Question about Watches
I am repowering a Seth Thomas Medbury 6E mantel clock.
The dead motor is stamped "General Time Corp. Made in USA" And in red ink "A9A" Do stock such a motor, or if not can you suggest another which would be a suitable replacement?
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Setting the correct time on Seth Thomas clock.
Correct technique definitely is CLOCKWISE ONLY. You are unbelievably lucky person if did not damage striking mechanism within 25 years while adjusting hands anti clockwise. If I'd have such a luck, I'd try to play lottery. :))
Posted on Feb 04, 2010
Testimonial: "I was surprised by the answer. I can't recollect where I got the advice to set it by counter clockwise. Will follow you guidance. Thanks"
reyjoshua07
  • 1157 Answers
SOURCE: i need to know how
Hi ajhazel1,
Please follow the steps below on how to set the alarm on your seth thomas mantel pendulum clock.
1. Determine if your Seth Thomas mantel clock is a 7-day clock or an 8-day clock. On most models it will say right on the face of the clock which type it is. Seven-day clocks must be wound every 7 days, and 8-day clocks must be wound every 8 days. If you are unsure you should wind your clock every seven days.
2. Look on the back of the clock. You will see three large holes (just large enough for the clock winding key to fit into) plus one or two smaller holes (often just large enough for the small end of the key to fit into). The two smaller holes are for speeding up or slowing down the clock and for turning the chimes off and on. The three larger holes are the ones we are interested in--they are the ones we will need to wind every 7 or 8 days. On some models the three winding holes are on the front of the clock. Winding instructions are the same, regardless of where the winding holes are located.
3. Push the large end of your clock winding key gently into the hole on the right as you look at the back of the clock. This hole allows you to wind the 15-minute chimes. Gently turn the key clockwise. Keep turning it until you feel resistance and the key stops turning. Remove the key.
4. Insert the large end of your key gently into the center hole. This hole allow you to wind the main clock mechanism, which allows the clock to run and to keep time. Turn the key clockwise firmly but gently until you feel resistance. When the key no longer wants to turn simply remove it.
5. Insert the large end of the key into the hole on the left. This winds the hour chimes. Turn the key clockwise firmly but gently until you meet with resistance. When the key no longer turns easily remove it and place your clock back on your mantel. Your clock is now set to run for 7 or 8 days, depending on the model you own.
6. Use your hand to start the pendulum swinging once the Seth Thomas mantel clock has been set to the right time. The pendulum should be located in the back of the clock. The clock will not keep time if the pendulum is not moving.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 24, 2011
I have a Seth Thomas Grandfather clock with three different chimes and chimes at every 15 minutes. The problem is it is chiming 2 hours shorter than the actual time. Example say it is 11:00, it is...
Thanks for contacting FixYa.
I wish I had an aswer for you but I dont. Here is a link for a repair man that has an 800 # toll free to call for estimate.
http://clock-repair.net/site-map/seth-thomas-clock-repair/
Best regards. Jewel
Sep 13, 2010 | Watches
Why is there two places to wind a Seth Thomas Corsair E537-000 clock? Any description on the proper tension for winding?
Two winding arbours are in clocks with chiming, because there are two separategears in one clock and each one is driven by separate mainspring. Description for winding is: Wind each spring as long as you do not feel significant resistance. As soon as you feel the winding goes too hard - stop winding.
Rate me, please.
Aug 05, 2010 | Seth Thomas Watches
How do i wind an old seth thomas pocket watch? mfg. 1894, montgomery ward model
mcdevito75 here, I believe you"ll need a special winding key to wind your Seth Thomas Clock, Best Bet, look for a small watch repair shop in your area, they may be able to order a key for you, have all info regarding the clock with you. Winding keys may also be on ebay under Vintage Clocks/watches.
Jul 12, 2010 | Watches
Have Seth Thomas Regulator clock...three years old hourly ring tones are out of sequence and time of day: i.e. 7:00PM migh dong five times; 9:00AM migh dong three times etc. Directions for setting time...
Sounds like a strike cam and rack alignment or hang up / sticking issue.
If you have already attempted to follow directions "Many Times" Recommend contacting help in your area.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 04, 2010 | Watches
Feb 04, 2010 | Timex Watches
Old Panasonic Clock RAdio
Assuming she can live without the alarm functions, have you considered the quick and dirty option of swapping the original clock for a quartz movement?
Mar 28, 2017 | Watches
Watches Logo
151 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
