Question about Whirlpool GS5SHAXN Side by Side Refrigerator
No water to ice maker
I am not getting any water to the ice maker but plenty of water to the water dispenser on the door, is there a way to determine when the water valve to the icemaker should be energized. I need to know how to verify if the water solenoid is being energized or if the valve is just not working.
    Problem Solver:
  • 3 Answers
There is a electric valve to only let so much water at a time ,and each time it dumps the ice that valve opens and lets more water in. The water line from the valve to ice freezing tray could be frozen or pluged. There is a switch when the ice is dropped it turns on the water valve.
Posted on Jan 03, 2009
My Frigidaire ice maker dispenses water when I use the dispenser on the door. I have been told it may be a DIODE issue. Does the LPHS2687KF0 have a diode?
Good Morning Jim,
I understand the ice maker is dispensing water when you use the dispenser on the door of your Frigidaire refrigerator, model# LPHS2687KF0. I also see that you have a Diode kit and are not sure if it would be this that is needed or a water valve that would be needed. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine what is causing the ice maker to dispense water. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire PLHS267ZA Side by Side...
No cold water, ice maker works fine but no water from the door
HI THIS SOUNDS LIKE WATER DISPENSER FROZEN.DEFROST FRIDGE FIRST.GOOD LUCK.ALI
Jun 27, 2012 | Samsung Refrigerators
Door dispenser will not dispense the ice.
you and many others have this problem . ( tip remove bin and rinse out with warm water dry it well and the door area also then the majic ... spray the dispenser with ( pam ) without the butter . clean and slick . this should help . mm
Jul 02, 2010 | Whirlpool ED2FHEXN Side by Side...
Getting no water to ice maker or water dispenser water is getting to the refrigerator
I would check the water supply first and the valve. if you have plenty of prssure and water is going to refrig, make sure line is clear was power of to this unit any? could be waterfroze in the lines check all this first
Feb 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
No water or ice
sounds like your door swith is not working. it wont let water or ice flow when door is open (even when door is closed it is not making contact)
Jan 12, 2009 | Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Will not dispense water
First remove toe panel...Under the freezer door there is a water line connection.. press in on the outer ring and pull out the water line to disconnect....get a cup to catch the water ... then press the water paddle if water comes out you have a frozen water line in the door.. it no water you have a bad water valve... let me know if it helps
Aug 13, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool GS5SHAXN Side by Side Refrigerator Logo
116 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
