Question about ION Audio iTTUSB Turntable
Arm does not track properly but skips across records
Just bought and installed a TTUSB05XL turntable and I am unable to record as the tonearm keeps skipping across the vinyl. Have searched the documentation for any info on adjustment but can find nothing other than troubleshooting for the software. The same vinyls play perfectly ok on my conventional Dual turntable.
Any help gratefully appreciated
Mike Barnes
  • mbarnes01 Jan 07, 2009
    Thanks for your reply, but I can find no documents for the turntable itself and nothing on the arm itself that looks capable of adjustment. I have solved the problem temporarily by the addition of some Blutack as a weight, but any thoughts on a more permanent solution would be welcome.
  • 3 Answers
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Posted on Jan 04, 2009
Turntable skips regularly
Once adjusted to the correct weight for the type of cartridge then the arm should only jump on a bad record. If it keeps on jumping then either there is something wrong with the platter, being warped or a bad matt. Or there is something in the mechanism that is causing the jumps. Either of these two causes is possible if it does it in the same position on two different records.
Mar 05, 2014 | Technics Audio Players & Recorders
All 33 records seem to be skipping. Is there a weight adjustment option for teh tone arm?
there is a counter weight on the rear of the tonearm that will add weight to the stylis (tracking force)
Apr 29, 2013 | Jensen JTA460 Turntable
The arm just slides across the record.
The link for this model's manual is a dead-end at the Panasonic website. I lodged an email complaint.
If the tonearms balance and anti-skate are set properly it should track correctly.
When you lower the tonearm does it actuallu drop onto the platter or does it seem to hover? Look at the stylus to make sure a dustball hasn't clogged the tip.
Jan 19, 2011 | Technics SL-BD20D Turntable
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus. styluscity@gmail.com
Jul 08, 2010 | Technics SL-1200 Turntable
The stylus skips across the record, despite readjusting the tracking force and the anti-skate control. After repeated adjustments for too little and too much weight, nothing helps. Does the stylus need...
If your needle skips across the record, then there is only 1 thing wrong with it... it's broken, and needs to be replaced.
If after you've replaced the stylus, and problem persists, then you have something a little more serious... Tonearm damage. More than likely not, but just in case replace the stylus does not help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Aug 25, 2009 | Audio Players & Recorders
Turntable stylus not staying on record
Since there are no tonearm adjustments the only solution in the manual that comes close is to make sure the turntable is level. The other possibility is the no-brainer of checking the stylus cover is NOT rotated down, preventing the stylus from contacting the record.
A quick and dirty test of tonearm balance being too light would be to unplug the power and manually move the tonearm over the platter. Gently lower it to see if it floats in the air or lightly but firmly contacts the platter. That won't tell you if it is tracking properly but it might indicate or eliminate tracking force as the culprit.
Apr 26, 2009 | Audio Players & Recorders
Only records 3 or 4 out of 10 songs
Please describe the exact model number and what it's doing wrong (skipping, I suspect). The tonearm setup is critical for proper tracking. Do it again with extreme care if mistracking is your problem.
I found one model online and a review with some sample of music. Quite interesting...
http://www.everythingusb.com/ion_ttusb10_usb_turntable_13231.html
The author complained about some things that clearly mark him as a stranger to finer turntables. Complaining about having to assemble and position the 'rubber band', aka the drivebelt, and the tonearm counterweight shows that he underestimates the precision required to for a mechanism to properly track the microscopic undulations of the groove without skipping into the air or gouging it to death.
Some basics when recording from a turntable...
1) Place the turntable as far from speakers as possible on a solid surface that you will not touch during the recording
2) Keep the volume low enough that airborne sounds don't cause mistracking of the stylus *
3) Avoid anything that will cause vibration or movement of the turntable.
* If you have a subwoofer, turn it off.
Some advice after reading the articel: don't try to save recording time by playing the discs at 45rpm. The best tracking of the disc and recording of the minute details in the grooves will be at the nativespeed of the recording. Digital manipulation later only gloms up the accuracy you probably want.
In general, the fewer the conversions steps in the analog domain, the better; and the fewer the bit rate conversions in the digital domain, the better.
Apr 03, 2009 | ION Audio Vinyl Recording Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
Tone arm skipping/not moving on especially at end of record
The issue is with your tonearm, and not your tracking. You probably have slight damage to the tonearm bearings, which will cause this. There are 2 options... you can try to adjust the pivoting screw at the top of the tonearm ... However, WE DO NOT RECOMMEND THIS, because once you mess with this screw, it's EXTREMELY difficult to get it back to the correct setting, as this screw is machine calibrated at the factory. So, we only recommend this when you have no other choice, or it's an emergency (the middle of a set).
You can view a video on how to do this, by going here - http://djprolab.com
Eventually, your going to have to have your Technics Tonearm replaced. This should be done by a professional, as it is not an easy replacement.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 11, 2008 | Technics SL-1210MK5 Turntable
ION Audio iTTUSB Turntable Logo
915 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
