Question about Samsung SyncMaster 540N 15" LCD Monitor
Remove cover Hi, think my backlight is broken and with no warranty left i'd like to open the back and have a look. Anyone know how to do it? Found somekind of thin metal barrier on the bottom left side of the back cover. Didn't manage to open it anyway. No screws what so ever. Thanks.
  • angkor Jan 26, 2009
    how to remove cover
    Genius:
  • 2,985 Answers
Its a snap together job But unless you know where to start something will snap. Try the Samsung Tech support for this product. Even if the Back light or inverter or some other do able thing is doable- getting parts may not be so easy for you. So follow their advice for service.
Posted on May 15, 2007
Black screen cant get menu
Hi Tracy..., last month my ipad got black screen also, all i have to do is.. I open it
slowly and carefully pull-up the touch screen,then i remove the LCD and at the back of LCD you can see the black plastic cover, carefully remove it,then when finish removing it, at left side there is flix ...that is the connection of backlights...
if you see that is broken that causes you the ipad turn black screen, all you need is to get a soldering iron and a lead then fix that 9 connections of flix one by one ..and after that, all parts that you remove return it carefully and restart your ipad..and you have your ipad now back to normal
Aug 23, 2015 | Apple iPad (16 GB) WiFi Tablet PC
1995 grand voyager hood handle broken does anyone know how to open it from the outside?
If there is nothing left of the cable to pull with pliers, you can try to go up from the bottom of the bumper cover to reach the latch.
You may have to remove the bumper cover to get to it.
Dec 14, 2012 | 1995 Plymouth Grand Voyager
How can i open the body or case to repair of hp
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the circuit board parts / connections if loose/broken/defective. regards
May 17, 2009 | HP f2105 21" LCD Monitor
HP vs15 no problem
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the power button connections if loose/broken. regards
May 15, 2009 | HP Vs17 17" LCD Flat Panel Monitor
ST3S Gauge Backlight
The light should be an LED so, yes, it should last longer than that! You probably have a corroded contact inside the unit from condensation.
Nov 10, 2008 | 2007 Ducati ST3
Backlight Problem
You are lucky it works at all. The system board has been compromised.
Jul 30, 2008 | HP iPAQ hw6515 Pocket PC
Canon digital G5 LCD monitor problem
Very simple fix. Open the covering on the lcd screen and also remove covering that is between the camera and screen. There is a wire that goes from the lcd screen to the camera. It came out from all the twisting of screen when opening and closing. Carefully put that back in. Google keywords like "lcd g5 fix" etc. for more detailed description.
Jul 20, 2008 | Canon PowerShot G5 Digital Camera
FreeAgent 500gig External - How to open case?
I believe Seagate has a 5yr warranty with this drive. Why not have Seagate honor the warranty and have them repair or replace the drive?
Jan 16, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
SD400 broken screen
found this guide on the net once, try it out and let us know what you think: " WARNING: this repair voids your warranty and may damage your camera. Perform at your own risk. The publisher of this site is not responsible for any damage you cause. This replacement is of medium difficulty. If you have ever ?built? a computer from parts, you are probably capable of it. If you are patient, orderly, and meticulous, you can probably do it. But you do risk breaking your camera even further, so don?t do it if you won?t accept that risk! Be carefully that you are grounded and thus do not harm the camera via static discharge. Google the terms ?grounding? and ?static discharge? if you need more info. I only performed this operation on a Canon SD300 / Ixus 40, but readers have reported that it is the same on the SD200 / Ixus 30 and on the SD400 / Ixus 50. Read all of the instructions before proceeding. Within each step, I don?t necessarily use exact chronological order. Tools: a small Phillips head screwdriver and a smaller flathead screwdriver (used for prying). Step 1. Ascertain what is broken. Symptom: your screen still glows with light, but shows crazy colors or a visible crack surrounded by crazy colors. Problem: your LCD screen is broken but your backlight still works. You need only purchase a new LCD screen. Symptom: your LCD does not glow. Problem: your backlight is probably broken. This didn?t happen to me, so I don?t give any further advice about this problem on this page. However, the information on this page will take you about 60% of the way to replacing the backlight as well, so it may be useful. Step 2. Order a replacement screen. UK: H. Lehmann's Ltd: +44 (0)1782 413 611 at a cost of 33 GBP (including shipping) US: Canon? +1 732 521 7230 / +1 800-828-4040 at a cost of around 66$ (including shipping) The part number for the SD-300 / Ixus 40 LCD screen (without backlight) is: ck9-1103 The part number is the same in the US & UK. I do not know whether the SD-200 / Ixus 30 LCD / SD-400 / Ixus 50 LCD part number is the same.. Step 3. Open the camera - Remove 6 screws in total: 2 from the left side, 2 from the right side, and 2 from the bottom. - Gently pry open the case - The plate covering the ?grommet? to which you attach the strap will fall off. So will the round grommet. Don?t worry about it. Step 4. Remove the screen & backlight assembly from the back of the camera - Remove the screw from the upper right corner of the backlight/LCD package. Note: this screw is of different size to those you have already removed. Keep it separate. - Be careful of the tongue extending from the bottom right corner of the backlight/LCD package. It?s very tiny and easy to miss. You want to be sure to slide it out, because it?s easy to just break the plastic into which the tongue slides. (I did. Not a huge crisis, but I wish I hadn?t!) - There is a tab on the left side of the backlight/LCD package. Pull it back slightly so you can lift the backlight/LCD package. (I used the flathead screwdriver to pry it off.) - You should now be able to lift up the backlight/LCD package. It will still be connected to the camera body via two ribbon cables. Step 5. Separate the LCD from the backlight - There are a number of fiddly plastic/metal tabs holding the two together. Just gently pry and poke until you have separated them. It?s a bit time consuming, but I can?t really give better instructions than these. - You should be left with the LCD totally separate from the backlight, but still connected to the camera via a ribbon cable. - The backlight should also remain connected to the camera via a ribbon cable. Step 6. Undo the LCD ribbon cable - The LCD ribbon cable extends under the bottom of the camera (actually passing under the tripod screw hole, which cannot be removed). It re-appears in the front of the camera and is connected to a socket. The socket is rather like a DIMM socket on a computer. It has a flat, black, clasp which is folded down to hold the ribbon cable in the socket. - Examine carefully the way the ribbon cable is attached to the socket. Note that it is pushed in entirely, so that the wider part of the cable (with two holes at either side of it) is flush against the socket. - GENTLY lift the clasp (I used the flathead screwdriver). It should swivel up and the ribbon cable should fall out. DO NOT YET PULL THE RIBBON OUT OF THE CAMERA. Step 7. Totally remove the LCD - Tape a long, narrow strip of paper to the end of the ribbon cable. This paper is to help you thread the ribbon cable of the new LCD back through the inside of the camera. - Note how the ribbon cable is threaded under the tripod mount to the front of the camera. Wiggle it around a bit, get a feel for it. Sliding the new one back through is a bit tough, so experiment with how this one fits and where it goes. - Gently pull the ribbon cable out from under the tripod mount, leaving the broken LCD screen now completely detached from the camera. Make sure to leave the paper threaded through the camera so that you can tape it to the new LCD?s ribbon cable and pull that one back through. - If you messed up with the paper, don?t worry. You can still push the new ribbon cable through: it just takes some wriggling and some time! Finishing. - You have now got to go through the process in reverse, installing the new LCD screen. - Threading the LCD ribbon cable back under the tripod mounting screw is tough. Just keep sliding it back and forth and exert pressure to push it through. It will go through, eventually. - As you connect the LCD ribbon cable, read the ?white screen? problem below, so that you do not suffer from it! FAQ 1. My screen just shows white or gray. (E.g. white screen, white display). What did I do wrong? A. The ribbon cable that connects the LCD to the circuit board was not inserted deeply enough. The end of the ribbon cable has a narrow portion, then a very small much wider portion with two holes at either end, then it narrows again. The very tip should be inserted into the "socket" deeply enough that the wider portion is pressed right up against the "socket." Physically, it cannot be inserted more deeply. It may help you to use two wooden or plastic toothpicks, one in each of the small holes at the end of the cable, to push the cable into the socket." If you feel like supporting the author of this thread, go to his website through this link: http://www.cl.cam.ac.uk/~jo262/broken_lcd_cracked_screen_canon_sd-300_sd-200_ixus-40_ixus-30.html Good luck
May 18, 2006 | Canon PowerShot SD400 / IXUS 50 Digital...
CASIO E-125 no backlit
Usually the ribbon cable connection that powers the backlight is the problem.If you remove the four screws in the back and take off the back cover. (note that there are two tabs on both sides of the cover half way up)You can see the white ribbon cable on the left above the battery back housing. Gently wiggle it and see if the backlight goes on. The cable is attached with a small brown insert that holds it in. It is removable so you might be able to get an electronics shop to replace the cable connection or the cable itself.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Samsung SyncMaster 540N 15" LCD Monitor Logo
501 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
