Question about Code-Alarm Code Alarm Transponder
Remote starter disabled and key will not start truck
Code starter installed by ford dealer in 02 deisel f350 .40 below here right now
  • jason skovly May 11, 2010
    what is the problem
  • 3 Answers
Interface kit went bad life time part goto dealer and have replace should take 20 min
Posted on Jan 13, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2003 ford mustang gt anti theft light flashing engine will turn over but will not start
From my experience...
A non PATS coded key SHOULD not turn the STARTER...!
If ANTI-THEFT were invoked... you can attain a not start condition which the Owners Manual says must be cleared by the dealer.
A working PATS key should disable the anti theft... by turning the ignition on... ELSE try your other key.
The SecuriLock [PATS]
passive anti-theft system is not compatible with
non-Ford aftermarket remote start systems. Use of these systems may
result in vehicle starting problems and a loss of security protection.
Owners Guide (post-2002-fmt)
USA English (fus)
OWNERS MANUAL
Ford 2003 Mustang Owner Manual
SHOP MANUAL
Ford 2003 Mustang Workshop Manual
May 17, 2017 | Ford Cars & Trucks
My 2004 Ford Taurus remote starter will not start the car. All other remote options are working. How ever if I have the key in the ignition and press remote start it will start. Please help.
The problem here is the remote start system is not giving out the correct transponder code to the security system, this locks out the starter. As to how you program the remote start I have no clue as to what you need to do.
Oct 27, 2016 | 2004 Ford Taurus
Saab experts
May be keyfob needs reprogramming.
Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.
If the remote s faulty then key fob will not get programmed.
Insert the key in ignition. Turn the key to on position, and cycle the key three times off-on-off-on-off-on. Then with the key fob remote select your remote and then try to operate the vehicle with remote.
These are just the basic procedure, but sometimes it will not help.
On that case dealer is the only option.
There are few much related troubleshooting links mentioned below for remote key fob reprogramming. I suggest you to go through the list and click the link below to go through its details and procedure: -------
Theft indicator not letting car to start?
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
2009 Toyota Highlander: Smart Key Not getting Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
After getting car washed, check engine light is ON and key less entry not working, tried reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
Audi A8 Key Fob Programming?
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
Oldsmobile Aurora Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
Buick Lesabre Key Fob Reprogramming?
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
Keyfob remote not working on 2003 Ford E350 Econoline?
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
KeyFob will open the doors but not start on BMW?
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
2000 Jeep Cherokee Limited: KeyFob Remote Not Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
2012 Dodge Ram: Ignition Key will not release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Deisel ford transit, turn the key to start and will usual start, on occasions turn the keyand engine does not turn over but get a clicking sound from under the bonnet, will start with a push or jump start...
titen the cables at batt posts and maybe at the starter motor--cud be corrosion also--the starter may be a lemon--ask dealer or go online for any service bullitins
Jun 14, 2011 | 2011 Ford Transit Connect
Can the anti-theft system be disabled on this '02 Taurus? Dealer has replaced PATS sensor, recoded keys/remote, and it still starts intermittently...and they have no more ideas!...and they still have the...
car quits after 30 miniutes of run time no enjine codes fuel system is ok enjine will not restart untill i turn the key to the off position but will only run intermitantly untill you lit it cool down then the same thing all over again
Feb 22, 2010 | 2002 Ford Taurus
2003 ford F250 6.0 deisel..it will crank but will not start,cam and crank wil not synchronize..both are new. oil gauge wil not show pressure while cranking RPM.is around 48 rpms on a scan tool...
I HAVE A 7.3 DEISEL AND I DONT KNOW IF THE 6.0 HAS ONE OR NOT BUT MY CRANK SHAFT SENSOR WENT BAD AND THE TRUCK WOULD NOT START( JUST TURN OVER ) DEALER PUT NEW CRANK SHAFT SENSOR ON MINE AND FIXED THE PROBLEM...HOPE THIS HELPS...
Nov 29, 2009 | 2003 Ford F250 Super Duty Crew Cab
2005escalade remote starter
did you install a "gm remote start bypass", like DEI model 556L?
if not it is the passlock that is not allowing the car to start.
Dec 19, 2008 | Directed Dei Valet 561r Remote...
FORD MONDEO 130 TDCI CUT OUT AND WONT START
common rail injection or traditional injector pump
Nov 11, 2008 | 2000 Ford Focus
How to install a remote car starter
The remote start should come with instructions, you will need these especially for the diagram of the units wiring harness.  It will need to be wired into the ignition key on wire, the ignition starter wire, power and ground, and usually the brake light wire, and a hoodpin disable switch that will come with the unit.  Also most manufactures will have a website with vehicle specific details like color and location of each wire on the vehicle.  hope this helps.
Oct 30, 2008 | 1998 Ford Contour
Code-Alarm Code Alarm  Transponder Logo
366 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
