Question about Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore ultra wash III keeps on turning off
When I turn it on in few minutes it turns off. Then it shows PF. I keep closing the door b4 I get PF and it starts and again turns off. If I wait for more it will show PF again. I have to sit there and every time it turns off I got to open and close door in time not to show PF. If it shows PF I have to restart the whole cycle again. Please direct me trouble shooting this. Thanks
SOURCE: Clean light keeps blinking and I can't start a new cycle
Clean blinking and nothing works
The solution works 100%
HI TEMP HEATED DRY
HI TEMP HEATED DRY
for ultra-wash quietguard3 Kenmore
Love you all of you
Posted on Feb 11, 2008
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
  • 4 Answers
SOURCE: Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Posted on Jul 01, 2008
  • 338 Answers
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Posted on Nov 25, 2008
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
I have a Kenmore Ultra Wash Quiet Guard washing machine Model No. 6651601. I am trying to find out how to reset my dishwaser as it keeps flashing the "clean" light but will not run.
No there is no reset button you could disconnect the power by turning off circuit break for at least 5 minutes turn it back on and see if that clears it
Gene
Aug 01, 2011 | Dishwashers
Kenomore ultra wash dishwasher will not clean dishes- water pump may be out? How do I perform self diagnostic test?
check and see if both wash arms are turning first.
does the lower arm turn but the top arm does not?
Another way to check to see if your upper wash arm is turning is to put a mug in the top rack upright. close the door and turn the dishwasher on if it fills the mug within 2 minutes you are getting proper curculation.
you press heated dry and high temp wash and toggle back and forth within 6-8 second. all the lights should light up and it will go into diagnostics.
Sep 03, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I keep getting a UL code which means unbalanced load..Open the machine and look at the cloths shut the door and start it back up 10 min's later wash is done . Looking at the manual it says machine is un...
This is usually a common error. You need to unplug the machine for few minutes, say 30 minutes and then turn it ON, it should reset the error.
If not, the next details you need to check :-
1. Is it accompanied by some other error code?
2. any other problem that sounds in relation with this code?
If not, it refers to faulty control board. Many people have got even error PF ( power failure ) along with it. Once replaced, it would fix the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 25, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite QuietPak 9 Dryer - door opens constantly
I'm not solving the problem, but just wanted to say I have the same problem for the same dryer
Aug 04, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite side-by-side (1999 model--don't have #)
Evaporator is probably overiced as a result od door not being completly closed at some time recently, turn off and defrost overnight with the doors open, turn on the next day and it should work ok within 24hrs. Regards Advisor
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 24 in. 15689 Built-in Dishwasher Logo
14 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
