Question about Welding Tools
Mig welder model 117-047-902 serial# D481146
Seeial D481146
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
luxur4
  • 92 Answers
SOURCE: lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
  • 14 Answers
SOURCE: looking for operating manual for dan mig 140 mono
go to web sight theyll b happy to help,
Posted on Mar 15, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Where do you find serial number
what model welder do you have?
Mar 03, 2015 | Welding Tools
Bicycle serial number location
The serial number is usually printed on the sides of the Millermatic 200 MIG Welder. You may also want to check at the back on the sticker for the serial number. If you cannot locate it, try the owner's manual or contact any of the local dealers for more inquires.
Apr 21, 2014 | Miller Welding Tools
Need a wiring diagram for a century quick fix wire feed welder
If you can give the code code number I can help you. The code number should be in the same plate as the serial and model number.
Jan 19, 2014 | Welding Tools
Forney model cb serial 145669 can't read front of welder.10 holes unmarked above low med hi
Here is picture of my Model CB. Based on the serial number it is slightly newer, but it should be close enough. Mine also came with a battery charger, which why it has the extra hole.11_22_2012_4_51_47_pm.jpg
Apr 07, 2012 | Welding Tools
I need the gun for my 80 fluxcore mig welder
Hi:
Her's the link to the site; all you need to do is to input the model number.
http://www.chpower.com/manualsearch/
Sep 28, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
I need a wiring diagrahm for a lincoln sa 200 can ya help?
I am a certified 6-g welder, and you can obtain the wiring prints through a welding supply company that sells lincoln products. Make sure you have the model number, as well as, the serial number. You will not find schematics posted online as this would be a rarely used post, so a dealer would be the fastest, and less time consuming effort.
Aug 11, 2011 | Lincoln Electric LINK2400-+1 CV-305 MIG...
I own a Miller "Sidkick" MIG welder. It has been
Hi:
If everything works but there is no arc; you should check your ground clamp, make sure it is not loose or dirty including terminals and replace your gun's contact tip.
Believe it or not this is a simple one.
If this was useful to you please vote. Thanks
Feb 25, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
I have a mig 101 wire welder serial number B-37491-1986. Can I use flux core wire instead of the gas. The welder states .24 or .030 size wire. Are tips available for this welder ?
I have a mig welder that said it could use flux core wire.
Usually, .030 is what I use.
I am not sure if yours is this way, though.
I gave up on using the gas, because my canister was too small to make it practical.
I bought mine from Pace Member Warehouse which turned into a Sam's Club years later.
Good luck.
Jun 21, 2010 | Welding Tools
Welding Tools Logo
163 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
