Question about Garden
What is the spark plug gap setting for 030245?
What is the gap setting for a troy-bilt 5550 watt generator? Briggs and Stratton motor.
mcdw
SOURCE: briggs and stratton engine #204412 type #0163e1
I found a parts list for model 204412 at http://www.buysmallengineparts.com/
Posted on Sep 07, 2008
  • 376 Answers
SOURCE: Need a fuel tank for a Troy Bilt mower
You won't find the fuel tank on MTD's site because it is part of the engine. MTD makes the mower, Briggs and Stratton makes the engine. Get the model and type number off the engine and search Briggs and Stratton's site or post it here and I will tell you the part #. Dwain
Posted on May 21, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
panilling9
  • 284 Answers
SOURCE: gap setting for champion RJ19LM spark plug 3.5
plug gap setting is .030
Posted on Jun 10, 2009
  • 3 Answers
SOURCE: brand new , won't start, no spark at plug, switch ok
check the spark plug and see if it is getting fire if not replace the spark plug if that dont work take it back.
Posted on Jun 24, 2009
What is spark plug gap on unidentified pressure washer?
Find My Engine Spark Plug & Gap ' Briggs & Stratton
www.briggsandstratton.com/.../identifying-the-correct-s...
Briggs & StrattonLearn how & where to find the right spark plug and a gap chart to guide you through ...are commonly used for walk behind lawn mowers and pressure washers.
Spark Plug Gap - Troy-Bilt
Nov 24, 2015 | Garden
We have a Troy-Bilt chipper and every time we use it, we have to change the spark plug in order for it to start.
Check the gap on your plug when you put a new one and then check it after you run it normally. If it is smashed check your piston for a contact point where it was hitting the plug.
Check your manual for the correct plug type. They my have put the wrong on in and if you just keep putting in the same plug...
Call troy-bilt they are pretty good about service issues.
Nov 04, 2015 | Troy-Bilt Chipper Shredder 250cc 11.50 TP...
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt 5550 generator has no spark
you can clean the fly wheel where the magnets are an see if that helps . you might need a NEW mag.
Mar 30, 2013 | Briggs & Stratton Power Products 5,550...
I am replacing the spark plug on a 5 hp Quantum engine that is on a Troy Bilt walk behind mower. I would like to know the spark plug gap setting on that motor.
I'm guessing you have a standard Champion J19LM plug, which has a gap of .030. They come pre-gapped from the mfg. and usually no need to adjust them. Most of the plugs on these engines have a .030 gap. There are very few exceptions that use a .020 gap (such as the RC12YC). Anyway, here's a link to a chart I like to use for reference: (there's a drop down menu at the top to change engines, but the standard Briggs engine is the one here).
http://www.manddsmallengine.com/briggs/info/plug7.html
Hope this helps. James
Aug 06, 2011 | Briggs & Stratton Garden
Troy bilt 5550 generator no start please help
fuel, fire, mechanical. Miss one and she won;t run. Are you sure the gas was good? Not some old can laying around that may have turned or become water contaminated? If it was fresh gas, then take off the air cleaner and spray a little wd-40, or ether, or brake cleaner whatever is flammable into the carb throat. Just a 1 second shot is all it should need. Try and start with that. If it starts and then dies quickly, still a fuel problem. maybe a gasket is damaged, or the jet is clogged. When you said you checked for fire, you acutally took the plug out and had it grounded while spinning the motor and saw spark? If you saw a hot spark then you have eliminated fire. Mechanical not likely if it was running well a short time before. If a valve was damaged, it would still run but not too well. My gut feeling is it is related to fuel.
May 25, 2010 | Briggs & Stratton Power Products 5,550...
Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My troy-Bilt 5550 watt generator will not start
First drain the fuel bowl. Any old fuel in there will keep it from starting. Fuel stabilizer is not what it's it cracked up to be. I've worked for 6yrs at a rental yard and had no luck with any fuel stabilizer, the fuel still went bad. If after you drain the fuel bowl it still will not start, you will need to clean the carb. Remove the carb and spray carb cleaner through all the accessible passages. If this does not do it, you will need to replace the carb. For long term storage I highly recommend draining all the fuel and filling just the carb with fuel stabilizer to keep gaskets moist. Then drain the carb when you take it out of storage.
Mar 29, 2009 | Electrical Supplies
Briggs and stratton engine #204412 type #0163e1
Jun 30, 2008 | Computers & Internet
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
