Question about IBM Magstar 3590 Magstar Tape Drive
I have F1D1 E5 error on 3592 tape drive. How to fix this problem?
Tar job to tape was terminated while still running. Then it gave this error message. Cannot put back a tape inside the drive. Thanks.
Backup tape(RDX) getting ejected automatically after sometime while backup job is not running.
RDX tape drives, by HP (tandenberg)
did you reload all that HP software and drivers fresh?
did you try fresh tape.
i replace the tape drive, (new , used, NOS , from whom, ebay)
i bet the tape drive, logs errors, if you look,
the driver software will log that, and you can see why the tape
failed, my guess, damage to the tape, end to end.
try fresh new tape, NEW in a box, not used.
Oct 13, 2017 | HP Computers & Internet
Tip
How to back up a Tape in Linux operating System
<p>Linux is a free operating system based on Linux kernel and provides a UNIX-like interface. Several Linux distributions including Ubuntu, Debian, Fedora, Pacman, RPM, Gentoo and Slackware. Linux is used in games consoles, mobile phones, netbooks and computers and mainframes and supercomputers. The Linux system can be through a Command Line Interface (CLI) or a graphical user interface (GUI) control. When you save data on your hard disk, a tape on Linux a few steps required to configure. <br /> <p><br /> <p>1. Open a terminal in Linux, and enter this code to data on multiple tapes: <br /> <p> <br /> <p>Tar clpMzvf / dev/st0 / home. " <br /> <p>2. Enter this code to the backups to compare: <br /> <p> <br /> <p>Tar dlpMzvf / dev/st0 / home. " <br /> <p>3. Restoring all backups missing hard disk with this code: <br /> <p> <br /> <p>Tar xlpMzvf / dev/st0 / home. " <br /> <p> <br /> <p>Now you have a tape backup done on Linux. <br />
on Jun 22, 2011 | Computers & Internet
Tip
HOW TO INSTALL FROM SOURCE IN LINUX
HOW TO INSTALL FROM SOURCE IN UBUNTU 9.10
Installing from source in linux is not very easy...... but once you know what to do, then it becomes a very easy task.
STEP 1 Tar.gz and Tar.bz2 Packages
The installation procedure for software that comes in tar.gz and tar.bz2 packages isn't always the same, but usually it's like this:
1.Download the tar.gz or tar.bz2 package
2.Extract the file
3.Open to the terminal
4.Use the cd command to change to the directory where the package is extracted
5.Use the following:
$ ./configure
$ make
$ make install
Without Using The Extraction Method
Run the following:
$ tar xvzf package.tar.gz (or tar xvjf package.tar.bz2)
$ cd package
$ ./configure
$ make
$ make install
!!!!THIS IS AWESOME!!! …... ISN'T IT?
STEP 2 .Deb Packages
Installation of .deb packages are in different forms or methods depending on the users understanding and how the user is flexible with the terminal.
1.Download the package
2.Extract the package
3.Change to the directory containing the package
4.Run the following
sudo dpkg -i package_file.deb
!!!! AND YOU ARE DONE!!!
LINUX X64 AND X86 BINARY INSTALLATION
2.Open to the terminal
3.Use the cd command to change to the directory containing the package
FOR X86 PACKAGES.........
$ chmod +x filename-ver.*-linux-i686.run
$ sudo ./filename-ver.*-linux-i686.runFOR X64 PACKAGES........
$ chmod +x filename-ver.*-linux-x86_64.run
$ sudo ./filename-ver.*-linux-x86_64.run
where ver is the version number (the whole number before the decimal point... eg; the 4 in 4.103)
!!!!THANKS A LOT!!!!
on Jul 21, 2010 | Computers & Internet
How do I fix an E5 error message on an Ironman 2300.1 treadmill? What does this error message mean? How do I get a manual for this treadmill?
go to www.fitness.manualsonline.com or www.iconservice.com and download for free.
E5 means a key stuck ,some Upper PCA has been failled.
Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jun 30, 2012 | Ironman Exercise & Fitness
Tar /dev/st0 can't write: error
Sounds like your tape drive or possibly the tape you are using is faulty.
check the following:
#1 - use a different tape
#2 - check that the read-only is not enabled on the tape(s)
#3 - run diagnostics on the drive (if it's come with software for diagnostics).
#4 - return it to the supplier to test and replace if under warranty.
Apr 04, 2010 | Sony DDS SDT-S9000 DAT Tape Drive
A PRINT JOB IS IN THE PRINTING QUE THAT IS NOT ERASING OR PRINTING AND NO OTHER JOB CANNOT BE PRINTED
1- Go to Start, All Programs, Accessories, and then RIGHT CLICK "Command Prompt" and select "Run as administrator". The terminal black screen will be opened.
2- Type NET STOP SPOOLER and press they Enter key (you should get a message confirming the spooler is stoped now)
3- Now in the same black terminal screen type NET START SPOOLER and press the ENTER key (you should get a message confirming the spooler is started now)
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Thank you
TechSaver
Feb 08, 2010 | HP DeskJet 3550 InkJet Printer
I dont know how to install external tape drive compaq DLT VS 80 in Red hat 4
Hello,.
Please reboot your server and attach tape drive... if it is still not detecting please check the
#dmesg
command to check the error...
and get back ............
Dec 02, 2008 | HP (154872-003) (154872003) DLT Tape Drive
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Jul 26, 2007 | Sony (LIB81A3BB) AIT-3 Tape Drive
IBM Magstar 3590 Magstar Tape Drive Logo
70 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
