Question about Samsung Televison & Video
Im looking for the setup code for a Samsung HT Z320 on samsung remore BN59-00709A
Im looking for the setup code for a Samsung HT Z320 on samsung universal remote BN59-00709A
SOURCE: Comcast 3 in 1 Universal Remote code for Samsung DVD-V5500
I had the same problem trying to use those three codes with a Samsung DVD-R155 recorder and then downloaded the pdf files for all of Comcast's remotes and came up with two codes (1) 20490 and (2) 21470. The second code worked for me. Hope that this will work for someone else.
Posted on Oct 26, 2008
SOURCE: region codes
While looking through some forum posts i found the way to fix the problem. It takes a bit of fiddling around but it does work... I tried it out last night.
Firstly you need to put a DVD of a different region into your player and wait for it to start to read the DVD before you commence the procedure... it takes a bit to get the timing right.
when the DVD can't be read it, on screen Eject Disc will come up
Press Repeat & Hold 3 Seconds (it may work using either repeat button on the bottom, i tried both.
Press 76884
After entering those 5 digits, you should see a number in the top left corner of the screen corresponding to the current region (4 being Australia region)
Press 9 for "auto-region" mode ie. Region Free
Turn Off Machine
and there you have it. The timing is crucial so start trying as soon as the DVD is in. It took me 5 goes before it worked.
You will notice that it may take a bit longer for the other Region DVDs to be read then normal but it's only a few seconds longer.
Posted on Dec 02, 2008
  • 5 Answers
SOURCE: region codes for Samsung ht z110
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
posted by alfredsaviou
Posted on Feb 05, 2009
SOURCE: region free code for samsung HD-BD2E
Haven't tried it, but found this online somewhere....
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
6. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9.
7. Press ENTER on remote. (The tray will open)
8. Switch off power from remote, then switch back on.
9. Player is now Region Free.
Posted on Mar 22, 2009
  • 219 Answers
Try this
Posted on Apr 25, 2009
What's the name of speaker conector of the HT Samsung HT-Z320
They are called composite video and audio connections. (RCA jack style)
May 29, 2010 | Samsung Audio Players & Recorders
What does FanChck mean on my samsung HT-Z320? How to I fix it?
I had the same problem with my Samsung HT-BD1250. In my case the fan did not run at any time! As a safety precaution, to prevent overheating, when the fan is malfunctioning the receiver powers off. I simply opened up the receiver and discovered that the fan was not even connected! I just plugged it in and.....Voila! Works like a charm. Be warned though that if your unit is still under warranty, opening it up will likely void the warranty.
Feb 07, 2010 | Samsung HT-Z310T Theater System
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
I have a Samsung 5.1Ch Home Cinema System. HT-Z320 and a SONY Integrated Digital TV DV3. Is there any way that i can set the surround up so that the tv can be played througt surround system and not just...
I just hooked up my HT-Z320 today. I had to use an optical audio cable to connect the audio output from my TV to the optical audio input in the samsung receiver (it's the only optical jack on the receiver). Then with your samsung remote in DVD/Receiver mode, click the Auxiliary button (near the top right of the remote). Hope this helps.
Nov 18, 2009 | Sony Televison & Video
Televison & Video Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
