Question about Garden
Collar on john deere drive shaft is stuck
62" deck drive shaft collar is stuck open (off the mower). I have tried WD40 and lithium grease. It will not close. How do i get it unstuck.
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
  • 229 Answers
SOURCE: MOWER DECK BELT ROUTE FOR LA175 JOHN DEERE LAWN
you can try johndeere.com you should be able to find it there.
Posted on Oct 20, 2009
  • 5 Answers
SOURCE: need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
Posted on Oct 22, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
Mower deck won't engage on John Deere x585, I think electrical
do you push a button to engage , if so look for a disconnected plug or a broken wire .
Aug 16, 2015 | John Deere Garden
How to remove the steering shaft on a John Deere 125 Automatic riding mower?
should be enough room to get it ontry rolling it past the steering shaft
Aug 25, 2014 | John Deere Garden
Do the gy21098 spindles for my La145 lawn mower deck come pre greased or do I need to add grease after installing
When changing spindles I always add at least 7 or 8 pumps of grease from the grease gun. Usually John Deere does not ship anything with grease. Daniel.
Sep 10, 2011 | John Deere 22HP VTwin 48" Riding Mower
Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Jun 16, 2011 | John Deere Garden
Mower blades froze up
Have you greased the bearings on the mower deck recently? Is there something jamming the blades?
Remove the deck and see if you can move the blades by hand. If you insist on not removing the deck to do this ... make sure the belt that drives the deck is not on the drive shaft of the motor to prevent accidental starting of the motor and instant mangling of your hand. If you can move all the blades, look for a faulty or worn out pulley on the deck. If the blades are frozen in their bearings, get replacement towers at your John Deere dealer or from a FixYa.com advertiser. If one is faulty or rusted ... replace them all ... as they are probably at or near the same condition. Do this job one time and do it correctly.
Thanks for your support.
Thanks for your interest in FixYa.com
Please evaluate this response.
Thanks
Good luck with your repair.
Jul 05, 2010 | John Deere 24HP VTwin Hydrostatic 48"...
Taking lawn mower off john deere 455 tractor
Undo the lever in the front by pulling it out and then rolling it downward to release the front of the deck [lower it to the ground before you start].Once that bracket is off you need to remove the drive shaft by pulling back on the lock collar on the shaft and then pull off the pto shaft.Now pick up the rear of the deck slightly and pull out the c hangers in the rearof the deck just ahead of the back wheels.Jack up the left rear end to make it easier to pull the deck out from under the tractor.
Nov 19, 2009 | Cars & Trucks
John deere 111 mower deck. Lift is in stuck in highest position
Jun 25, 2009 | Garden
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
