Back to:
Tags:
Hotpoint Aquarius WF000 / WF000G / WF000T Front Load Washer
Hotpoint Aqaurius WF000 - Flashing Energy save and... (by 5 users)
posted by edillo on May 15, 2007
My machine has started to flash leds with the energy save button and the on/off simultaneously whilst it sounds like the machine is also trying to pump out. I have to unplug it to stop it from doing this and no amount of pressing buttons seems to help (not surprisingly I suppose!) Is there a way to solve this without having it serviced for the second time in 3 months? Thanks!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by toniheathe, posted on Sep 14, 2008
I have a Hotpoint Aquarius WF 440; When turned on water flows through the soap powder tray but drum does not fill, it then rotates and the on/off switch light flickers and then after going throught the correct sequence of lights the light to the left in a vertical row which starts with "mini load" then "reduce crease" the reduce crease starts to flicker,and apart from the drum rotating the machine does not wash.
Comment by alan473, posted on Aug 13, 2008
Hotpoint Aquqrius WF000 my problem is not washing properly, clothes come smelling un clean, if i use powder there is a white residue, plastic caps melt on the clothes, tried full loads and half loads still same, sometimes some clothes are still dryish. had to wash clothes over and over again seems not enough water , old hotpoints were great you could see the water in the drum, can`t on this one never had probs with them. any ideas????
Comment by cookiedood, posted on Jul 02, 2008
we have had the same problem it stops half way through wash and starts flshing.my partner has checked the filter and it wasn't blocked.HELP! don't know whats wrong with it.
Comment by lisa p, posted on Nov 28, 2007
hi, I have the exact same problem . My hubby has already cleaned out the pump (there were three coins and a handkerchief in the filter) and put everything back together again but the washer still continues to pump out as it is filling and the on/off button and energy save button flash simultaneously. please help only ive a 2 year old and desperately need my washer to work again
Best Solution
posted on Aug 28, 2007
FixYa! (100)
gittos73
Rank:Guru Guru
Rating: 87%, 233 votes
check your pump for any blockages it may not be pumping out fast enough the tomer only gives the pump a certain amount of time to pump all the water out if has got some blockage than clean out and this should sort the problem out always check pockets if this is no help let me know and ill let u know what else it could be m8
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hotpoint Aqaurius WF000 - Flashing Energy save and on/off switch:
I don't want to Accept this solution
Solution #2
posted on Sep 10, 2008
Not Rated (0)
grantbowden
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
try running a cold wash. if it works its likely to be the heating element because the water isnt getting to temp and just holds its cycle!. It happened to me about 1 year ago i fixed it and now its happening again.
Thank You!
Can you Help with these Washing Machines problems?
Hotpoint Aquarius WF000 / WF000G / WF000T...
my machine (hotpoint aquarius 1000 spin) is stuck on...
power and energy saver flashing but will not spin or...
need to know washing settings for wf000
I have a hotpoint aquarius ctd40g condensing dryer and...
washing machine displayed f-12 and has now stopped...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
