seconds
is this unit diesel or gas? If its gas driven, the carburetor needs to be removed and cleaned out. Also make sure your gas is fresh. If not drain fuel tank, remove carb, clean out, re-assemble & test. Check fuel filter, oil level.
Feb 05, 2010 | Generac 13,000 Watt / 13,000 Watt Home...
How to drain ford fusion fuel tank
The "MOST EFFECTIVE
" way is to REMOVE The FUEL TANK and DRAIN it By Tipping it over to Pour From FUEL INLET HOSE. Im Sure you Dont want to Here this as it Requires Much WORK . , BUT It IS The MOST EFFECTIVE Way to EMPTY The TANK.
Oct 31, 2009 | 2004 Ford Fusion
Gas in crank case!!
I've seen this many times, you've got fuel system problems.
Here is how to fix this yourself.
1) Drain out all of the oil that has the fuel in it and dispose of it in an EPA friendly way.
2) Take the fuel supply line off of the carburetor and drain the fuel out of the tank into a clean plastic container. You want to get the tank as dry as possible, so tilt and shake the generator or whatever you need to in order to get everything out of the tank. Look at the stuff that drained into the container, if it looks like Italian dressing or has a layer of stuff at the bottom of the container get rid of it just like the oil.
3) Get a flashlight and look at the inside of the fuel tank. You're looking for rust, bits of debris, and anything else that may have found its way in there. A clean fuel tank is a happy fuel tank.
On some generators there is a metal shutoff valve at the bottom of the tank where the fuel line goes to the carb that has a removable "cup" at the bottom. If yours has one you should take it apart, gently clean it, and reassemble it. you don't have to remove the valve from the tank to do this.
4) Take the bowl off of the carb. The exact procedure for this will vary with the model of generator you have but the point is to find out just how much crud is in the carb causing the float to stick and let fuel get into your crankcase. Be gentle with the carb parts, it's easy to stretch the rubber bits without meaning to do so. The decision you have to make at this point is whether you're going to try and clean the original carb or just get a new one. If the carb looks badly crusted up with stuff, or if I can see obviously broken parts I go find out how expensive a replacement is, often it's less than $100US so I replace the carb to avoid charging the $100 to clean the old one.
5) If you've opted to try and clean the carb take it off of the engine, spread out a clean shop towel, and disassemble the carb as far as possible. I try to put the parts down on the towel in the order I took them off as sort of a hint as to where they came from. If you're really careful you can probably just reuse the parts of the carb, mostly the rubber and fiber gaskets get damaged in disassembly and have to be replaced. Poke a small wire thru each of the holes in the carb body, especially the tiny ones inside near the engine side of the body. I use a cut down piece of an old antilash spring for this job, you should use whatever works without making any of the holes you poke get damaged. Blow compressed air thru all of the holes in the carb, when you blow air thru the fuel inlet seat do it from the inside of the carb towards the fuel tank to avoid dislodging the valve seat if there is one.
Inspect the needle valve for signs of wear, damage, or excessive "ringing" that could make it leak.
Float the little float in a pan of water, submerge it all the way under and look for bubbles.
Once you've got everything shiny clean and nothing is broken, put it all back together. Again be careful with the orings and gaskets as they are annoyingly fragile.
6) Now that the fuel tank has had time to get dry inside, inspect it again. blow it out with compressed air, keep your face away from the fill tube when doing this to avoid debris in your eyes, WEAR EYE PROTECTION, put your hand over the fill tube with the fuel valve open and blow air between your fingers to gently pressurize the tank so you can check for big leaks, this also blows out the fuel line.
7) Put the fuel system back together starting with the carb and working back towards to fuel tank. Check the end of the fuel line for cracks before reassembling it onto the carb. If there are cracks you can someitmes trim off a bit of the fuel line. If the fuel line is at all worn consider replacing it, fuel line is usually around $2/foot so it is cheap and easy.
8) Put clean fresh oil back into the engine, remove inspect and perhaps replace the spark plug. It is way better to just replace a suspect plug than to try and clean it.Leave the air cleaner element and cover off for now.
9) Put in fresh fuel, open the fuel valve and wait 5 minutes. Look down the carb intake as see if there is fuel pouring out where it shouldn't, if there isn't check the oil and smell for fuel. If you've gotten this far with no problems reassemble the air cleaner and cover, apply half choke and try to start the engine. If it starts you're done, shut off the fuel valve and let the engine run until it starves for fuel and dies, this keeps our newly cleaned carb from getting dirty quite as fast. You might have to use full choke for a few pulls to get the engine to start the first time.
10) If the engine won't start, get some carb cleaner or brake cleaner and spray it past the carb into the intake, a one sec blast is enough. Pull the rope and see if the engine fires at all, if it does you've still got fuel systems problems and have to systematicaly check everything again, if it doesn't at least make some sort of detonation you've got some other problem to find.
Regards,
Carl
Dec 14, 2008 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
My son just called to say he put diesel in the tank. He hasn't started it yet. Is there a drain on the fuel tank or does he have to siphon and then use rags to soak up the rest?
Hi and welcome to FixYa,
Initially, what could be suggested are:
  • remove the fuel hose end connected to the carb;
  • fit that freed end to a suitable container;
  • depending on the version, PRI setting of the fuel valve/control would make the fuel in the tank to flow;
  • if PRI is not available, the smaller hose leading to the carb/rubber coupling from the valve would have to have a vacuum to enable fuel flow;
  • alternately, the entire tank could be removed and inverted to remove the fuel inside;
  • there are drain screws at the very bottom of each carb to remove the fuel inside the bowl;
  • flushing the tank with gasoline would help after diesel removal;
  • if diesel was removed and replaced with appropriate gasoline, it is possible bike may run a little rough for a bit of time;
  • your suggestion of siphon will work, no need for the rag (though not a bad idea).
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | 2002 Suzuki GZ 250 Marauder
Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E Logo
20 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
Jay Plesset
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
