Question about Hunter Dryers
Does anyone have Hunter Fan remote 86257 manual?
Remote control does not work even with new battery
  • 10865 Answers
SOURCE: need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
Posted on May 31, 2009
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
  • 3 Answers
SOURCE: Hunter Fan has stopped accepting remote control signals
I'll guess and say that the fan quit working properly shortly after either a power surge in your house of after a light burnt out after turning them on. It has happened several times to the two Hunter fans we have here, both with the wireless remote control. After having both replaced under warranty, and then paying for a replacement, I finally took the receiver apart and found the root cause. There is a power regulator (looks like a power transistor) that uses the aluminum portion on the housing as a heat sink. The part is easy to replace for those of you who are handy with a soldering pencil. For those of you who are not, I'm sure you know of someone who is. Now for the good and bad news. The good news? The replacement part is about a dollar from an electronics supply house called Mouser. I tried Radio Shack, but they have really cut back on electronic components. The bad news? I can't remember the part number. I have a spare one, but I can't find it right now. I will look for it and if need be, I'll open up the receiver and get the number off of it and post back to this thread. After replacing the part in both a little over six months ago, we have had no problems with the receivers. Voltage spikes no longer take out the regulator.
Posted on Jan 04, 2010
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
SOURCE: Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Posted on Mar 11, 2010
Romote control is not working.there is a battery in it ,red light comes up but fan is not reponding.is there any way i can manually control the fan ,any button hided some where? or i can make sure remote...
normally in Hunter fans its not the controller but the receiver goes out, if your controller has a new battery and the receiver doesn't get the signal,, the fan isn't going to work, I've never been able to Locate Hunter receivers, tons of the remotes, you can contact them on line at this link
http://www.huntershoponline.com/cc_contactus.asp
Aug 26, 2011 | Hunter (25417) Ceiling Fan
I have the Hunter remote control fan model UC7848. The remote has stopped working, although the light does come on when the battery was replaced. There doesn't seem to be another way to turn the fan on. ...
have you sanded the terminals off on the battery contacts in the battery compartment in the remote,even new batteries at 3 volts between the 2 batteries cannot pass alll the signals if the tabs of the battery are corroded,i know ,you will say,they look shiny,but any glossy corrosion will inhibit battery voltage,use a nail file board lightly
Jul 28, 2010 | Hunter 52" Ceiling Fan With Light And...
Recently moved, the remote doesn't work the fan, and there isn't a wall on off switch This is a Hampton Breeze fan. A Hunter univesal remote
If the remote is not working, first check the batteries. If you have the manual for the programmable remote try to reset it. If you have no wall swtch you have to control the fan and light manually with the pull chains on the fan.
Jan 16, 2010 | Hunter 27148 Remote Control
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Aug 13, 2009 | Hunter Ceiling Fan Remote Transmitter...
Installed new hunter westminster and the lights work but no fan. and how do i get my hunter remote to work with fan?
begin by unscrewing one wire nut at a time to be sure that the wires are tightly twisted together before the wire nut is reinstlled. Once you have the fan working manually, the remote will also work.
Jan 07, 2009 | Hunter 27187 Remote Control
Dryers Logo
49 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
