I have a 2000 range rover i recently purchased. had to replace the starter and now cant unlock the radio because i never got the 4 digit code. The auto dealer where it was purchased has no record. I took it in to a rangerover dealer and they doant have any record please help me
    Genius:
  • 1,239 Answers
Hi first check the voltage.if it is  To initiate the procedure, one must first turn the key anticlockwise (locking the car) 4 times. The 4-digit EKA code can then be entered- first clockwise, then anti, etc. After all 4 numbers have been entered, turn once more clockwise to unlock the vehicle, disarm the alarm, and re-mobilise the engine.
Posted on Jan 03, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 03, 2009
     The transmitter and receiver synthesizer monitors four channel select lines (CSEL3 to CSEL0) that are connected at the rear of the motherboard. The states of these channel select lines will determine the channel that the transmitter or receiver will operate on. The channel select lines operate in a binary fashion, where a high (+9.5Vdc) is a ‘1’ and a low (ground) is a ‘0’. The channel select lines are read from Most Significant Digit (CSEL3) to Least Significant Digit (CSEL0) and form a four digit binary code.
    A binary code of 0000 (all four channel select lines grounded) will result in transmitter or receiver operation on channel 1. A binary code of 0001 will result in transmitter or receiver operation on channel 2, and so forth. A binary code of 1111 (all four channel select lines at +9.5 Vdc) will result in transmitter or receiver operation on channel 16.
    Control of the channel select lines can be done by three different methods:
    A) The motherboard has four channel select jumpers and a power enable jumper for each transmitter and receiver in the subrack. These jumpers can be selected in the +9.5 Vdc position (1 or up) on the motherboard or in the grounded (0 or down) position. The power enable jumper must be installed for these jumpers to operate.
    B) Rotary switches can be mounted on the front of the Audio Control Card and wired into the channel select jumpers allowing control of channel selection through 16 position selectable front panel rotary switches.
    C) The channel select lines can be routed to an external source through the auxiliary control connector on the motherboard, allowing channel selection by third party equipment such as tone remote adapters.
  • 470 Answers
Restar the software , and much better reprogram it
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 18, 2009
    like what i said,, reformat it or reprogram, because the source of the problem is the software
    Genius:
  • 1,199 Answers
Try taking off the battery cable for five min to reset the unit! Then replace the Radio is now back to the factory settings!
  • 15,935 Answers
If you canot find the code, there is a way to get the code for the radio.
1--remove the plastic cover plate from the radio surround - it should come right off if you pull on it.
2--insert an 1/8" round something ( usualy an allen key will do ) into the holes at either side of the top of radio, this will release the radio from the casing. Pull it out.
3--the code is written sometimes on top or bottom or both sides of radio.
re-assemble everything by pushing it back in ( remember to write it down somewhere for future reference, Sharpie works great at inside of the glove compartment ) follow above previous instructions to reset the code input.
  • blueextc3221
    blueextc3221 Jan 03, 2009
    hold down the "band" button until the radio screen reads "code in" then enter your 4 digit code
    Brigadier General:
  • 5,158 Answers
Only thing i could find and i can't vouch for them is
http://www.radio-code.com/?gclid=CLn31YP08pcCFQRhswodYlU-Dw
Robert
P.S. i will keep researching it
  • Roberta Smith
    Roberta Smith Jan 03, 2009
    code input.
Receiver code no
This requires a specific code that is unique to the car the radio came from I'd you get lucky sometimes there's a little sticker on the radio somewhere with a 4 or 5 digit code typed on it... If not your only other option is going to a dealer to see if they can get the unlock code for you
May 01, 2013 | Audio Players & Recorders
Entering my code 3 times wrong now its locked up.my car is a range rover 1998 .
put your key in turn to position 1 turn on radio you will see _ _ _ _ on display leave like this for 1 1 1/2 HOURS then radio will read enter code put in your 4 diget number in radio will come on you dont have to press anything else tuneyour radio in sounds great
Dec 08, 2009 | Harman Kardon AVR 635 Receiver
My starter was replaced and the radio reprogrammed itself and now it's asking for a 4 digit code in order for the radio to play.
You need to contact a local dealer with your car VIN and they can assist you with this. Sounds to me like the radio is in the theft mode since the power from the vehicle was removed to replace the starter.
May 03, 2009 | Audio Players & Recorders
I need a code for my BLAUPUNKT Radio serial no BP2015R7563321 which came with Rover 623
There is no info on the internet for the unlock. But, I do know if you contact blaupunkt and give them the serial number, they will unlock it for free.
Apr 30, 2009 | Audio Players & Recorders
My 2000 430E Audio suddenly came up with CODE I tried to enter numbers and it won't remove the CODE. I purchased the car second hand and they did not include the code sheet for the radio. Any suggestions...
Hi Gal in PA...
The word CODE is displayed if the radio is removed or if the battery is disconnected. You'll need to do one of the following to get the radio code:
1. Call or go to your local MB dealership. They may or may not provide this to you free of charge.
2. Email MB USA customer assistance. (I found a post online where someone did this and had success)
http://www.mbusa.com/mercedes/#/contactusOverview/
Either way, you'll need your VIN.
I'm surprised your catalytic converter needs to be replaced with so few miles. If your dealer is telling you this, I suggest a second opinion. Or, post a new question in the car section of fixya.com.
Apr 20, 2009 | Audio Players & Recorders
Had dead battery. Now radio says I need a code to unlock it.
What type of radio is this? If it is aftermarket, then typically Eclipse and Kenwood are the only units that utilize radio codes. If it is a factory radio (Honda, Acura, Audi, VW typically), then you will need the code which is 4 or 5 digits long and located in your owners manual or vehicle documentation on a small card the size of a credit card. If this is unavailable, then you will need to visit a local stereo shop, have your radio removed and re-installed, and your serial number written down. Take your radio's serial number to any dealer for your car manufacturer, and they will provide you with the unlock code. Hope this helps.
Sep 03, 2008 | Audio Players & Recorders
Acura mdx 05 radio unlock code
my 2004 acura mdx is dead so i finally jumpstart but the dvd player,radio and cd is lock and it need a code
Jul 19, 2008 | Audio Players & Recorders
I just bought a Porsche Boxer but I can't turn the radio on because I don't have the code!!!
You just need to recover the radio's serial number to decode the 4 digit radio key. The full process and decoder is available here: Porsche Boxster: Online Lost Radio Code Recovery Tool
May 04, 2008 | Audio Players & Recorders
22 people viewed this question
 Grubhead
Grubhead
